path: root/sound/pci/cs5535audio
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-15ALSA: cs5535audio: free OLPC quirks from reliance on MGEODE_LX cpu optimizationAndres Salomon
Previously, OLPC support for the mic extensions was only enabled in the ALSA driver if CONFIG_OLPC and CONFIG_MGEODE_LX were both set. This was because the old geode GPIO code was written in a manner that assumed CONFIG_MGEODE_LX. With the new cs553x-gpio driver, this is no longer the case; as such, we can drop the requirement on CONFIG_MGEODE_LX and instead include a requirement on GPIOLIB. We use the generic GPIO API rather than the cs553x-specific API. Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Takashi Iwai <tiwai@suse.de> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-02-05ALSA: Fix missing KERN_* prefix to printk in sound/pciTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535 - Make OLPC-stuff depending on MGEODE_LXTakashi Iwai
The GPIO stuff for OLPC in cs5535audio_olpc.c is implemented only for Geode-LX, and enabled only when CONFIG_MGEODE_LX=y. Without this config option, the driver gets build errors. This patch adds a workaround to make it dependent on CONFIG_MGEODE_LX. Ideally, the OLPC-GPIO stuff should be implemented in a way independent from CPU type selection... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: ensure MIC Bias/Analog Input bail if not on an OLPC machineAndres Salomon
Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: clean up OLPC codeAndres Salomon
- add copyright info to _olpc.c - minor layout fixes - make Makefile more concise - silence a warning Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: turn off mic bias on OLPCs by defaultAndres Salomon
Always turn off mic bias; the MIC LED should never come on when the driver is first loaded. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: for OLPC, default to Analog Input being offAndres Salomon
2008-12-10ALSA: cs5535audio: rename V_REFOUT control to MIC BiasAndres Salomon
This drops the AD1888 V_REFOUT control, and replaces it with a MIC Bias Enable control. It also moves the MIC bias enabling into a separate function. Signed-off-by: Andres Salomon <dilinger@debian.org>
2008-12-10ALSA: cs5535audio: enable OLPC's V_REFOUT bias when recordingChris Ball
The OLPC has a privacy light hooked up in series with the microphone's V_Ref bias. We want to activate the bias while we are capturing audio. Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: check OLPC's Analog Input status vis GPIOAndres Salomon
Checking the HPF register is irrelevant; HPF is secondary to the AI mode. Instead, check for Analog Input mode via GPIO. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: rename OLPC's analog input control && drop AD1888's HPFAndres Salomon
Previously, we had two separate controls; there's no need to have AD1888's HPF control, so drop it if we're on an OLPC machine. Also, as per Arjun's request, rename OLPC's Analog Input Switch control to "DC Mode Enable". Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: create function for setting OLPC's Analog Input modeAndres Salomon
Clean this stuff up a bit.. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: decouple HPF from V_REFOUT in OLPC codeAndres Salomon
We shouldn't be touching V_REFOUT when we toggle HPF/analog input, so just drop that code. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: drop ec_analog_input flag for OLPC stuffAndres Salomon
This is no longer necessary, as we're no longer doing indexed i/o commands. Signed-off-by: Andres Salomon <dilinger@debian.org>
2008-12-10ALSA: cs5535audio: invert EAPD for OLPC (newer than B3)Andres Salomon
Fix an audible pop described in <http://dev.laptop.org/ticket/977>. Originally based upon fixes by Mitch Bradley and Chris Ball. Signed-off-by: Andres Salomon <dilinger@debian.org>
2008-12-10ALSA: cs5535audio: Use OLPC/Geode basic infrastructureJordan Crouse
Use basic infrastructure code; geode_gpio* (rather than indexed i/o EC access), and do an OLPC machine check in olpc_quirk. [dilinger@debian.org: don't return failure in olpc_quirks if !OLPC] [dilinger@debian.org: drop the <B2 workarounds; those machines are EOL'd] Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andres Salomon <dilinger@debian.org>
2008-12-10ALSA: cs5535audio: OLPC analog input supportJaya Kumar
This is a 2nd cut at adding support for OLPC analog input. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Andres Salomon <dilinger@debian.org>
2008-12-10ALSA: cs5535audio: suspend/resume callbacks are only defined with CONFIG_PMAndres Salomon
snd_cs5535audio_suspend and snd_cs5535audio_resume are only defined when CONFIG_PM is set; make that clear in the header file. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-10ALSA: cs5535audio: turn off PCM properly if closing the audio deviceJaya Kumar
As per <http://dev.laptop.org/ticket/1420>, we need to properly turn off the PCM if we're closing the device in order to save power. This also causes the MIC led to turn off properly. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] fix cs5535 section mismatchRandy Dunlap
snd_cs5535audio_mixer() is only called by __devinit snd_cs5535audio_probe(), so the mixer function can also be __devinit. WARNING: vmlinux.o(.text+0xfdbba0): Section mismatch: reference to .init.data:ac97_quirks (between 'snd_cs5535audio_mixer' and 'process_bm0_irq') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] cs5535audio - Fix available sample ratesTakashi Iwai
The available sample rates on CS5535 depend on AC97 codec chip. Set the additional hw params limit. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] cs5535audio: drop unused bus master stuffAndres Salomon
