path: root/sound/pci/hda/alc861vd_quirks.c
2011-07-07ALSA: hda - Split quirk codes from patch_realtek.cTakashi Iwai
Put the all static quirk codes out of patch_realtek.c, split into the file for each codec model. For controlling the build of quirk codes, a new Kconfig, CONFIG_SND_HDA_ENABLE_REALTEK_QUIRKS is introduced. By setting this off, all quirk codes won't be built, thus you can save lots of memory. The codes in patch_realtek.c are also shuffled and more comments are given, but the contents aren't changed. This is just a refactoring. Signed-off-by: Takashi Iwai <tiwai@suse.de>
