path: root/sound/pci/via82xx.c
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] via82xx: minor optimization in snd_via82xx_freeMarcin Ślusarz
via82xx: minor optimization in snd_via82xx_free don't check X, when we just checked !X before goto Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] via82xx - Fix quirk for Shuttle AK32VNTakashi Iwai
Fix quirk for Shuttle AK32VN. It works better with DXS_SRC, and needs HP_ONLY ac97 quirk. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] via82xx - Add DXS quirk for Shuttle AK31v2Takashi Iwai
Shuttle AK31v2 works well with dxs_support=5 (ALSA bug#2926). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] alsa-kernel: schedule_timeout() fixesRene Herman
Fix schedule_timeout() use in alsa-kernel. Mostly just schedule_timeout(1) --> schedule_timeout_uninterruptible(1) The wavefront_synth one fixes the surrounding loop as well. In ymfpci_main, delete a superfluous set_current_state() and in soc/soc-dapm.c replace an _interruptible with _uninterruptible in some debug code; it's not waiting for signals. Signed-off-by: Rene Herman <rene.herman> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Fix invalid schedule_timeout_interruptible()Takashi Iwai
Fixed the invalid use of schedule_timeout_interruptible() without checking pending signals. Simply replaced with schedule_timeout(). Suggestions thanks to Jeff Garzik. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] via82xx - Use quirk list helper functionTakashi Iwai
Clean up dxs_support quirk list using snd_pci_quirk_lookup(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ac97 - Suppress power-saving mode on non-supporting driversTakashi Iwai
Don't enable power-saving mode on drivers that don't support it. The supporting drivers set AC97_SCAP_POWER_SAVE to scaps at creation of ac97 instance. Currently enable on the following drivers: intel8x0, intel8x0m, atiixp, atiixp-modem, via82xx and via82xx-modem. Also, a bit clean up of power-saving stuff: - Don't create an own workq - Remove superfluous ifdefs Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] via82xx: add __devinitdataAndreas Mohr
add __devinitdata to struct whitelist, since it's used within a __devinit function. Add const attribute to iterator variable, too. Compile-tested (no section warnings etc.) and run-tested on vt8233, 2.6.18-mm3 (hopefully applies well to current ALSA). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Various fixes for suspend/resume of ALSA PCI driversTakashi Iwai
- Check the return value of pci_enable_device() and request_irq() in the suspend. If any error occurs there, disable the device using snd_card_disconnect(). - Call pci_set_power_state() properly with pci_choose_state(). - Fix the order to call pci_set_power_state(). - Removed obsolete house-made PM codes in some drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Added TLV support to VIA82xx driverTakashi Iwai
Added the TLV support to VIA82xx driver for addition of dB range information. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] via82xx - Add dxs_support entry for a FSC machineTakashi Iwai
Added dxs_support=5 entry for a FSC machine. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Add experimental support of aggressive AC97 power-saving modeTakashi Iwai
Added CONFIG_SND_AC97_POWER_SAVE kernel config to enable the support of aggressive AC97 power-saving mode. In this mode, the AC97 powerdown register bits are dynamically controlled at each open/close of PCM streams. The mode is activated via power_save option for snd-ac97-codec driver. As default it's off. It can be turned on/off on the fly via sysfs, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] via82xx - Default to variable samplerate enabled for MSI K8T Neo2-FIKarsten Wiese
Default to variable samplerate enabled for MSI K8T Neo2-FI No crackles here with 44100. Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Add hp_only quirk for pci id [161f:2032] to via82xxDaniel T Chen
http://www.kernel.org/git/?p=linux/kernel/git/bcollins/ubuntu-dapper.git;a=commitdiff;h=eae2cc78de39502595f67b7fc1f821f5963bb8ae UpstreamStatus: Not merged Christian Bjalevik reports in LP#38546 that his sound chipset requires the 'hp_only' quirk to allow him to control sound volume correctly when headphones are inserted. This patch adds the appropriate pci id to the via82xx ALSA driver so that the quirk is applied automatically, thereby removing the need for users to modify /etc/modprobe.d/alsa-base (or to unload and reload snd-via82xx with ac97_quirk=hp_only). This patch closes LP#38546. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Change an arugment of snd_mpu401_uart_new() to bit flagsTakashi Iwai
Change the 5th argument of snd_mpu401_uart_new() to bit flags instead of a boolean. The argument takes bits that consist of MPU401_INFO_XXX flags. The callers that used the value 1 there are replaced with MPU401_INFO_INTEGRATED. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] via82xx - Use DXS_SRC as default for VIA8235/8237/8251 chipsTakashi Iwai