We really only care about the first two bus masters (playback and capture). There's no need to have unused BM code lying around, so let's get rid of it. If for some reason we trigger an IRQ for some BM that we're not using.. well, that warrants spitting out an error message (imo). Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] cs5535audio: fix ACC_BM[x]_CMD register handlingAndres Salomon
According to 6.3.2.7 of the cs5535/cs5536 data sheets, the ACC_BM[x]_CMD registers are only 8 bits wide. This driver treats them as 32 bits wide, and also has bits in the wrong place. Simple fix to the definitions. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] cs5535audio: update PCI device handling in suspend/resumeAndres Salomon
Save the PCI state before disabling the device, and add some error checking. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] cs5535audio: fix PRD register save/restore power management raceAndres Salomon
In the suspend path, we currently save the PRD registers and then disable DMA. This is racy; the sound hardware might update the PRD register as it finishes processing some DMA pages between when we've saved the PRD registers and when DMA actually gets disabled. Furthermore, we actively check whether or not DMA is enabled before saving PRD registers; there's no reason to do that, as the PRD registers should not update when we twiddle the ACC_BM[x]_CMD register(s). Worst case, we save the PRD registers twice; even powering down the ACC shouldn't mess with the PRD registers (according to the 5536 data sheet, section 5.3.7.4, power-down procedure). This patch reworks all that to first disable DMA, and then save PRD registers. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] cs5535audio: correctly set dma->substreamAndres Salomon
We're never actually setting dma->substream to the current substream; that means the dma->substream checks that we do in the suspend/resume path are never satisfied, and the PRD registers are never correctly managed. This changes it so that we set the substream when constructing the specific bus master DMA, and unsetting it when we tear down the BM's DMA. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] remove incorrect usage of SNDRV_PCM_INFO_SYNC_START and ↵Clemens Ladisch
snd_pcm_set_sync() Set the SNDRV_PCM_INFO_SYNC_START flag and the substream's sync ID (only) if the substream actually can be linked to another one. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up MakefileTakashi Iwai
Clean up Makefile using xxx- style instead of ifeq(CONFIG_XXX,y). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Various fixes for suspend/resume of ALSA PCI driversTakashi Iwai
- Check the return value of pci_enable_device() and request_irq() in the suspend. If any error occurs there, disable the device using snd_card_disconnect(). - Call pci_set_power_state() properly with pci_choose_state(). - Fix the order to call pci_set_power_state(). - Removed obsolete house-made PM codes in some drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Fix Makefile of cs5535audioTakashi Iwai
Use ifeq instead of ifdef in Makefile to make the maintenance of out-of-kernel tree easier. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-22[ALSA] cs5535audio - trivial debug printkJaya Kumar
Following is a trivial patch to get more info for boards where the AC97_VENDOR_ID2 register (or others) time out. Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Change an arugment of snd_mpu401_uart_new() to bit flagsTakashi Iwai
Change the 5th argument of snd_mpu401_uart_new() to bit flags instead of a boolean. The argument takes bits that consist of MPU401_INFO_XXX flags. The callers that used the value 1 there are replaced with MPU401_INFO_INTEGRATED. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Single variables for cs5535audioJaya Kumar
As per Takashi's feedback, this is a cleanup to make cs5535audio be single device per system. The diff is against 2.6.17-rc4 with Takashi's patch adding the module_params for index, id and enable. Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] cs5535audio - Add missing module_param*() and MODULE_PARM_DESC()Takashi Iwai
Added missing module_param*() and MODULE_PARM_DESC() for cs5535audio driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] PM support for cs5535audioJaya Kumar
Appended is my patch adding PM support to the cs5535audio driver. I also added the ac97 quirk but it's not yet confirmed which boards need to be in the quirk list. The patch also includes some Kconfig and misc cleanup. Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] CS5535: shorter delays when accessing AC'97 codec registersDavid Vrabel
Modules: CS5535 driver The 10 ms sleeps while waiting for AC'97 codec register reads/writes to complete are excessive given the maxmium time is one AC'97 frame (~21 us). With AC'97 codecs with integrated touchscreens (like the UCB1400) this improves the interactive performance of the touchscreen. Signed-off-by: David Vrabel <dvrabel@arcom.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] AMD cs5536 ID for cs5535audioRene Rebe
Modules: CS5535 driver Added AMD CS5536 to the cs5535audio driver. Signed-off-by: Rene Rebe <rene@exactcode.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-10[PATCH] i386: GPIO driver for AMD CS5535/CS5536Ben Gardner
A simple driver for the CS5535 and CS5536 that allows a user-space program to manipulate GPIO pins. The CS5535/CS5536 chips are Geode processor companion devices. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] cs5535audio: move sound/driver.h to the topClemens Ladisch
Modules: CS5535 driver Move the #include of <sound/driver.h> to the top which is required for compilation on earlier kernels. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
