path: root/sound/pci/cs5530.c
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-02-26ALSA: cs5530: Use standard printk helpersTakashi Iwai
Convert with dev_err() and co from snd_printk(), etc. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-12ALSA: pci: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-29ALSA: PCI: Remove superfluous pci_set_drvdata(pci, NULL) at removeTakashi Iwai
As drvdata is cleared to NULL at probe failure or at removal by the driver core, we don't have to call pci_set_drvdata(pci, NULL) any longer in each driver. The only remaining pci_set_drvdata(NULL) is in azx_firmware_cb() in hda_intel.c. Since this function itself releases the card instance, we need to clear drvdata here as well, so that it won't be released doubly in the remove callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: pci: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-30ALSA: cs5530: Fix resource leak in error pathTakashi Iwai
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44741 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: pci: clean up using module_pci_driver()Takashi Iwai
2011-12-19ALSA: Add missing module parameters for als300 and cs5530 driversTakashi Iwai
These drviers defined only variables but didn't declare as module parameters. Also fix the enable variable to bool type. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-27Merge branches 'topic/fix/asoc', 'topic/fix/hda', 'topic/fix/misc' and ↵Takashi Iwai
'topic/pci-ioremap-bar' into for-linus
2008-10-27sound: use a common working email addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-21pci: use pci_ioremap_bar() in sound/Arjan van de Ven
Use the newly introduced pci_ioremap_bar() function in sound/. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-07-20[ALSA] Add support for Cyrix/NatSemi Geode CS5530 (VSA1)Takashi Iwai
Add support for Cyrix/NatSemi Geode SC5530 (VSA1). The driver is snd-cs5530. Signed-off-by Ash Willis <ashwillis@programmer.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
