This fixes the following warning, that is seen with gcc 5.1:
warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses].
Signed-off-by: Tomer Barletz <barletz@gmail.com>
Make it possible for cards to have three stereo analog input pairs.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Cards without S/PDIF output do not need those controls.
When the user switches the output from stereo to multichannel
or vice versa, the driver needs to update the channel routing.
Instead of creating additional subroutines, I better export existing
oxygen_update_dac_routing symbol from the oxygen mixer
and call this function. It calls model.adjust_dac_routing()
and my function does the work.
Signed-off-by: Roman Volkov <v1ron@mail.ru>
The driver accidentally exchanged the left/right fields for stereo AC'97
mixer registers. This affected only the aux and CD inputs because the
line input bypasses the AC'97 codec and the mic input is mono; cards
without AC'97 (Xonar DS/DG/HDAV Slim, HG2PCI, HiFier) were not affected.
Reported-and-tested-by: Abby Cedar <abbycedar@yahoo.com.au>
Cc: 2.6.31+ <stable@vger.kernel.org>
This card uses separate I2S outputs for the front speakers and
headphones, and reverses the order of the three speaker outputs.
To work around this, add a model-specific callback to adjust the
controller's playback routing.
Add a mixer control to prevent capturing S/PDIF samples that are not
marked as valid (non-audio or corrupted samples).
Introduce the helper function snd_ctl_enum_info() to fill out the
elem_info fields for an enumerated control.
Add experimental support for the Asus Xonar DG sound card.
For cards like the Xonar HDAV1.3, differentiate between the number of
PCM channels that can be played and the number of channels whose volume
can be adjusted.
The "Front Panel" switch on the Xonar D1/DX actually switches only the
output direction, so mark it appropriately.
The front panel microphone is controlled by the FMIC2MIC bit of the
CM9780. It was unconditionally enabled on the D1/DX and never set on
the ST(X); add a control for it. Selecting the front panel microphone
as source does not actually disable the microphone jack, but this is
bug-compatible with the Windows driver, and users rely on it.
The input monitor half volume bit results in a factor of 0.5, so the
minimum scale value should be -6 dB.
There are more models without a CD input than with one, so handle this
explicitly with a device_config flag to avoid having to define a control
filter callback to filter it out.
Insert "Playback" into the input monitor control names to prevent
alsa-lib from treating these controls as global controls.
Add the possibility to route a mix of the two channels of stereo data to
the center and LFE outputs. This is implemented only for models where
the DACs support this, i.e., for the Xonar D1 and DX.
On card models with two-channel outputs, the base driver can
automatically disable the upmixing control so that the model
drivers do not need to do this.
The microphone input and its volume register have only one channel, so
we have to make the corresponding mixer control a mono control.
Rename the pcm_dev_cfg field to device_config because there will be
additional flags that do not describe PCM devices.
Put a copy of the model structure into the chip structure so that model-
specific drivers can modify it depending on a particular device
instance.
When setting the SPDIF channel status sample rate field, use the
recently defined symbols instead of magic numbers.
The Xonar DX does not have CD Capture controls, so we have to check that
a control actually exists before muting it.
Cc: <stable@kernel.org>
Check that model->control_filter is set before trying to call it.
Add a pointer for DAC volume TLV data to the model structure so that the
model driver do not need to manually assign it in their control filter.
Add fields for the DAC volume limits to the module structure so that
model drivers do not need to install their own control info handlers.
If the card model does not have a digital input or an AC97 codec,
disable the respective interrupt and mixer controls.
When selecting the capture source on the Xonar DX, the input jack must
be routed to either the line input or the microphone input by setting a
GPIO pin. This requires an additional callback so that the model driver
can hook into the toggling of AC97 switches.
On C-Media cards, the GPIO pin 0 of the CM9780 must be handled exactly
like on Xonar cards, so move the Xonar code to the common mixer code.
When specifying which PCM devices to use, model drivers now use flags
that also specify the routing between PCM devices and DMA channels
instead of just DMA channel bits. This simplifies some code that checks
for these flags.
Add controls to enable monitoring of the analog and digital inputs.
To allow monitoring after loading the driver when nothing has been
played back or recorded yet, the I2S input and outputs are initialized
to a valid configuration.
Add mixer controls for the front panel AC97 codec.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Move the line input switching code to the Virtuoso driver because only
the Xonar cards bypass the analog mixer for line input.
Add a driver for the MediaTek/TempoTec HiFier Fantasia sound card.
Add a field to struct oxygen_model to allow model drivers for cards with
less than eight output channels.
Add a mixer control for the SPDIF loopback function.
Actually use the template that was maybe changed by the control filter
instead of the original one.
Add symbol definitions for the various codecs and GPIO pins.
Replace some magic numbers with register symbols.
The default playback routing must be 0xe4, not 0xe1; the front and
surround DACs were exchanged.
Allow the models to modify mixer controls before they are added to the
card.
Only initialize and create mixer controls for the first AC97 codec when
one has actually been detected.
Rename the 'PCM Playback Volume'/'Switch' mixer controls to 'Master'.
The line input cannot be mixed with the other inputs, so we have to mute
the other input switches when it is selected.
Use an array for the pointers to known controls so that it is easier to
add more.
Do not exchange the surround and back jacks except when in 7.1 mode
where the surround jack is not rear but side.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Add the snd-oxygen driver for the C-Media CMI8788 (Oxygen) chip, used on
the Asound A-8788, AuzenTech X-Meridian, Bgears b-Enspirer,
Club3D Theatron DTS, HT-Omega Claro, Razer Barracuda AC-1,
Sondigo Inferno, and TempoTec HIFIER sound cards.
