commit 275ec0cb946cb75ac8977f662e608fce92f8b8a8 upstream.
Fujitsu Seimens ESPRIMO Mobile U9210 requires the same fixup as H270
for the correct pin configs.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200107
Cc: <stable@vger.kernel.org>
commit d5a6cabf02210b896a60eee7c04c670ee9ba6dca upstream.
Some Lenovo laptops, e.g. Lenovo P50, showed the pop noise at resume
or runtime resume. It turned out to be reduced by applying
alc_no_shutup() just like TPT440 quirk does.
Since there are many Lenovo models showing the same behavior, put this
workaround in ALC269_FIXUP_THINKPAD_ACPI entry so that it's applied
commonly to all such Lenovo machines.
Reported-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Benjamin Berg <bberg@redhat.com>
commit f429e7e494afaded76e62c6f98211a635aa03098 upstream.
Add new support for ALC257 codec.
[ It's supposed to be almost equivalent with other ALC25x variants,
just adding another type and id -- tiwai ]
Signed-off-by: Kailang Yang <kailang@realtek.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
[ Upstream commit c469652bb5e8fb715db7d152f46d33b3740c9b87 ]
The commit ffcd28d88e4f ("ALSA: hda - Select INPUT for Realtek
HD-audio codec") introduced the reverse-selection of CONFIG_INPUT for
Realtek codec in order to avoid the mess with dependency between
built-in and modules. Later on, we obtained IS_REACHABLE() macro
exactly for this kind of problems, and now we can remove th INPUT
selection in Kconfig and put IS_REACHABLE(INPUT) to the appropriate
places in the code, so that the driver doesn't need to select other
subsystem forcibly.
Fixes: ffcd28d88e4f ("ALSA: hda - Select INPUT for Realtek HD-audio codec")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org> # and build-tested
commit ea04a1dbf8b1d6af759d58e705636fde48583f8f upstream.
Fill COEF to change EAPD to verb control.
Assigned codec type.
This is an additional fix over 92f974df3460 ("ALSA: hda/realtek - New
vendor ID for ALC233").
[ More notes:
according to Kailang, the chip is 10ec:0235 bonding for ALC233b,
which is equivalent with ALC255. It's only used for Lenovo.
The chip needs no alc_process_coef_fw() for headset unlike ALC255. ]
commit e40bdb03d3cd7da66bd0bc1e40cbcfb49351265c upstream.
Some HP laptops have a mute mute LED controlled by a pin VREF. The
Realtek codec driver updates the VREF via vmaster hook by calling
snd_hda_set_pin_ctl_cache().
This works fine as long as the driver is running in a normal mode.
However, when the VREF change happens during the codec being in
runtime PM suspend, the regmap access will skip and postpone the
actual register change. This ends up with the unchanged LED status
until the next runtime PM resume even if you change the Master mute
switch. (Interestingly, the machine keeps the LED status even after
the codec goes into D3 -- but it's another story.)
For improving this usability, let the driver temporarily powering up /
down only during the pin VREF change. This can be achieved easily by
wrapping the call with snd_hda_power_up_pm() / *_down_pm().
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199073
[ Upstream commit fc7438b1eb12b6c93d7b7a62423779eb5dfc673c ]
Headset microphone does not work out of the box on ASUS Nx51
laptops. This patch fixes it.
Patch tested on Asus N551 laptop. Asus N751 part is not tested, but
according to [1] this laptop uses the same audiosystem.
1. https://bugzilla.kernel.org/show_bug.cgi?id=117781
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195437
Signed-off-by: Mikhail Paulyshka <me@mixaill.tk>
commit e4c07b3b66b7d6a24c2fe3b1ddeff5cd9b378b3a upstream.
One version of Lenovo Thinkpad T570 did not use ALC298
(like other Kaby Lake devices). Instead it uses ALC292.
In order to make the Lenovo dock working with that codec
the dock quirk for ALC292 will be used.
Signed-off-by: Dennis Wassenberg <dennis.wassenberg@secunet.com>
commit e312a869cd726c698a75caca0d9e5c22fd3f1534 upstream.
The dock line-out pin (NID 0x17 of ALC3254 codec) on Dell Precision
7520 may route to three different DACs, 0x02, 0x03 and 0x06. The
first two DACS have the volume amp controls while the last one
doesn't. And unfortunately, the auto-parser assigns this pin to DAC3,
resulting in the non-working volume control for the line out.
