path: root/sound/pci/pcxhr
2008-04-24[ALSA] sound/pci/pcxhr/pcxhr.c: fix warningsAndrew Morton
sparc64: sound/pci/pcxhr/pcxhr.c: In function `pcxhr_update_r_buffer': sound/pci/pcxhr/pcxhr.c:459: warning: cast to pointer from integer of different size sound/pci/pcxhr/pcxhr.c: In function `pcxhr_trigger_tasklet': sound/pci/pcxhr/pcxhr.c:628: warning: long int format, different type arg (arg 4) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/pci/pcxhr/pcxhr_core.c: fix printk warningAndrew Morton
sound/pci/pcxhr/pcxhr_core.c: In function `pcxhr_set_pipe_state': sound/pci/pcxhr/pcxhr_core.c:899: warning: long int format, different type arg (arg 4) suseconds_t is int on sparc64. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound/pci: remove unused variableJulia Lawall
The variable is_capture is initialized but never used otherwise. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; identifier i; constant C; @@ ( extern T i; | - T i; <+... when != i - i = C; ...+> ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: pcxhr_core.c fix shadowed variable warningHarvey Harrison
Inner loop redeclares err with u32 rather than int, stupid fix here is to change the inner err to err2. sound/pci/pcxhr/pcxhr_core.c:1008:8: warning: symbol 'err' shadows an earlier one sound/pci/pcxhr/pcxhr_core.c:983:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] pci - check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in the rest of PCI drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] pcxhr - Fix dB level informationTakashi Iwai
Some dB level information is wrong in pcxhr driver according to the datasheet. Fixed now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] pcxhr - Fix trigger start with non-linked streamsTakashi Iwai
The non-linked streams couldn't be started properly due to missing setting of stream->status. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] remove incorrect usage of SNDRV_PCM_INFO_SYNC_START and ↵Clemens Ladisch
snd_pcm_set_sync() Set the SNDRV_PCM_INFO_SYNC_START flag and the substream's sync ID (only) if the substream actually can be linked to another one. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] check for linked substreams of different cardsClemens Ladisch
It is possible to have linked substreams that belong to different cards and/or different drivers. This patch changes some drivers to make sure that they do not incorrectly try to handle substreams of a different card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] add MODULE_FIRMWARE entriesClemens Ladisch
Add MODULE_FIRMWARE() entries, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] pcxhr - Minor optimization in trigger callbackTakashi Iwai
Minor optimization in trigger start callback. This fixes a nasty compile warning, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Add dB scale information to pcxhr driverTakashi Iwai
Added the dB scale information to pcxhr driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] pcxhr - Fix a compiler warning on 64bit architecturesHenrik Kretzschmar
The patch fixes a conpile warning on 64bit architectures, caused by different sizes of size_t . Since size_t is unsigned I permited myself to cange the format, too. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] sound/pci/: remove duplicate #include'sAdrian Bunk
There's no reason for #include'ing linux/dma-mapping.h more than once. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] pcxhr - Fix the crash with REV01 boardMarkus Bollinger
On a new board revision for pcxhr boards, the PCXHR_CHIPSC_GPI_USERI bit is no more supported. The cards concerned have a REV01 in their PCI ID. As the current driver tests this bit and does not load the first Xilinx binary when it's 1, the card will crash on Xilinx access over PCI. (the PCI will freeze ....) The fix (fix to version 1.0.11rc4) works for both REV00 and REV01 cards. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] Intruduce DMA_28BIT_MASKTobias Klauser
This patch introduces the DMA_28BIT_MASK constant in dma-mapping.h ALSA drivers using this mask are changed to use the new constant. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] semaphore -> mutex (PCI part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] pcxhr - Suppress debug messagesTakashi Iwai
Modules: Digigram PCXHR driver Suppress debug messages. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] pcxhr - Fix printk warningAndrew Morton
Modules: Digigram PCXHR driver sound/pci/pcxhr/pcxhr.c: In function 'pcxhr_update_r_buffer': sound/pci/pcxhr/pcxhr.c:460: warning: unsigned int format, different type arg (arg 7) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] pcxhr - Fix the sample rate changesTakashi Iwai
Modules: Digigram PCXHR driver Fix the hardware set up when the sample rate is changed multiple times. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Add PCXHR driverMarkus Bollinger
Modules: Documentation,PCI drivers,Digigram PCXHR driver Add Digigram PCXHR driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
