This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
* support for switching rate in STAC9460 - using set_rate_val of the akm
infrastructure
* listing all STAC9460 registers in proc
* disabling mpu401 device for Prodigy192 - otherwise the currently
flawed mpu401 code hangs kernel when opening the midi device
* removing old unused commented-out code
Signed-off-by: Pavel Hofman <dustin@seznam.cz>
adding i2c busy wait before sending device address to prevent reading
bogus data.
The 'Word Clock Status' control on Delta 1010LT checks the CS8427
error register too strictly and almost always returns 1 (unlocked).
It should check only the lock status bit.
Clean up ctl callbacks of SE-200PCI driver. Also make sure to check
the value ranges.
Check the value ranges in ctl put callbacks properly.
Also fixed the wrong access type to enum elements in aureon.c.
Added the support for Onkyo SE-90PCI and SE-200PCI boards.
Signed-off-by: Shin-ya Okada <sh_okada at d4.dion.ne.jp>
It is possible to have linked substreams that belong to different cards
and/or different drivers. This patch changes some drivers to make sure
that they do not incorrectly try to handle substreams of a different
card.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
There were some places I forgot to replace with snd_ctl_boolean_mono_info.
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
This patch adds the support of mute for front channels of M-Audio
Revolution 7.1 (the DAC AK4381 features a mute bit).
Cannot mix const and __initdata:
sound/pci/ice1712/prodigy192.c:708: error: ak4114_controls causes a section type conflict
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
- always set 256fs in SPDIF master clock mode
- disable deemphasis filter in AK4114 for Prodigy192
Fixes:
* correct card specific ice1724 initialization
* working IEC958 output of the card
* renamed capture controls
New features:
* analog input switch (line-in/mic)
* optional ak4114 based MI/ODI/O card detection & support: IEC958 input,
digital input switch (toslink/coax)
Unresolved issues
* Analog and digital input enums are listed on playback panel of alsamixer,
I do not know how to push them onto the capture one.
Added some comments regarding naming of PCM streams on vt172x chip.
Call snd_ak4114_build() in juli support code to build proper mixer
elements for SPDIF inputs.
ak4114 code may trigger Oops when the parameters are changed without
call of snd_ak4114_build(). Now it checks the existence of kctl
element, and the workq is triggered after building the necessary
kcontrols.
Also, did some code clean up.
ap192_4wire_start() in ice1712/revo.c returns unsigned char
whereas it should return unsigned int.
Marvin told with a depressed face,
gcc doesn't like both __devinitdata and const in the same line.
So, remove const from all over places now...
CC [M] sound/pci/ice1712/ice1712.o
sound/pci/ice1712/ice1712.c:290: error: snd_ice1712_mixer_digmix_route_ac97 causes a section type conflict
sound/pci/ice1712/ice1712.c:1630: error: snd_ice1712_eeprom causes a section type conflict
Gcc like its __devinitdata readable not const, it seems. An alternative
fix would be to remove the __devinitdata attribute but that would result
in slight runtime bloat.
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup.
Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(),
are removed.
Fix the misspellings of "propogate", "writting" and (oh, the shame
:-) "kenrel" in the source tree.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Mark TLV data as 'const'
Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
Make data passed to ak4xxx_create 'const'.
Mark a lot of data as 'const'
Reorganize EEPROM data (in C99 style).
This patch adds the support of the ESI Waveterminal 192M soundcard
to the ice1724 familly ALSA driver.
It's a semi-professionnal soundcard for home studio : many I/O and
a quality of sound is good, better than consumer cards, but less
musical than professional cards.
It use a Via Envy24ht chipset as ice1724 soundcard, Sigmatel
stac9640 ADC/DAC for the analog I/O as Prodigy192, and Atmel ak4114
for S/PDIF as ESI Julia.
Is working : the 8 analog outputs, the analog inputs 1&2, the mic
input 1, the coaxial & optical digital outputs.
Signed-off-by: Clement Guedez <klem.dev@gmail.com>
This patch supports Audiotrack 7.1 XT.
7.1XT is almost same hardware as 7.1LT. so using 7.1 LT's code.
Signed-off-by: Toshimune Konno <heitouk@nifty.com>
Added the (experimental) support of M-Audio Audiophile 192 board.
Currently, the analog and the digital playbacks seem working fine.
The inputs seem not working as far as I've tested yet.
Enable the analog loopback of the Revolution 5.1 card.
This patch adds support for the PT2258 volume controller and modifies
the Revolution 5.1 driver to make use of this facility. This allows
to control the analog loopback of the card.
Signed-off-by: Jochen Voss <voss@seehuhn.de>
Enable capture from line-in and CD on the Revolution 5.1 card.
This patch adds support for switching between the 5 input channels of
the AK5365 ADC and modifies the Revolution 5.1 driver to make use of
this facility. Previously the capture channel was fixed to channel 0
(microphone on the Revolution 5.1 card).
Fix IRQ flags for PCI devices.
The shared IRQs for PCI devices shouldn't be allocated with
IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't
be used.
The patch removes unnecessary cast in request_irq and free_irq,
too.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Remove IPGA volume controls and merge the IPGA range to ADC volume
controls. These two volumes are not really independent but connected
simply in different ranges 0-0x7f and 0x80-max. It doesn't make sense
to provide two controls.
Since both 0x7f and 0x80 specify 0dB, a hack is needed for IPGA range
to skip 0x80 (increment one) for such controls.
Added the dB scale information to each board support code of ice1724 driver.
Added the dB scale information for native digital volumes of ice1712 driver.
- Clean up the code in AK4xxx-ADDA i2c code.
- Fix capture gain controls for AK5365
- Changed the static table for DAC/ADC mixer labels to use
structs
- Implemented TLV entries for each AK codec
The volumes in AK4524, AK4528 and AK5365 are corrected with
a table to be suitable for dB conversion.
Complete the AK5365 support.
This adds a boolean control to toggle the soft mute feature of the
AK5365 chip.
Enable capture support for the M-Audio Revolution 5.1 card,
by registering the ADC with ALSA.
Fixed 'section mismatch' errors in ALSA PCI drivers:
- removed invalid __devinitdata from pci id tables
- fix/remove __devinit of functions called in suspend/resume
Fix the driver string name for Terratec Aureon 7.1 Universe
to fit in 15 letters to avoid the overflow.
This patch adds stereo controls to revo cards by making the ak4xxx
driver mixers configurable from the card driver.
Signed-off-by: Jani Alinikula <janialinikula@gmail.com>
To permit use, in ice1712, of the mpu401 info flags recently added to
mpu401_uart, adds info_flags in snd_ice1712_card_info so that additional
flags can be set, if desired. 'MPU401_INFO_INTEGRATED' is always set with
the ice1712. The flags are passed on to snd_mpu401_uart_new().
_INFO_OUTPUT is set for DMX6fire mpu2.
Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk>
This patch adds support for useable front audio channels,
user controllable headphone channel and optical output.
Signed-off-by: Matt Taylor <mwtaylor@gmail.com>
Consumer AC97 is not used by the Terratec DMX6fire, but eeprom bit indicates
it is; change the stored value to disable failing consumer mode.
Change the 5th argument of snd_mpu401_uart_new() to bit flags
instead of a boolean. The argument takes bits that consist of
MPU401_INFO_XXX flags.
The callers that used the value 1 there are replaced with
MPU401_INFO_INTEGRATED.
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
