path: root/sound/pci/rme9652
2011-08-05ALSA: hdspm - Fix uninitialized compile warningsTakashi Iwai
Put the exception checks for io_type switch() for possible mistakes in future. Also this shuts up annoying compile warnings. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-29ALSA: hdspm - Add firmware revision 0xcc for RME MADIAdrian Knoth
Apparently, there are multiple old firmware revisions in the wild for the PCI RME MADI cards. Just add them to the list of supported devices and treat them like their modern counterparts. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-29ALSA: hdspm - Fix reported external sample rate on RME MADI and MADIfaceAdrian Knoth
In slave mode, the card can only detect the base frequency (32..48kHz) on the MADI link (exception: 96k frames), so the real external sample rate is this base frequency multiplied by 1, 2 or 4 depending on the speed mode. This patch enables 64..192kHz sample rates in clock slave mode, which failed before due to an alleged sample rate mismatch between the MADI link (e.g., 48kHz) and the application in DS/QS mode (e.g., 96kHz, 192kHz). Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-29ALSA: hdspm - Provide MADI speed mode selector on RME MADI and MADIfaceAdrian Knoth
When running in slave mode (no clock master), there is no way to determine the real wirespeed on the MADI link (single/double/quad speed). Like physical gear, simply provide the user with a tristate switch to select the appropriate format. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-06-30ALSA: hdspm - Fix compile warnings with PPCTakashi Iwai
The char can be unsigned on some architectures. Since the code checks the negative values, they should be declared as signed char explicitly. sound/pci/rme9652/hdspm.c:5449: warning: comparison is always false due to limited range of data type sound/pci/rme9652/hdspm.c:5462: warning: comparison is always false due to limited range of data type Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-14Merge branch 'test/pci-rename' into topic/miscTakashi Iwai
2011-06-12ALSA: hdspm - Add firmware revision ID for RME MADI PCI versionAdrian Knoth
The PCI version of the RME HDSP MADI card uses 0xcf as revision ID. Just add this to the list of supported cards. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-12ALSA: hdspm - Fix jumping external wordclock frequency in AutoSync modeAdrian Knoth
When using Word Clock on RME MADI cards, AutoSync mode was alternating betweeen MADI and WC due to a typo: AutoSync is indicated in the second status register (status2), not the first one (status). While the proc output was always correct, the reported WC frequency to ALSA was unstable as mentioned in http://mailman.alsa-project.org/pipermail/alsa-devel/2008-March/006723.html Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-12ALSA: hdspm - Fix locking in snd_hdspm_midi_input_readAdrian Knoth
For the MIDI part, we need to acquire (and release) the hmidi->lock, access to the global hdspm structure is serialized through hmidi->hdspm->lock instead. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: use KBUILD_MODNAME for request_irq argument in sound/pci/*Takashi Iwai
The name argument of request_irq() appears in /proc/interrupts, and it's quite ugly when the name entry contains a space or special letters. In general, it's simpler and more readable when the module name appears there, so let's replace all entries with KBUILD_MODNAME. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-08ALSA: hdspm - Add firmware ID for older AES32 cards.Adrian Knoth
The current AES32 firmware revision ID is 234, however, a user confirmed that everything works fine with the previous revision, too. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - Fix midi port initializationAdrian Knoth
