commit de4da59e480cdf1075b33dbaf8078fc87bc52241 upstream.
These laptops can work well with the auto-parser and their BIOS setups,
and in addition, the auto-parser fixes the problem with S3/S4 where
the unsol event handling is killed after resume due to fallback to the
single-cmd mode.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740115
commit 6b45214277bec2193ad3ccb8d7aa6100b5a0f1a9 upstream.
It seems that Conexant CX20549 chip handle only a single input-amp even
though the audio-input widget has multiple sources. This has been never
clear, and I implemented in the current way based on the debug information
I got at the early time -- the device reacts individual input-amp values
for different sources. This is true for another Conexant codec, but it's
not applied to CX20549 actually.
This patch changes the auto-parser code to handle a single input-amp
per audio-in widget for CX20549. After applying this, you'll see only a
single "Capture" volume control instead of separate "Mic" or "Line"
captures when the device is set up to use a single ADC.
We haven't tested 20551 and 20561 codecs yet. If these show the similar
behavior like 20549, they need to set spec->single_adc_amp=1, too.
commit 254f296840b64b034a4c850d45dbde7c040f0819 upstream.
In the old Conexant chips (5045, 5047, 5051 and 5066), a single EAPD
may handle both headphone and speaker outputs while it's assigned only
to one of them. Turning off dynamically leads to the unexpected silent
output in such a configuration with the auto-mute function.
Since it's difficult to know how the EAPD is handled in the actual h/w
implementation, better to keep EAPD on while running for such codecs.
This is patch for Conexant codec of Intel HDA driver, adding new quirk
for Lenovo Thinkpad T520 and W520. Conexant autodetection works fine for
T520 (similar subsystem ID is used also in W520 model) and detects more
mixer features compared to generic (fallback) Lenovo quirk with
hardcoded options in Conexant codec.
Patch was activelly tested with Linux 3.0.4, 3.0.6 and 3.0.7 without any
problems.
Signed-off-by: Daniel Suchy <danny@danysek.cz>
Cc: <stable@kernel.org> [3.0+]
Headphones has stopped working for the original reported (a regression
compared to 2.6.38). This is because Speaker and Headphones share the
same DAC, in which case no Headphones volume control was created.
This patch fixes so that both Speaker and Headphones volume
controls are created in such scenario.
BugLink: http://bugs.launchpad.net/bugs/817943
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
The ADC-switching can work also in the auto-mic mode, too.
When multiple headphones or speakers are assigned but no individual
DACs are available, the driver should take the first HP/SPK DAC instead
of another primary output. The patch adds a bit-flag to dac field of
struct pin_dac_pair indicating that it's a slave DAC.
The procedure for codec D-state change may have exceptional cases
depending on the codec chip, such as a longer delay or suppressing D3.
This patch adds a new codec ops, set_power_state() to override the system
default function. For ease of porting, snd_hda_codec_set_power_to_all()
helper function is extracted from the default set_power_state() function.
As an example, the Conexant codec-specific delay is removed from the
default routine but moved to patch_conexant.c.
Some machines seem to use EAPD control of the unused pin for controlling
the overall EAPD. Since the driver currently doesn't check the EAPD of
unused pins, the EAPD isn't enabled. For avoiding such a problem, turn
all extra EAPDs on as default.
Let's use auto-parser as default now.
Create snd_hda_get_conn_index() helper function for obtaining the
connection index of the widget. Replaced the similar codes used in
several codec-drivers with this common helper.
Since we're not using the new auto parser as a fallback yet,
add it manually as a quirk.
Conexant ID 506c was found on Acer Aspire 3830TG. As users report
no playback, sending to stable should be safe.
Cc: stable@kernel.org
BugLink: https://bugs.launchpad.net/bugs/783582
Reported-by: andROOM
N57001 laptop
BugLink: https://launchpad.net/bugs/761171
The original reporter needs the model=auto quirk for his internal
speakers to be audible in the latest daily snapshot, so add an entry in
the quirk table for his PCI SSID.
A trivially different version of this patch using the model=asus quirk
should be applied to the 2.6.38 and 2.6.39 stable kernels. We don't use
the asus quirk in 3.0-rc2, because 3.0-rc2's autoparser is much
improved.
Reported-and-tested-by: tomdeering7
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
The SPDIF output controls apply to converter widgets. A future change
will create a PCM device per pin widget, and hence a set of SPDIF output
controls per pin widget, for certain HDMI codecs. To support this, we
need the ability to virtualize the SPDIF output controls. Specifically:
* Controls can be "unassigned" from real hardware when a converter is
not used for the PCM the control was created for.
