path: root/sound/pci/ctxfi/xfi.c
2011-06-14Merge branch 'test/pci-rename' into topic/miscTakashi Iwai
2011-06-14ALSA: ctxfi: Add support for Creative Titanium HDHarry Butterworth
Initialise model-specific DAC and ADC parts. Add controls for output and mic source selection. Rename some mixer controls according to ControlNames.txt. Remove Playback switches for Line-in and IEC958-in - these were controlling the input mute/unmute which affected capture too. Use the capture switches to control the input mute/unmute instead - it's less confusing. Initialise the WM8775 to invert the left-right clock to swap the left and right channels of the mic and aux input. Signed-off-by: Harry Butterworth <heb1001@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-14ALSA: ctxfi - Add subsystem optionTakashi Iwai
Added a new option "subsystem" to override the PCI SSID for identifying the card type. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-22ALSA: ctxfi - Add PM supportWai Yew CHAY
Added the suspend/resume support to ctxfi driver. The team tested on the following seems ok: AMD Athlon 64 3500+ / ASUS A8N-E / 512MB DDR ATI / Radeon X1300 20k1 & 20k2 cards Signed-off-by: Wai Yew CHAY <wychay@ctl.creative.com> Singed-off-by: Ryan RICHARDS <ryan_richards@creativelabs.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-08ALSA: ctxfi - Clean up probe routinesTakashi Iwai
Clean up probe routines and model detection routines so that the driver won't call and check the PCI subsystem id at each time. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-05ALSA: ctxfi - Clean up / optimizeTakashi Iwai
- Use static tables instead of assigining each funciton pointer - Add __devinit* to appropriate places; pcm, mixer and timer cannot be marked because they are kept in the function table that lives long - Move create_alsa_devs function out of struct ct_atc to mark it __devinit Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-02ALSA: ctxfi - Fix a typo in MODULE_LICENSETakashi Iwai
A space has to be put between GPL and v2. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-26ALSA: ctxfi - Add missing module parameter definitionsTakashi Iwai
Added missing module_param*() and MODULE_PARM*(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-14ALSA: ctxfi - Add prefix to debug printsTakashi Iwai
Added ctxfi: prefix to each debug print. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-14ALSA: ctxfi - Move PCI ID definitions to linux/pci_ids.hTakashi Iwai
2009-05-14ALSA: SB X-Fi driver mergeWai Yew CHAY
The Sound Blaster X-Fi driver supports Creative solutions based on 20K1 and 20K2 chipsets. Supported hardware : Creative Sound Blaster X-Fi Titanium Fatal1ty® Champion Series Creative Sound Blaster X-Fi Titanium Fatal1ty Professional Series Creative Sound Blaster X-Fi Titanium Professional Audio Creative Sound Blaster X-Fi Titanium Creative Sound Blaster X-Fi Elite Pro Creative Sound Blaster X-Fi Platinum Creative Sound Blaster X-Fi Fatal1ty Creative Sound Blaster X-Fi XtremeGamer Creative Sound Blaster X-Fi XtremeMusic Current release features: * ALSA PCM Playback * ALSA Record * ALSA Mixer Note: * External I/O modules detection not included. Signed-off-by: Wai Yew CHAY <wychay@ctl.creative.com> Singed-off-by: Ryan RICHARDS <ryan_richards@creativelabs.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