Depending on the model and the presence of a TCO module, the number of midi ports varies. Some have 1 port (MADIface), some have 2 (default), with TCO, there are 3. Don't hardcode the number of midi ports to initialize. This patch also fixes a boot lockup on MADIface. [Coding-style fixes by tiwai] Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - Abort on unknown firmware revisionAdrian Knoth
Don't continue if we cannot detect the real card type, otherwise, all subsequent functions, especially strcpy(), would fail, leaving the whole driver in an unusable state. Without such a protection, dmesg would look like this: Pid: 1525, comm: modprobe Not tainted 2.6.38-rc6 #1 MSI MS-7250/MS-7250 EIP: 0060:[<c114e700>] EFLAGS: 00010296 CPU: 1 EIP is at strcpy+0x10/0x30 EAX: f4d33e58 EBX: f5990800 ECX: f4d33e58 EDX: 00000000 ESI: 00000000 EDI: f4d33e58 EBP: f5990930 ESP: f3dd3e0c DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 f53d4204 00000000 f90bfc03 00000001 00000001 f3dd3e64 c10fedff f3dd3e7c f3d854e4 f53d4000 c10307b8 00000001 c10307b8 f5990860 c10307b8 00000001 c10332e5 f59908bc c12f4339 f59908bc f5990860 c11ef207 f4d33e00 f53d4000 [<f90bfc03>] ? snd_hdspm_probe+0x7e7/0x1166 [snd_hdspm] [<c10fedff>] ? __sysfs_add_one+0x1f/0xf0 [<c10307b8>] ? get_parent_ip+0x8/0x20 [<c10307b8>] ? get_parent_ip+0x8/0x20 [<c10307b8>] ? get_parent_ip+0x8/0x20 [<c10332e5>] ? add_preempt_count+0xa5/0xd0 [<c12f4339>] ? _raw_spin_lock_irqsave+0x19/0x40 [<c11ef207>] ? pm_runtime_enable+0x17/0x80 [<c1160172>] ? local_pci_probe+0x42/0xb0 [<c1161091>] ? pci_device_probe+0x61/0x80 [<c11e9587>] ? driver_probe_device+0x77/0x180 [<c11600f0>] ? pci_match_device+0xa0/0xc0 [<c11e9709>] ? __driver_attach+0x79/0x80 [<c11e9690>] ? __driver_attach+0x0/0x80 [<c11e8e32>] ? bus_for_each_dev+0x52/0x80 [<c11e9416>] ? driver_attach+0x16/0x20 [<c11e9690>] ? __driver_attach+0x0/0x80 [<c11e8771>] ? bus_add_driver+0xa1/0x220 [<c1160f20>] ? pci_device_remove+0x0/0xf0 [<c11e99a3>] ? driver_register+0x63/0x120 [<c11612bd>] ? __pci_register_driver+0x3d/0xb0 [<c1001132>] ? do_one_initcall+0x32/0x160 [<f90d6000>] ? alsa_card_hdspm_init+0x0/0x14 [snd_hdspm] [<c10676a9>] ? sys_init_module+0x99/0x1e0 [<c10ade3d>] ? sys_close+0x6d/0xc0 [<c1002c90>] ? sysenter_do_call+0x12/0x26 ---[ end trace 239f0661c558378b ]--- Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - Add updated firmware revision for AES32Adrian Knoth
In contrast to the PCIe version (RME AES), the PCI version (RME AES32) has a different firmware revision. This patch adds the missing PCI revision. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: hdspm - AES32: Use define instead of hardcoded channel countAdrian Knoth
2011-02-23ALSA: hdspm - Fix lock/sync reporting on MADI and AES32Adrian Knoth
2011-02-23ALSA: hdspm - prevent reading unitialized stack memoryAdrian Knoth
Original patch by Dan Rosenberg <drosenberg@vsecurity.com> under commit e68d3b316ab7b02a074edc4f770e6a746390cb7d. I'm copying his text here: The SNDRV_HDSPM_IOCTL_GET_CONFIG_INFO ioctl in hdspm.c allow unprivileged users to read uninitialized kernel stack memory, because several fields of the hdspm_config struct declared on the stack are not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - fix sync check on AES32Adrian Knoth
Fredrik Lingvall <fredrik.lingvall@gmail.com> has discovered wrong frequency and sync detection on AES32. According to him, the provided patch fixes these issues. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Remove input selector on MADIfaceAdrian Knoth
In contrast to the RME MADI card, coax/optical selection on the MADIface is done via a physical switch located at the breakout box. Obviously, the driver cannot switch ports in software. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Fix DS/QS output channel mappings on RME MADI/MADIfaceAdrian Knoth
Caused by two typos, no output channel mappings were assigned for MADI/MADIface at double/quad speed. The channel mapping is indeed identical to the single speed mapping, the cards will simply use the first N channels. Signed-off-by: Florian Faber <faber@faberman.de> Signed-off-by: Fredrik Lingvall <fredrik.lingvall@gmail.com> Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Restrict channel count on RME AES/AES32Adrian Knoth
