commit 10f571d09106c3eb85951896522c9650596eff2e upstream.
Add chip details for E-mu 1010 PCIe card. It has the same
chip as found in E-mu 1010b but it uses different PCI id.
Signed-off-by: Maxim Kachur <mcdebugger@duganet.ru>
0x20051102 is an Audigy 2 ZS.
Signed-off-by: Tim Yamin <plasm@roo.me.uk>
Lots of sound drivers were getting module.h via the implicit presence
of it in <linux/device.h> but we are going to clean that up. So
fix up those users now.
This patch adds the necessary details to support the PCIe version of
E-MU's 0404 card.
From comparing the PCBs it seems the PCIe version just added a PCIe
chipset and left all other components pretty much in place.
For anyone intrigued to take a look at the PCB there are pictures I took
at <http://babelmonkeys.de/~florob/E-MU%200404/>.
Signed-off-by: Florian Zeitz <florob@babelmonkeys.de>
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The patch below removes an extra "l" in the word.
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Fix this sparse warnings:
sound/pci/emu10k1/emu10k1_main.c:723:66: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:724:68: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:748:74: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:751:66: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:759:73: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:760:73: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:837:50: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:845:50: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:881:50: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:889:57: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:890:57: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:895:60: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:897:60: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:899:60: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:910:56: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:914:57: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:918:56: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:922:57: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:924:58: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:936:60: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:1073:60: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:1088:60: warning: incorrect type in argument 3 (different signedness)
sound/pci/emu10k1/emu10k1_main.c:1093:58: warning: incorrect type in argument 3 (different signedness)
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Fix the inverted logic of shared spdif switch.
Reference: Novell bnc#478496
https://bugzilla.novell.com/show_bug.cgi?id=478496
Reported in Novell bnc#440862:
https://bugzilla.novell.com/show_bug.cgi?id=440862
I fixed all of coding style errors and some warnings, now it is down to:
checkpatch.pl-0.24 --no-tree --file --strict --terse emu10k1_main.c
total: 0 errors, 62 warnings, 7 checks, 2075 lines checked
Signed-off-by: Vedran Miletic <rivanvx@gmail.com>
Commit 18c7109289625106cdc810b20b628cd13b46d6dd had #endif leftoff from
compilation. This patch fixes it.
Also, I replaced a misplaced comment by a useful one, that explains why are
here #ifdef and #endif added in compilation.
* added missing SBxxxx, CTxxxx, PCxxx and MAEMxxxx where they were missing,
and fixed some of them which were wrong (according to kx.inf, which is pretty
accurate compared to anything out there)
* fixed device names to make them more consistent across various cards
* fixed order of devices where appropriate
On Audigy2 Platinum, the Analog/Digital mixer switch is inverted.
https://bugzilla.novell.com/show_bug.cgi?id=396204
The patch adds a simple workaround.
There might be another device requiring a similar fix, too (or fix for
audigy2 generically), but right now I fix only the known broken one.
When the Linux kernel is compiled with CONFIG_DEBUG_SHIRQ=y,
the Soundblaster Audigy2 ZS Notebook PCMCIA card causes the
system hang during boot (udev stage) or when the card is hot-plug.
The CONFIG_DEBUG_SHIRQ flag is by default 'y' with all Fedora
kernels since 2.6.23. The problem was reported as
https://bugzilla.redhat.com/show_bug.cgi?id=326411
The issue was hunted down to the snd_emu10k1_create() routine:
/* pseudo-code */
snd_emu10k1_create(...) {
request_irq(... IRQF_SHARED ...) {
register the irq handler
#ifdef CONFIG_DEBUG_SHIRQ
call the irq handler: snd_emu10k1_interrupt() {
poll I/O port // <---- !! system hangs
#endif
snd_emu10k1_cardbus_init(...) {
initialize I/O ports
The early access to I/O port in the interrupt handler causes
the freeze. Obviously it is necessary to init the I/O ports
before accessing them. This patch moves the registration of
the irq handler after the initialization of the I/O ports.
Signed-off-by: Jaroslav Franek <jarin.franek@post.cz>
Acked-by: James Courtier-Dutton <James@superbug.co.uk>
The irq handler of PCI drivers must be released before releasing other
resources since the handler for a shared irq can be still called and
may access the freed resource again.
This is based on pseudo-random playing around with the capabilities.
With ca0102 this card gives no output atall, ca0108 appears to work
fine, so it rather looks similar to the EMU1010b/EMU1010 changes.
Some other people seem to have succeeded in using this aswell:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3496
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Don't create emu1010 kthread again at resume if it's already created.
Also make the thread function static.
bug#9304.
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
Use enum instead of digits for emu_model types.
This patch improves E-Mu 1616(M) cardbus support. It adds definitions of the
new Microdock and 1010 cardbus registers (thanks again for descriptions
James) and improves mixer for this card. Now you can use S/PDIF and ADAT on
Mirodock and also use headpohone output on host cardbus card as another
independent output.
Signed-off-by: Ctirad Fertr <c.fertr@gmail.com>
0404.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
vmalloc() returns void *. no need to cast.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Patch submitted by Ctirad Fertr
<c.fertr@volny.cz>
Details:
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=8176
* adding 8 more 32-bit capture channels (total of 16) for emu1010 cards
* adding some code comments and card details description
Signed-off-by: Pavel Hofman <dustin@seznam.cz>
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Add MODULE_FIRMWARE() entries, where appropriate.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
E-Mu 1010 is not currently supported yet. Needs development work.
Implement functionallity in order to fixe ALSA bug#2058.
Fixed a compile warning regarding print format for size_t.
1820m
Fix IRQ flags for PCI devices.
The shared IRQs for PCI devices shouldn't be allocated with
IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't
be used.
The patch removes unnecessary cast in request_irq and free_irq,
too.
Fixes ALSA bug#324
The emu10k1 driver saves the A_IOCFG and HCFG register on suspend and restores
it on resumes. Unfortunately, this doesn't work as the arguments to outl() are
reversed.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
card.
Fixes ALSA bug#1365.
Fixed 'section mismatch' errors in ALSA PCI drivers:
- removed invalid __devinitdata from pci id tables
- fix/remove __devinit of functions called in suspend/resume
