intel8x0 driver has the inside_vm check for skipping a buggy hardware
workaround in the PCM pointer callback in the commit [228cf79376f1:
ALSA: intel8x0: Improve performance in virtual environment]. This was
originally applied to all devices on known VMs, but the code was
switched to use the PCI ID matching for applying to only known
devices (KVM and Parallels), in order to avoid applying wrongly to
VT-d and other such cases, in the commit [7fb4f392bd27: ALSA:
intel8x0: improve virtual environment detection].
Meanwhile, the original VM check was kept even after switching to the
PCI ID matching. It was partly because we weren't 100% sure whether
we had covered all well, and partly because this would help
identifying the issue once when a user of another VM hit the same
problem or a regression. Currently the VM check is used only for
showing the kernel message that the VM-optimization isn't applied, and
the VM check itself doesn't change the actual driver behavior at all.
Despite the relatively safe driver behavior, the code caught attention
of developers badly and brought many confusion / misunderstanding.
Since we've got neither regression nor enhancement report for other
VMs for five years long, it's likely safe to drop this superfluous VM
check now.
The module option is still kept, so if a user still needs to adjust,
it can be applied as was.
Acked-by: Konstantin Ozerkov <kozerkov@parallels.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"After a heavy storm by syzkaller in 4.5 cycle, we have relatively few
changes in the core at this time while a lot of changes are found in
the driver side, unsurprisingly. Below are some highlights:
ALSA core:
- A few more hardening in ALSA timer codes
- An extension of sequencer API for advertising the card / pid
- Small fixes in compress-offload and jack layers
HD-audio:
- Dynamic PCM assignment in HDMI/DP codec; preparation for upcoming
DP-MST support
- Lots of code refactoring for sharing with ASoC SKL driver
- Regression fixes for Intel HDMI/DP
- Fixups for CX20724 codec, Lenovo AiO
USB-audio:
- Add quirk_alias option to make quirk debugging easier
- Fixes for possible Oops by malformed firmware
Firewire:
- Add support for FW-1804 in tascam driver
- Improvements / changes in card registration, multi stream handling,
etc for DICE
ASoC:
- Enhancements of still ongoing topology API
- Lots of commits for Intel Skylake support including HDMI support
- A few Intel Atom driver updates for recent devices
- Lots of improvements to the Renesas drivers
- Capture support for Qualcomm drivers
- Support for TI DaVinci DRA7xxx devices
- New machine drivers for Freescale systems with Cirrus CODECs,
Mediatek systems with RT5650 CODECs
- New CPU drivers for Allwinner S/PDIF controllers
- New CODEC drivers for Maxim MAX9867 and MAX98926 and Realtek RT5514"
* tag 'sound-4.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (291 commits)
ALSA: hda - Fix mutex deadlock at HDMI/DP hotplug
ALSA: ctl: change return value in compatibility layer so that it's the same value in core implementation
ALSA: mixart: silence an uninitialized variable warning
ALSA: usb-audio: Add sanity checks for endpoint accesses
ALSA: usb-audio: Minor code cleanup in create_fixed_stream_quirk()
ALSA: usb-audio: Fix NULL dereference in create_fixed_stream_quirk()
ALSA: hda - Limit i915 HDMI binding only for HSW and later
ALSA: hda - Fix unconditional GPIO toggle via automute
ALSA: mixart: silence unitialized variable warnings
ALSA: hda - Fixes double fault in nvhdmi_chmap_cea_alloc_validate_get_type
ALSA: intel8x0: Add clock quirk entry for AD1981B on IBM ThinkPad X41.
ALSA: hda - Add new GPU codec ID 0x10de0082 to snd-hda
ASoC: rsnd: add simplified module explanation
ASoC: hdac_hdmi: Add broxton device ID
ASoC: Intel: Bxtn: Add Broxton PCI ID
ASoC: Intel: Skylake: Move Skylake dsp ops & loader ops
ASoC: Intel: add dmabuffer to common sst_dsp
ASoC: Intel: Skylake: Unstatify skl_dsp_enable_core
ASoC: Intel: Skylake: Fix whitepsace issues
ASoC: Intel: Skylake: Move module id defines
The clock measurement on the AC'97 audio card found in the IBM ThinkPad X41
will often fail, so add a quirk entry to fix it.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=441087
Cc: <stable@vger.kernel.org>
Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Introduce PCI_VENDOR/PCI_SUBVENDOR/PCI_SUBDEVICE defines to replace the
constants scattered in the kernel already used to detect QEMU.
They are defined in the QEMU codebase per docs/specs/pci-ids.txt.
Signed-off-by: Robin H. Johnson <robbat2@gentoo.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Reviewed-by: Gerd Hoffmann <kraxel@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
The compiler can optimize the unused code away, so we can drop
ifdefs.