Use DXS_SRC as the default value for dxs_support option for VIA8235/8237/8251 chips. These new chips should work well with SRC. For VIA8233/A/C, the old default DXS_48K is still used to be sure. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] via82xx: tweak VT8251 workaroundBastiaan Jacques
Move the workaround for the VT8251 up a bit, and check for STAT_EOL rather than STAT_ACTIVE. This resolves issues some people were having with certain ALSA clients (and allows the STAT_ACTIVE check to do what it was intended to do). This change was suggested by Andrew Daviel. Signed-off-by: Bastiaan Jacques <b.jacques@planet.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] via82xx: add support for VIA VT8251 (AC'97)Bastiaan Jacques
Add support for VIA VT8251 AC'97. Includes a workaround which ensures sound won't stop playing after one second of playback. Signed-off-by: Bastiaan Jacques <b.jacques@planet.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] via82xx - Add a dxs entry for ECS K8T890-ATakashi Iwai
Modules: VIA82xx driver Added a dxs_support entry for ECS K8T890-A board. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] via82xx - Add dxs entry for EPoX EP-8KRAITakashi Iwai
Added the dxs_support entry for EPoX EP-8KRAI (ALSA bug#1423). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] via82xx - Add dxs entry for ASRock moboTakashi Iwai
Modules: VIA82xx driver Add dxs_support entry for ASRock mobo. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] via82xx - Add dxs entry for FSC Amilo L7300Takashi Iwai
Modules: VIA82xx driver Added dxs_support entry for FSC Amilo L7300. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] via82xx - Add dxs entry for P4M800/VIA8237RTakashi Iwai
Modules: VIA82xx driver Added the dxs entry for P4M800/VIA8237R, reported by OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] via82xx - Add dxs entry for a FSC boardTakashi Iwai
Modules: VIA82xx driver Add dxs entry for a FSC board. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] via82xx - Add dxs_support entry for EpoX 9HEAITakashi Iwai
Modules: VIA82xx driver Added the dxs_support entry for EpoX 9HEAI. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] via82xx - Add dxs_support entryTakashi Iwai
Modules: VIA82xx driver Added a dxs_support entry for Jetway K8M8MS. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] via82xx - Add dxs_support for ASUS moboTakashi Iwai
Modules: VIA82xx driver Add a dxs_support entry for ASUS mobo. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] via82xx - Add a quirk for Targa Traveller 811Takashi Iwai
Modules: VIA82xx driver Add an ac97 quirk entry for Targa Traveller 811. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] via82xx - Add dxs entry for ASRock moboTakashi Iwai
Modules: VIA82xx driver Added dxs_support entry for ASRock mobo. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] via82xx - Fix PM supportTakashi Iwai
Modules: VIA82xx driver,VIA82xx-modem driver Fix PM support on VIA82xx and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI VIA82xxTakashi Iwai
Modules: VIA82xx driver,VIA82xx-modem driver Remove xxx_t typedefs from the PCI VIA82xx and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] via82xx - Add dxs entry for MSI KT800 Delta-FSRTakashi Iwai
Modules: VIA82xx driver Added the dxs entry for MSI KT800 Delta-FSR. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-04[ALSA] Fix schedule_timeout usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use human-time conversion functions instead of hard-coded division to avoid rounding issues. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Fix the type of enable module optionTakashi Iwai
Fix the type of enable module option to bool. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Reduce interrupt latency in sound/pci/via82xx.cKarsten Wiese
Modules: VIA82xx driver The change only affects the via823x kind of chips. Here the via8233_pcm_pointer_hw() function (named snd_via8233_pcm_pointer() before) needed to loop until a non zero position is red from the chip. Measurements have shown that more than 200 loops are typically needed on an Athlon64. As io-reads cost many cycles, those loops sum up huge. via8233_pcm_pointer_hw() runs either in interrupt or with interrupts disabled. So it introduces significant interrupt latency. The patch introduces a calculated position value hwptr_done, that is updated by the interrupt routine when a period is completed. It is only used, if the 823x chip returns a zero position, which can't be interpreted reliably. Further optimisation is applied on the 8233 chip's interrupt routine: Only the SGD_SHADOW is read, as it contains all infos needed. We ommit ~5 more register reads that way. Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Enable DXS controls for VIA VT82xxHonza Maly
Modules: VIA82xx driver The patch enable separate DXS controls of sound function of VIA VT82xx controller in case DXS volume is not needed for PCM Playback volume control emulation. Signed-off-by: Honza Maly <hkmaly@matfyz.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] via82xx - Add DXS entry for Clevo D470Takashi Iwai
Modules: VIA82xx driver Added the DXS entry for Clevo D470 laptop. Signed-off-by: Takashi Iwai <tiwai@suse.de>