Without calling an appropriate rule, AES/AES32 cards would announce a theoretical channel count of 64 (HDSPM_MAX_CHANNELS), leading to the already known bug: [37422.640481] ------------[ cut here ]------------ [37422.640487] WARNING: at sound/pci/rme9652/hdspm.c:5449 snd_hdspm_ioctl+0x18f/0x202 [snd_hdspm]() [37422.640489] Hardware name: PRIMERGY RX100 S6 [37422.640490] BUG? (info->channel >= hdspm->max_channels_in) [37422.640492] Modules linked in: snd_hdspm snd_seq_midi ipmi_watchdog ipmi_poweroff ipmi_si ipmi_devintf ipmi_msghandler i2c_i801 e1000e snd_rawmidi power_meter [last unloaded: snd_hdspm] [37422.640501] Pid: 22231, comm: jackd Tainted: G D W 2.6.36-gentoo-r5 #5 [37422.640502] Call Trace: [37422.640508] [<ffffffff8103db3a>] warn_slowpath_common+0x80/0x98 [37422.640511] [<ffffffff8103dbe6>] warn_slowpath_fmt+0x41/0x43 [37422.640514] [<ffffffff81034306>] ? get_parent_ip+0x11/0x42 [37422.640518] [<ffffffffa0055763>] snd_hdspm_ioctl+0x18f/0x202 [snd_hdspm] [37422.640522] [<ffffffff813fd626>] snd_pcm_channel_info+0x73/0x7c [37422.640525] [<ffffffff814001e9>] snd_pcm_common_ioctl1+0x326/0xb01 [37422.640527] [<ffffffff81034306>] ? get_parent_ip+0x11/0x42 [37422.640531] [<ffffffff8105be6c>] ? __srcu_read_unlock+0x3b/0x59 [37422.640533] [<ffffffff81400bce>] snd_pcm_capture_ioctl1+0x20a/0x227 [37422.640537] [<ffffffff811e599c>] ? file_has_perm+0x90/0x9e [37422.640540] [<ffffffff81400c15>] snd_pcm_capture_ioctl+0x2a/0x2e [37422.640543] [<ffffffff810f2c69>] do_vfs_ioctl+0x404/0x453 [37422.640546] [<ffffffff810f2d09>] sys_ioctl+0x51/0x74 [37422.640549] [<ffffffff81002aab>] system_call_fastpath+0x16/0x1b [37422.640552] ---[ end trace 0cd919cd68118082 ]--- We already have all the right values in place, we simply have to inform the upper layers about this restriction. Note that snd_hdspm_hw_rule_rate_out_channels and snd_hdspm_hw_rule_rate_in_channels must not be called on AES32, because the channel count is always 16, no matter of the samplerate in use. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hdspm - Fix buffer handling on RME MADI/MADIface/AES(32)Adrian Knoth
Only RayDAT and AIO provide sane buffer pointers that can be used with HDSPM_BufferPositionMask, on all other cards, this would result in a wrong HW pointer leading to xruns and these messages: [260808.916788] BUG: pcmC0D0p:0, pos = 2976, buffer size = 1024, period size = 512 [260808.961124] BUG: pcmC0D0c:0, pos = 4944, buffer size = 1024, period size = 512 Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: hpdsm - RME AES(32): Fix missing channel mappingsAdrian Knoth
On RME AES and AES(32), none of the required information (max_channels_in, max_channels_out, channel mappings, port names) was set, leading to the BUG below. This patch adds the missing bits, thus fixing the bug. 125.058768] ------------[ cut here ]------------ [ 125.058773] WARNING: at sound/pci/rme9652/hdspm.c:5389 snd_hdspm_ioctl+0x10c/0x1d8 [snd_hdspm]() [ 125.058775] Hardware name: PRIMERGY RX100 S6 [ 125.058777] BUG? (info->channel >= hdspm->max_channels_out) [ 125.058778] Modules linked in: ipmi_watchdog ipmi_poweroff ipmi_si ipmi_devintf ipmi_msghandler snd_hdspm power_meter e1000e snd_rawmidi i2c_i801 [ 125.058787] Pid: 3652, comm: audacity Tainted: G W 2.6.36-gentoo-r5 #5 [ 125.058788] Call Trace: [ 125.058792] [<ffffffff8103db3a>] warn_slowpath_common+0x80/0x98 [ 125.058796] [<ffffffff8103dbe6>] warn_slowpath_fmt+0x41/0x43 [ 125.058800] [<ffffffffa006761a>] snd_hdspm_ioctl+0x10c/0x1d8 [snd_hdspm] [ 125.058803] [<ffffffff813fd626>] snd_pcm_channel_info+0x73/0x7c [ 125.058806] [<ffffffff814001e9>] snd_pcm_common_ioctl1+0x326/0xb01 [ 125.058809] [<ffffffff810c604c>] ? __do_fault+0x361/0x3a6 [ 125.058812] [<ffffffff81400e23>] snd_pcm_playback_ioctl1+0x20a/0x227 [ 125.058815] [<ffffffff811e599c>] ? file_has_perm+0x90/0x9e [ 125.058818] [<ffffffff81400e6a>] snd_pcm_playback_ioctl+0x2a/0x2e [ 125.058821] [<ffffffff810f2c69>] do_vfs_ioctl+0x404/0x453 [ 125.058824] [<ffffffff810f2d09>] sys_ioctl+0x51/0x74 [ 125.058827] [<ffffffff81002aab>] system_call_fastpath+0x16/0x1b [ 125.058830] ---[ end trace 5bddb08e5d4cbeb1 ]--- Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Florian Faber <faber@faberman.de> Signed-off-by: Fredrik Lingvall <fredrik.lingvall@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-27ALSA: hdspm - remove unused arrays, reduce stack usage in hwdep_ioctlJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-27ALSA: [hdspm] Move static mapping arrays to .cAdrian Knoth
As requested by Takashi and Jaroslav, these arrays should not be in the header file. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-27ALSA: hdspm - Add support for RME RayDAT and AIOAdrian Knoth
Incorporate changes by Florian Faber into hdspm.c. Code taken from http://wiki.linuxproaudio.org/index.php/Driver:hdspe Heavily reworked to mostly comply with the coding standard (whitespace fixes, line width, C++ style comments) The code was tested and confirmed to be working on RME RayDAT. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2010-12-01ALSA: hdsp - Add support for RPM io boxFlorian Faber
Add support for the RME HDSP RPM IO box. Changes have been made in the identification of the IO box and the neccessary controls have been added. Signed-off-by: Florian Faber <faberman@linuxproaudio.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-25ALSA: sound/pci/rme9652: prevent reading uninitialized stack memoryDan Rosenberg
The SNDRV_HDSP_IOCTL_GET_CONFIG_INFO and SNDRV_HDSP_IOCTL_GET_CONFIG_INFO ioctls in hdspm.c and hdsp.c allow unprivileged users to read uninitialized kernel stack memory, because several fields of the hdsp{m}_config_info structs declared on the stack are not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-08-12ALSA: hdsp - allow proc reporting with disconnected io boxTim Blechmann
the hdsp driver refuses to report any information via the proc interface, if the io box is not connected. with this patch, the content of the control and status registers is printed before the iobox check. Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10Merge branch 'topic/hdsp' into for-linusTakashi Iwai
* topic/hdsp: ALSA: hdsp - Add a comment about external firmwares for hdsp ALSA: hdsp: allow firmware loading from inside the kernel
2009-06-05ALSA: Clean up 64bit division functionsTakashi Iwai
Replace the house-made div64_32() with the standard div_u64*() functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-12ALSA: hdsp: allow firmware loading from inside the kernelRaphael Doursenaud
Allow the use of the FIRMWARE_IN_KERNEL option with hdsp cards and in-kernel driver. Also corrected a typo in the comment. Signed-off-by: Raphael Doursenaud <rdoursenaud@free.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-05ALSA: hdsp - Ignore MIDI and PCM events in interrupts until initializedTakashi Iwai
Ignore MIDI and PCM events in the interrupt handler until the device gets initialized properly. Otherwise you may get kernel panic by the access to uninitialized devices via hotplugging. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23ALSA: hdsp - whitespace cleanupTim Blechmann
Impact: remove trailing spaces Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23ALSA: hdsp - poll for ioboxTim Blechmann
sleeping for 2 seconds before checking for the iobox is not enough on some systems. this patch increases the timeout, but polls the card during that time. it thus speeds up the module loading when the card has already been initialized, while being more robust on systems, which require a higher timeout than the predefined 2 seconds. Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23Merge branch 'topic/hwdep-cleanup' into topic/hdspTakashi Iwai
2009-02-05ALSA: Remove superfluous hwdep opsTakashi Iwai
Remove NOP hwdep ops in sound drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
