commit 27c3afe6e1cf129faac90405121203962da08ff4 upstream.
BugLink: https://bugs.launchpad.net/bugs/930842
The reporter states that audio is inaudible by default without muting
'External Amplifier'. Add a quirk to handle his SSID so that changing
the control is not necessary.
Reported-and-tested-by: Benjamin Carlson <elderbubba0810@gmail.com>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
controls
BugLink: https://launchpad.net/bugs/669279
The original reporter states: "The Master mixer does not change the
volume from the headphone output (which is affected by the headphone
mixer). Instead it only seems to control the on-board speaker volume.
This confuses PulseAudio greatly as the Master channel is merged into
the volume mix."
Fix this symptom by applying the hp_only quirk for the reporter's SSID.
The fix is applicable to all stable kernels.
Reported-and-tested-by: Ben Gamari <bgamari@gmail.com>
Cc: <stable@kernel.org> [2.6.32+]
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
BugLink: https://bugs.launchpad.net/bugs/619439
This ThinkPad model needs External Amplifier muted for audible playback,
so set the inv_eapd quirk for it.
Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk>
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
BugLink: https://bugs.launchpad.net/bugs/487884
This Gateway model needs External Amplifier muted for audible playback,
BugLink: https://bugs.launchpad.net/bugs/474972
This Sony model needs External Amplifier muted for audible playback, so
make sure we set the inv_eapd quirk.
BugLink: https://bugs.launchpad.net/bugs/410933
This Sony VAIO model also needs External Amplifier unmuted for audible
playback, so make sure we set the inv_eapd quirk.
This Sony VAIO model needs External Amplifier unmuted for audible
The PCM pointer callback sometimes returns invalid positions and this
screws up the hw_ptr updater in PCM core. Especially since now the
jiffies check is optional with xrun_debug, the invalid position is
handled as is, and causes serious sound skips, etc.
This patch simplifies the position-fix strategy in intel8x0 to be more
robust:
- just falls back to the last position if bogus position is detected
- another sanity check for the backward move of the position due to
a race of register update and the base-index update
This patch is applicable also for 2.6.30.
Tested-by: David Miller <davem@davemloft.net>
* commit 'alsa/master':
[ALSA] intel8x0: another attempt to fix ac97_clock measure routine
[ALSA] ac97_codec: increase timeout for analog subsections
Appearently, a big delay ~300ms is required before hw is settled and ready
to transfer samples on some hardware variants. Also, return back
"clocking to 48000Hz" message when something fails.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Subject says it all. Briefly, use hp_only for another Dell Inspiron 8600.
Reference: Ubuntu #41015 (https://launchpad.net/bugs/41015)
Signed-off-by: Daniel T Chen <seven.steps@gmail.com>
While cleaning up quirks, I noticed that there is a duplicated quirk for
the SSID 0x103c0934. Looking back through the bug reports, I've concluded
that there is only one necessary quirk (hp_mute_led), so this patch
removes the conflicting one.
Reference: Ubuntu #44066 (https://launchpad.net/bugs/44066)
It seems that on some hardware platforms, the first measurement is wrong.
This patch adds second measurement to this case.
Also add a little code cleanup.
It seems that the zero value from the PICB (position in current buffer)
register is not reliable. Use jiffies to correct returned value
from the ring buffer pointer callback.
- use monotonic posix clock to measure time
- try to avoid reading zero from PICB (position in current buffer) register
- show also measured samples
- when clock is near 41000 or 44100, use exactly these values
(they appears to be reference clocks for hardware manufacturers)
With a postfix decrement time will reach -1 rather than 0,
so the warning will not be issued.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Check in a quirk list if it should do cold reset when AC97 power saving
is enabled. Some devices do not resume properly when cold reset,
although power saving works OK.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Convert from snd_card_new() to the new snd_card_create() function
in sound/pci/*.
alsa-info.sh output at:
https://bugzilla.redhat.com/show_bug.cgi?id=441087#c49
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Fujitsu Lifebook P7010 requires ac97_quirk=hp_only.
http://bugzilla.kernel.org/show_bug.cgi?id=9100
The AC97 clock detection is not accurate in some cases. This patch adds
an initial whitelist for audio devices gathered from RedHat's bugzilla:
As a side effect, white-listing might speedup kernel booting (AC97 clock
measuring code is not activated).
sound/pci: supported cards update
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Kill snd_assert() in sound/pci/*, either removed or replaced with
if () with snd_BUG_ON().
free_irq() calls synchronize_irq() for you, so there is no need for
drivers to manually do the same thing (again). Thus, calls where
sync-irq immediately precedes free-irq can be simplified.
However, during this audit several bugs were noticed, where free-irq is
preceded by a "irq >= 0" check... but the sync-irq call is not covered
by the same check.
So, where sync-irq could not be eliminated completely, the missing check
was added.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Added the support of 8 channel sound for codecs that are known to work.
So far, only ALC850 is marked as a 8ch-support codec.
This fix is a modified version of the patch on ALSA BTS#2097 by
Martin Ellis:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=2097
Added the ac97_quirk hp_only for Compaq Deskpro EN.
Added ac97_quirk=hp-only for Acer Travelmate 2310.
ALSA bug#3656
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3656
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Continue is not needed at the bottom of a loop.
The semantic patch implementing this change is as follows:
for (...;...;...) {
if (...) {
- continue;
The set_memory_* and set_pages_* family of API's currently requires the
callers to do a global tlb flush after the function call; forgetting this is
a very nasty deathtrap. This patch moves the global tlb flush into
each of the callers
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch converts various users of change_page_attr() to the new,
more intent driven set_page_*/set_memory_* API set.
Included is a patch against current alsa-kernel hg tip adding
quirks that Ubuntu Dapper/Edgy/Feisty contains.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
When intel8x0 driver is loaded in the crash kernel, it gets Oops
occasionally. This is because the irq handler gets called before
the proper hardware initialization. Now defer it after
snd_intel8x0_chip_init().
(reference: http://lkml.org/lkml/2007/3/5/252)
Fixed Oops at crash kernel from intel8x0 driver that is triggered
from interrupt handler. Proper irqsave version seems needed for
kexec/kdump.
Fixed the mute speaker problem after S2RAM on some laptops:
http://bugme.osdl.org/show_bug.cgi?id=6181
Signed-off-by: Tommi Kyntola <tommi.kyntola@ray.fi>
Added spdif_aclink module option to specify whether the board
has SPDIF over AC-link or a direct connection from the controller
chip.
NForce and ICH4 (or newer) boards may be equipped with SPDIF
through AC97 codec. In such a case, SPDIF should be handled
as if the old ICH style (the same slot for analog and digital).
A quirk list is added to detect this automatically for known
hardwares.
Corresponds to ALSA bug#2637.
Don't enable power-saving mode on drivers that don't support
it. The supporting drivers set AC97_SCAP_POWER_SAVE to scaps
at creation of ac97 instance.
Currently enable on the following drivers: intel8x0, intel8x0m,
atiixp, atiixp-modem, via82xx and via82xx-modem.
Also, a bit clean up of power-saving stuff:
- Don't create an own workq
- Remove superfluous ifdefs
