commit 2e1210bc3d065a6e26ff5fef228a9a7e08921d2c upstream.
This patch fixes "Surround Speaker Playback Volume" being cut off.
(Commit b4dabfc452a10 was probably meant to fix this, but it fixed
only the "Switch" name, not the "Volume" name.)
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 87232dd49aeb6b7d1af291edca8bd129a82ef4b5 upstream.
This patch add support for the MacBookAir3,1 and MacBookAir3,2 to the alsa
sound system.
Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com>
commit f46119b73425df9d1e05c5d5e909a993d95b0218 upstream.
Reference: Novell bnc#645066
https://bugzilla.novell.com/show_bug.cgi?id=645066
commit 4e7d7c6018567fa03f387d06602d4145c75ebbe0 upstream.
I've found the following patch is necessary to enable line-in on
my MacBookPro 5,3 machine. With the patch applied I've successfully
recorded audio from the line-in jack. This is based on the existing
5,5 support.
Signed-off-by: Vince Weaver <vweaver1@eecs.utk.edu>
commit 1a5ba2e9fc7999b8de2a71c7e7b9f58d752c05e4 upstream.
With the attached patch I am able to use the sound on a new IMac 27.
What works:
*) Internal speakers
*) Internal microphone
*) Headphone
I don't have an external mic or a SPDIF device to test the rest.
Signed-off-by: Rafael Avila de Espindola <rafael.espindola@gmail.com>
The patch below, to be applied on the latest sound-unstable-2.6.git,
enables headphones output on my MacBookPro 5,5, together with the
automuting feature.
Here is the exact soundcard id:
Vendor Id: 0x10134206
Subsystem Id: 0x106b4d00
Revision Id: 0x100301
Increase the name string buffer size so that "Surround Speaker Playback
Volume" won't be truncated.
GPIO3 seems corresponding to EAPD that is required for the speaker
output.
Add the default pin configs for MBP55.
The parser wasn't called in the proper order.
Split now the parser to be called in patch_cirrus(), and the rest
are just for building PCMs and controls.
