path: root/sound/pci/ctxfi/ctdaio.c
2011-06-14ALSA: ctxfi: Add support for Creative Titanium HDHarry Butterworth
Initialise model-specific DAC and ADC parts. Add controls for output and mic source selection. Rename some mixer controls according to ControlNames.txt. Remove Playback switches for Line-in and IEC958-in - these were controlling the input mute/unmute which affected capture too. Use the capture switches to control the input mute/unmute instead - it's less confusing. Initialise the WM8775 to invert the left-right clock to swap the left and right channels of the mic and aux input. Signed-off-by: Harry Butterworth <heb1001@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Clear input settings before initializationPrzemyslaw Bruski
Clear input settings before initialization. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-22ALSA: ctxfi - Simple code clean upTakashi Iwai
- replace NULL == xxx with !xxx - replace NULL != xxx with xxx - similar trivial cleanups Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-20ALSA: ctxfi: Swapped SURROUND-SIDE channels on emu20k2Frank Roth
On Soundblaster X-FI Titanium with emu20k2 the SIDE and SURROUND channels were swapped and wrong. I double checked it with connector colors and creative soundblaster windows drivers. So I swapped them to the true order. Now "speaker-test -c6" and "speaker-test -c8" are working fine. Signed-off-by: Frank Roth <frashman@freenet.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-08ALSA: ctxfi - Clean up probe routinesTakashi Iwai
Clean up probe routines and model detection routines so that the driver won't call and check the PCI subsystem id at each time. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-08ALSA: ctxfi - Remove useless initializations and castTakashi Iwai
Remove useless variable initializations and cast at the beginning of functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-14ALSA: SB X-Fi driver mergeWai Yew CHAY
The Sound Blaster X-Fi driver supports Creative solutions based on 20K1 and 20K2 chipsets. Supported hardware : Creative Sound Blaster X-Fi Titanium Fatal1ty® Champion Series Creative Sound Blaster X-Fi Titanium Fatal1ty Professional Series Creative Sound Blaster X-Fi Titanium Professional Audio Creative Sound Blaster X-Fi Titanium Creative Sound Blaster X-Fi Elite Pro Creative Sound Blaster X-Fi Platinum Creative Sound Blaster X-Fi Fatal1ty Creative Sound Blaster X-Fi XtremeGamer Creative Sound Blaster X-Fi XtremeMusic Current release features: * ALSA PCM Playback * ALSA Record * ALSA Mixer Note: * External I/O modules detection not included. Signed-off-by: Wai Yew CHAY <wychay@ctl.creative.com> Singed-off-by: Ryan RICHARDS <ryan_richards@creativelabs.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