DEVICE_ALI previously would jump to port_inited after calling
pci_iomap(), bypassing the check for bmaddr being NULL.
Use const to reduce data by ~3Kb.
Nowadays it's recommended. Replace all in a shot.
This is a similar cleanup like the commit [3db084fd0af5: ALSA: fm801:
PCI core handles power state for us].
Since pci_set_power_state(), pci_save_state() and pci_restore_state()
are already done in the PCI core side, so we don't need to it doubly.
Also, pci_enable_device(), pci_disable_device() and pci_set_master()
calls in PM callbacks are superfluous nowadays, too, so get rid of
them as well.
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
do_posix_clock_monotonic_gettime() is a leftover from the initial
posix timer implementation which maps to ktime_get_ts() and returns
the monotonic time in a timespec.
Use ktime based ktime_get() and use the ktime_delta_us() function to
calculate the delta instead of open coding the timespec math.
Convert with dev_err() and co from snd_printk(), etc.
Also remove superfluous snd_card_set_dev() calls.
The playback chmap for multi-channel stream hasn't been properly added
to intel8x0 devices due to the wrong condition.
Reported-by: Raymond Yau <superquad.vortex2@gmail.com>
As drvdata is cleared to NULL at probe failure or at removal by the
driver core, we don't have to call pci_set_drvdata(pci, NULL) any
longer in each driver.
The only remaining pci_set_drvdata(NULL) is in azx_firmware_cb() in
hda_intel.c. Since this function itself releases the card instance,
we need to clear drvdata here as well, so that it won't be released
doubly in the remove callback.
Because currently snd_printd() and snd_printdd() macros are expanded
to empty when CONFIG_SND_DEBUG=n, a compile warning like below
appears sometimes, and we had to covert it by ugly ifdefs:
sound/pci/hda/patch_sigmatel.c: In function ‘stac92hd71bxx_fixup_hp’:
sound/pci/hda/patch_sigmatel.c:2434:24: warning: unused variable ‘spec’ [-Wunused-variable]
For "fixing" these issues better, this patch replaces snd_printd() and
snd_printdd() definitions with empty inline functions instead of
macros. This should have the same effect but shut up warnings like
above.
But since we had already put ifdefs, changing to inline functions
would trigger compile errors. So, such ifdefs is removed in this
patch.
In addition, snd_pci_quirk name field is defined only when
CONFIG_SND_DEBUG_VERBOSE is set, and the reference to it in
snd_printdd() argument triggers the build errors, too. For avoiding
these errors, introduce a new macro snd_pci_quirk_name() that is
defined no matter how the debug option is set.
Reported-by: Stratos Karafotis <stratosk@semaphore.gr>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r1@
statement S;
position p,p1;
S@p1;@p
@script:python r2@
p << r1.p;
p1 << r1.p1;
if p[0].line != p1[0].line_end:
cocci.include_match(False)
position r1.p;
-;@p
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Just set the channel maps depending on the hardware availability.
Otherwise we may get compile warnings due to unused functions.
Straightforward conversion to the new pm_ops from the legacy
suspend/resume ops.
Since we change vx222, vx_core and vxpocket have to be converted,
too.
BugLink: https://bugs.launchpad.net/bugs/930842
The reporter states that audio is inaudible by default without muting
'External Amplifier'. Add a quirk to handle his SSID so that changing
the control is not necessary.
Reported-and-tested-by: Benjamin Carlson <elderbubba0810@gmail.com>
Cc: <stable@kernel.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
For historical reasons, we allow module_param(bool) to take an int (or
an unsigned int). That's going away.
A few drivers really want an int: they set it to -1 and a parameter
will set it to 0 or 1. This sucks: reading them from sysfs will give
'Y' for both -1 and 1, but if we change it to an int, then the users
might be broken (if they did "param" instead of "param=1").
Use a new 'bint' parser for them.
(ntfs has a different problem: it needs an int for debug_msgs because
it's also exposed via sysctl.)
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Hoang-Nam Nguyen <hnguyen@de.ibm.com>
Cc: Christoph Raisch <raisch@de.ibm.com>
Cc: Roland Dreier <roland@kernel.org>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: linux390@de.ibm.com
Cc: Anton Altaparmakov <anton@tuxera.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: lm-sensors@lm-sensors.org
Cc: linux-rdma@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: alsa-devel@alsa-project.org
Acked-by: Takashi Iwai <tiwai@suse.de> (For the sound part)
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> (For the hwmon driver)
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Detection code improved by PCI SSID usage. VM optimization
now enabled only for known devcices (skip host devices forwarded
to VM by VT-d or same kind of technology).
For debug/troubleshooting purposes optimization can be
forced (on/off) by module parameter: "inside_vm" (boolean).