Fix it by disabling the routing to DAC3 on the corresponding pin.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199029
commit 85981dfd6b0a0fd9ed87ca4a525981b67c21f098 upstream.
The internal mic boost on the T480 is too high. Fix this by applying the
ALC269_FIXUP_LIMIT_INT_MIC_BOOST fixup to the machine to limit the gain.
Signed-off-by: Benjamin Berg <bberg@redhat.com>
commit 71db96ddfa72671bd43cacdcc99ca178d90ba267 upstream.
We've added a quirk to enable the recent Lenovo dock support, where it
overwrites the pin configs of NID 0x17 and 19, not only updating the
pin config cache. It works right after the boot, but the problem is
that the pin configs are occasionally cleared when the machine goes to
PM. Meanwhile the quirk writes the pin configs only at the pre-probe,
so this won't be applied any longer.
For addressing that issue, this patch moves the code to overwrite the
pin configs into HDA_FIXUP_ACT_INIT section so that it's always
applied at both probe and resume time.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195161
Fixes: 61fcf8ece9b6 ("ALSA: hda/realtek - Enable Thinkpad Dock device for ALC298 platform")
commit fdcc968a3b290407bcba9d4c90e2fba6d8d928f1 upstream.
These laptops have a combined jack to attach headsets, the U727 on
the left, the U757 on the right, but a headsets microphone doesn't
work. Using hdajacksensetest I found that pin 0x19 changed the
present state when plugging the headset, in addition to 0x21, but
didn't have the correct configuration (shown as "Not connected").
So this sets the configuration to the same values as the headphone
pin 0x21 except for the device type microphone, which makes it
work correctly. With the patch the configured pins for U727 are
Pin 0x12 (Internal Mic, Mobile-In): present = No
Pin 0x14 (Internal Speaker): present = No
Pin 0x19 (Black Mic, Left side): present = No
Pin 0x1d (Internal Aux): present = No
Pin 0x21 (Black Headphone, Left side): present = No
Signed-off-by: Jan-Marek Glogowski <glogow@fbihome.de>
commit 61fcf8ece9b6b09450250c4ca40cc3b81a96a68d upstream.
Thinkpad Dock device support for ALC298 platform.
It need to use SSID for the quirk table.
Because IdeaPad also has ALC298 platform.
Use verb for the quirk table will confuse.
commit 3f2f7c553d077be6a30cb96b2976a2c940bf5335 upstream.
One of them has the codec of alc256 and the other one has the codec
of alc289.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit e4c9fd10eb21376f44723c40ad12395089251c28 upstream.
There is another Dell XPS 13 variant (SSID 1028:082a) that requires
the existing fixup for reducing the headphone noise.
This patch adds the quirk entry for that.
BugLink: http://lkml.kernel.org/r/CAHXyb9ZCZJzVisuBARa+UORcjRERV8yokez=DP1_5O5isTz0ZA@mail.gmail.com
Reported-and-tested-by: Francisco G. <frangio.1@gmail.com>
commit 285d5ddcffafa5d5e68c586f4c9eaa8b24a2897d upstream.
It has the codec alc256, and add its pin definition to pin quirk
table to let it apply ALC255_FIXUP_DELL1_MIC_NO_PRESENCE.
[ Upstream commit 04d5466a976b096364a39a63ac264c1b3a5f8fa1 ]
This tested patch adds missing initialization for Line-In/Out PINs for
the docking station for HP 820 G2.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
[ Upstream commit 972aa2c708703c21f14eb958b37e82aae2530e44 ]
Setting shutup when the action is HDA_FIXUP_ACT_PRE_PROBE might
not have the desired effect since it could be overridden by
another more generic shutup function. Prevent this by setting
the more specific shutup function on HDA_FIXUP_ACT_PROBE.
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
commit 2d7fe6185722b0817bb345f62ab06b76a7b26542 upstream.
It maybe the typo for ALC700 support patch.
To fix the bit value on this patch.
Fixes: 6fbae35a3170 ("ALSA: hda/realtek - Add support for new codecs ALC700/ALC701/ALC703")
[ Upstream commit 28f1f9b26cee161ddd3985b3eb78e3ffada08dda ]
ALC299 was similar as ALC225.
