commit e7848163aa2a649d9065f230fadff80dc3519775 upstream.
Cards with identical PCI ids but no AC97 config in EEPROM do not have
the ac97 field initialized. We must check for this case to avoid kernel oops.
Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Fix the num_total_dacs setting for Chaintech AV710. The existing comment
that only PSDOUT0 is connected is correct, but since the card is using
packed AC97 mode to send 6 channels to the codec, num_total_dacs should be
set to 6 and not 2. This allows 6-channel surround to work. Also clarify
a comment regarding the additional WM8728 codec on this card (it's connected
to the SPDIF output and always receives the same data).
Signed-off-by: Robert Hancock <hancockrwd@gmail.com>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Marvin told with a depressed face,
gcc doesn't like both __devinitdata and const in the same line.
So, remove const from all over places now...
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Mark a lot of data as 'const'
Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
Modules: ICE1724 driver,ICE1712 driver
Remove xxx_t typedefs from the PCI ICE1724 driver.
Documentation,ICE1724 driver
Add the support of Chaintech AV-710 to ice1724 driver.
The patch includes the WM-codec initialization fix by
Jaanus Kivistik <jaanus@no.spam.ee>.
Since both AV-710 and AMP Audio2000 have the same SSID, initialize
WM codecs as default for both devices. In case it breaks Audio2000,
you can pass 'model=amp2000' option to avoid WM codec initialization.
infrastructure for it.
Let it rip!