* Control puts only write to hardware when they are assigned.
* Controls can be "assigned" to real hardware when a converter is picked
to support output for a particular PCM.
* When a converter is assigned, the hardware is updated to the cached
configuration.
The new auto-parser fixes problems on Lenovo G555.
Fix some logic failures in auto-mute handling in Conexant auto-parser.
Also, modify codes to be a bit more understandable.
Fix the initialization of capture-source route when auto-mic is enabled
for Conexant auto-parser.
Fix the auto-mic detection for Cxt auto-parser due to off-by-one
missing initialization.
Add model=asus quirk for Lenovo Ideapad U350 to make internal mic
work correctly.
Cc: stable@kernel.org (2.6.38+)
BugLink: http://bugs.launchpad.net/bugs/751681
Reported-by: Kent Baxley <kent.baxley@canonical.com>
Similar process like in patch_realtek.c and patch_sigmatel.c.
In addition to the normal external mic jack, check also the mic jack
on a docking-station as well, and select the input source appropriately.
The similar functionality was already implemented in patch_sigmatel.c.
Implement the same functionality as Realtek's auto-mute mode control.
Now Conexant auto-parser can also mutes line-out and provide the enum
control for different automute behavior.
Use a struct instead of each array for managing input-source info
for auto-parser.
Still experimental.
Not enabled as default unless model=auto is passed.
Check the routing more exactly for avoiding the duplicated controls for
the very same effect for multiple capture routes in Conexant auto-parser.
When the intermediate selector widget in the capture path provides the
boost volume, create the corresponding volume control.
Just for safety reason (for avoiding any possible regressions), don't
enable auto-parser as default for cxt5045 and 5051, as well as 5047.
It can (must for some) be used for all Conexnat codecs safely.
Instead of giving fixed arrays, look for ADC nids dynamically in the
tree in Conexant auto-parser code.
Similarly like other Conexant codecs, now model=auto is supported for
cxt5047.
But the auto-parser mode isn't activated as default yet, since BIOS
pin-configs seem often broken on machines with this codec. User need
to pass model=auto explicitly.
Handle not only a single-depth input-route but two-level depth routes
(PIN->MUX->ADC), too.
Keep the registered input-pins in imux_pins[], and fix the inconsistent
use of sepc->auto_mic_ext.
Extend the existing auto-parser for CX2064x for cxt5051 codec.
Now the auto-parser supports ADC-switching for this codec.
Some codecs have no mute caps in audio I/O widgets.
Instead of keeping always EAPD on, turn on/off appropriately at jack
plugging in Conexant auto-parser mode.
The wrong id is assigned for external/internal mics in the auto-mic
selection parser.
Without the "thinkpad" quirk, the dock mic in
Lenovo X220 tablet edition won't work.
BugLink: http://bugs.launchpad.net/bugs/751033
Tested-by: James Ferguson <james.ferguson@canonical.com>
This quirk is needed for the docking station mic of
Lenovo Thinkpad X220 to function correctly.
BugLink: http://bugs.launchpad.net/bugs/746259
Since multiple codec drivers already use the input-jack stuff, let's
make common helper functions to reduce the duplicated codes.
These two Dell machines have been reported working well with
the ideapad model.
BugLink: http://bugs.launchpad.net/bugs/723676
Tested-by: David Chen <david.chen@canonical.com>
Conexant 506e/20590 has the same graph as the rest of the 5066 family.
BugLink: http://bugs.launchpad.net/bugs/723672
Without this patch, one line-out and one speaker and
Conexant's auto parser would announce (non-working) surround
capabilities.
BugLink: http://bugs.launchpad.net/bugs/721126
Conexant 20641 has several inputs to its ADC node, with one selector
and individual amps for all inputs. This patch adds support in the
Conexant auto parser to handle that case.
It also means that the pin node's volume is being renamed to "Boost"
to avoid name clash with the new volume controls on the ADC node.
BugLink: http://bugs.launchpad.net/bugs/719524
The Conexant codec driver adds the jack arrays in init callback which
may be called also in each PM resume. This results in the addition of
new jack element at each time.
The fix is to check whether the requested jack is already present in
the array.
Reference: Novell bug 668929
https://bugzilla.novell.com/show_bug.cgi?id=668929