Add headset support for ALC299.
ALC3271 was for Dell rename.
commit f265788c336979090ac80b9ae173aa817c4fe40d upstream.
We have several Dell laptops which use the codec alc236, the headset
mic can't work on these machines. Following the commit 736f20a70, we
add the pin cfg table to make the headset mic work.
commit 736f20a7060857ff569e9e9586ae6c1204a73e07 upstream.
Add support for ALC236/ALC3204.
Add headset mode support for ALC236/ALC3204.
commit 3f3c371421e601fa93b6cb7fb52da9ad59ec90b4 upstream.
Sony VAIO VPCL14M1R needs the quirk to make the speaker working properly.
Tested-by: Dmitriy <mexx400@yandex.ru>
Signed-off-by: Sergei A. Trusov <sergei.a.trusov@ya.ru>
commit 2f726aec19a9d2c63bec9a8a53a3910ffdcd09f8 upstream.
On this Dell AIO machine, the lineout jack does not work.
We found the pin 0x1a is assigned to lineout on this machine, and in
the past, we applied ALC298_FIXUP_DELL1_MIC_NO_PRESENCE to fix the
heaset-set mic problem for this machine, this fixup will redefine
the pin 0x1a to headphone-mic, as a result the lineout doesn't
work anymore.
After consulting with Dell, they told us this machine doesn't support
microphone via headset jack, so we add a new fixup which only defines
the pin 0x18 as the headset-mic.
[rearranged the fixup insertion position by tiwai in order to make the
merge with other branches easier -- tiwai]
Fixes: 59ec4b57bcae ("ALSA: hda - Fix headset mic detection problem for two dell machines")
commit 3f307834e695f59dac4337a40316bdecfb9d0508 upstream.
A new Dell laptop needs to apply ALC269_FIXUP_DELL1_MIC_NO_PRESENCE to
fix the headset problem, and the pin definiton of this machine is not
in the pin quirk table yet, now adding it to the table.
commit 29693efcea0f38cf40d0055d2401490a4f9bf8be upstream.
On this machine, the micmute button is connected to Line2 of the
codec and the micmute led is connected to GPIO2 of the codec.
After applying this quirk, both hotkey and led work well.
commit 493de342748cc6f52938096f5480cf291da58a0b upstream.
Dell Inspiron 17 7000 Gaming laptop needs a similar quirk like
Inspiron 7599 to support its subwoofer speaker.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=194191
commit 9f1bc2c4c58fcb2d86e0e26437dc8f3a18ac3276 upstream.
The issue is the same as "dd9aa335c880 ALSA: hda/realtek - Can't adjust
speaker's volume on a Dell AIO", the output requires to connect to a node
with Amp-out capability.
Applying the same fixup "ALC298_FIXUP_SPK_VOLUME" can fix the issue.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit c7efff9284dfde95a11aaa811c9d8ec8167f0f6e upstream.
Although the old quirk table showed ASUS X71SL with ALC663 codec being
compatible with asus-mode3 fixup, the bugzilla reporter explained that
asus-model8 fits better for the dual headphone controls. So be it.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=191781
commit 85bcf96caba8b4a7c0805555638629ba3c67ea0c upstream.
ASUS ROG Ranger VIII with ALC1150 codec requires the extra GPIO pin to
up for the front panel. Just use the existing fixup for setting up
the GPIO pins.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=189411
commit 989dbe4a30728c047316ab87e5fa8b609951ce7c upstream.
This group of new pins is not in the pin quirk table yet, adding
them to the pin quirk table to fix the headset-mic problem.
The commit [1a3f099101b8: ALSA: hda - Fix surround output pins for
ASRock B150M mobo] introduced a fixup of pin configs for ASRock
mobos to fix the surround outputs. However, this overrides the pin
configs of the mic pins as if they are outputs-only, effectively
disabling the mic inputs. Of course, it's a regression wrt mic
functionality.
Actually the pins 0x18 and 0x1a don't need to be changed; we just need
to disable the bogus pins 0x14 and 0x15. Then the auto-parser will
pick up mic pins as switchable and assign the surround outputs there.
This patch removes the incorrect pin overrides of NID 0x18 and 0x1a
from the ASRock fixup.