Known devices (PCI SSID):
1af4:1100: Reserved for KVM devices. Note this is not yet
implemented for KVM's ICH/AC'97 emulation.
1ab8:xxxx: Parallels ICH/AC'97 emulated sound.
[ fixed a minor coding-style issue by tiwai]
Signed-off-by: Konstantin Ozerkov <kozerkov@parallels.com>
Signed-off-by: Denis V. Lunev <den@openvz.org>
This is refactoring patch: preparation for add improved detection code.
Now all detection code placed in one place.
The recently merged 228cf79376f1 looks a bit hackish while it is not.
The change was quite simple. In a virtualized environment the
patch unhacks old kludge introduced for old broken AC97 hardware.
This patch adds proper comment to "unkludge" code.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
<linux/kvm_para.h> should be included instead of <asm/...>
The implicit presence of module.h lured several users into
incorrectly thinking that they only needed/used modparam.h
but once we clean up the module.h presence, these will show
up as build failures, so fix 'em now.
v3: detection code is x86 and KVM specific, hide it under ifdef
v2: add detection for virtual environments (KVM and Parallels)
This patch is intended to improve performance in virtualized environments
like Parallels Desktop or KVM/VirtualBox/QEMU (virtual ICH/AC97 audio).
I/O access is very time-expensive operation in virtual world: VCPU
can be rescheduled and in the worst case we get more than 10ms delay on
each I/O access.
In the virtual environment loop exit rule
(old_civ == current_civ && old_picb == current_picb) is never satisfied,
because old_picb is never the same as current_picb due to delay inspired
by reading current_civ. As a result loop ended by timeout and we get 10x
more I/O operations.
Experimental data from Prallels Desktop 7, RHEL6 guest (I/O ops per
second):
Original code:
In Port Counter Callback
f014 41550 fffff00000179d00 ac97_bm_read_civ+0x000
f018 41387 fffff0000017a580 ac97_bm_read_picb+0x000
With patch:
f014 4090 fffff00000179d00 ac97_bm_read_civ+0x000
f018 1964 fffff0000017a580 ac97_bm_read_picb+0x000
BugLink: https://bugs.launchpad.net/bugs/774895
The original reporter states that his volume keys do not change the
desired Master and PCM mixer elements together, so apply the hp+mute led
quirk for his PCI SSID.
Reported-by: Jeffrey Finkelstein
The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
controls
BugLink: https://launchpad.net/bugs/669279
The original reporter states: "The Master mixer does not change the
volume from the headphone output (which is affected by the headphone
mixer). Instead it only seems to control the on-board speaker volume.
This confuses PulseAudio greatly as the Master channel is merged into
the volume mix."
Fix this symptom by applying the hp_only quirk for the reporter's SSID.
The fix is applicable to all stable kernels.
Reported-and-tested-by: Ben Gamari <bgamari@gmail.com>
Cc: <stable@kernel.org> [2.6.32+]
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
BugLink: https://bugs.launchpad.net/bugs/619439
This ThinkPad model needs External Amplifier muted for audible playback,
so set the inv_eapd quirk for it.
Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk>
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
BugLink: https://bugs.launchpad.net/bugs/487884
This Gateway model needs External Amplifier muted for audible playback,
BugLink: https://bugs.launchpad.net/bugs/474972
This Sony model needs External Amplifier muted for audible playback, so
make sure we set the inv_eapd quirk.
BugLink: https://bugs.launchpad.net/bugs/410933
This Sony VAIO model also needs External Amplifier unmuted for audible
playback, so make sure we set the inv_eapd quirk.
This Sony VAIO model needs External Amplifier unmuted for audible
The PCM pointer callback sometimes returns invalid positions and this
screws up the hw_ptr updater in PCM core. Especially since now the
jiffies check is optional with xrun_debug, the invalid position is
handled as is, and causes serious sound skips, etc.
This patch simplifies the position-fix strategy in intel8x0 to be more
robust:
- just falls back to the last position if bogus position is detected
- another sanity check for the backward move of the position due to
a race of register update and the base-index update
This patch is applicable also for 2.6.30.
Tested-by: David Miller <davem@davemloft.net>
* commit 'alsa/master':
[ALSA] intel8x0: another attempt to fix ac97_clock measure routine
[ALSA] ac97_codec: increase timeout for analog subsections
Appearently, a big delay ~300ms is required before hw is settled and ready
to transfer samples on some hardware variants. Also, return back
"clocking to 48000Hz" message when something fails.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Subject says it all. Briefly, use hp_only for another Dell Inspiron 8600.
Reference: Ubuntu #41015 (https://launchpad.net/bugs/41015)
Signed-off-by: Daniel T Chen <seven.steps@gmail.com>