Fixes: 1a3f099101b8 ('ALSA: hda - Fix surround output pins for ASRock...')
Reported-and-tested-by: Vitor Antunes <vitor.hda@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=187431
ASRock B150M Pro4/D3 mobo with ALC892 codec doesn't seem to provide
proper pins for the surround outputs, hence we need to specify the
pincfgs manually with a couple of other corrections.
Reported-and-tested-by: Benjamin Valentin <benpicco@googlemail.com>
They uses the codec ALC255, and have the different pin cfg definition
from the ones in the existing pin quirk table. Now adding them into
the table to fix the problem.
Cc: stable@vger.kernel.org
We have a new Dell laptop model which uses ALC295, the pin definition
is different from the existing ones in the pin quirk table, to fix the
headset mic detection and mic mute led's problem, we need to add the
new pin defintion into the pin quirk table.
We have two new Dell laptop models, they have the same ALC255 pin
definition, but not in the pin quirk table yet, as a result, the
headset microphone can't work. After adding the definition in the
table, the headset microphone works well.
Back-merge from for-linus just to make the further development easier.
One of the laptops has the codec ALC256 on it, applying the
ALC255_FIXUP_DELL1_MIC_NO_PRESENCE can fix the problem, the rest
of laptops have the codec ALC295 on them, they are similar to machines
with ALC225, applying the ALC269_FIXUP_DELL1_MIC_NO_PRESENCE can fix
the problem.
Realtek codec driver expects an implicit rule where either the codec
SSID or the pincfg NID 0x1d contains the some information encoded in
some bits. One of the expected information is there is the
availability of PC beep, and the driver doesn't build up the PC beep
control if this is *supposed* to be disabled there.
Meanwhile, Lenovo doesn't seem to follow this requirement (yes it's
non-standard after all), and the BIOS sets just the normal SSID and
the pincfg values. This resulted in the lack of PC beep on a few
machines, purely with a lucky or unlucky number. It didn't bother
most people, but some people still demand the PC beep, as found in bug
reports.
This patch just adds the fixup chain to Lenovo machines to skip the
SKU checks. Then the beep control will show up in the mixer, and user
can still decide to enable / disable it via the standard mixer
interface.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=156311
The subwoofer on Inspiron 7559 was disabled originally.
Applying a pin fixup to node 0x1b can enable it and make it work.
Old pin: 0x411111f0
New pin: 0x90170151
This patch enables headset microphone on some variants of
Dell Inspiron 5468. (Dell SSID 0x07ad)
BugLink: https://bugs.launchpad.net/bugs/1617900
Signed-off-by: Shrirang Bagul <shrirang.bagul@canonical.com>
MSI Cubi MS-B120 needs the same fixup as the Gigabyte BXBT-2807 for its
mic to work.
They both use a single 3-way jack for both mic and headset with an
ALC283 codec, with the same pins used.
Cc: Daniel Drake <drake@endlessm.com>
Signed-off-by: Anisse Astier <anisse@astier.eu>
One of the machines has ALC255 on it, another one has ALC298 on it.
On the machine with the codec ALC298, it also has the speaker volume
problem, so we add the fixup chained to ALC298_FIXUP_SPK_VOLUME rather
than adding a group of pin definition in the pin quirk table, since
the speak volume problem does not happen on other machines yet.
On Acer Veriton machines, codec with subsystem-id 0x1b0a01b8 the port at
0x15 is configured by default as an Internal Speaker (0x90170120).
However, no physical is speaker installed on-board. This patch adds a quirk
which disables the physical connection on this pin.
BugLink: https://bugs.launchpad.net/bugs/1607647
We have a Dell AIO on which we can't adjust its speaker's volume.
The problem is it is connected to a Audio Output node without Amp-out
capability. To fix it, we change it to be connnected to a node with
Amp-out capability.
Merged 4.8 changes.
We have some Dell laptops which can't detect headset mic, the machines
use the codec ALC225, they have some new pin configuration values,
after adding them in the alc225 pin quirk table, they work well.
This solves the issue that a headphone is not working on the docking
unit.
Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
See: https://bugzilla.redhat.com/show_bug.cgi?id=1349539
See: https://bugzilla.kernel.org/show_bug.cgi?id=120961
