path: root/sound/pci
2010-09-14Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-10Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-09-09ALSA: virtuoso: update Kconfig textClemens Ladisch
Update the Xonar config texts with the latest information about the Xonar DS, HDAV1.3 Slim, and Xense. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09ALSA: oxygen: fix CONFIG_SND_OXYGEN_LIB dependency selectionClemens Ladisch
As the select directive does not handle indirect dependencies, select those explicitly in the driver sections. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09ALSA: virtuoso: Xonar DS: add stereo upmixing to center/LFE channelsClemens Ladisch
Add the possibility to route a mix of the two channels of stereo data to the center and LFE outputs. Due to a WM8766 restriction, all surround and back channels also get the mixed L/R signal in this case. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09ALSA: virtuoso: automatically handle Xonar DS headphone routingClemens Ladisch
Automatically mute the speaker outputs as long as a headphone is plugged. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09ALSA: virtuoso: add Xonar DS headphone jack detectionClemens Ladisch
Now that the polarity of the headphone detection pin is known, replace the debugging message with a proper jack plug input device. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09ALSA: virtuoso: fix Xonar DS input switchesClemens Ladisch
Use the correct number, register bits, and names for the input switches. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09ALSA: virtuoso: fix WM8766 register writes with MSBClemens Ladisch
The check for the volume update latch bit was accidentally in the wrong function, where it would prevent the MSB from being written, instead of correctly ignoring it for cached values. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-08ALSA: hda - Fix wrong HP pin detection in snd_hda_parse_pin_def_config()Takashi Iwai
snd_hda_parse_pin_def_config() has some workaround for re-assigning some pins declared as headphones to line-outs. This didn't work properly for some cases because it used memmove() stupidly wrongly. Reference: Novell bnc#637263 https://bugzilla.novell.com/show_bug.cgi?id=637263 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-08ALSA: hda - Enable PC-beep for EeePC with ALC269 codecTakashi Iwai
EeePC 1001HAG has a similar problem like other ASUS machine, which doesn't set the codec SSID properly for indicating the beep capability. To enable PC-beep again, put this to the whitelist. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-08ALSA: hda - Add errata initverb sequence for CS42xx codecsBrian Austin
Add init verb sequence for errata ER880C3 http://www.cirrus.com/en/pubs/errata/ER880C3.pdf Signed-off-by: Brian Austin <brian.austin@cirrus.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-08ALSA: virtuoso: fix setting of Xonar DS line-in/mic-in controlsClemens Ladisch
The Line and Mic inputs cannot be used at the same time, so the driver has to automatically disable one of them if both are set. However, it forgot to notify userspace about this change, so the mixer state would be inconsistent. To fix this, check if the other control gets muted, and send a notification event in this case. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-and-tested-by: Nathan Schagen Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-08ALSA: virtuoso: work around missing reset in the Xonar DS Windows driverClemens Ladisch
For the WM8776 chip, this driver uses a different sample format and more features than the Windows driver. When rebooting from Linux into Windows, the latter driver does not reset the chip but assumes all its registers have their default settings, so we get garbled sound or, if the output happened to be muted before rebooting, no sound. To make that driver happy, hook our driver's cleanup function into the shutdown notifier and ensure that the chip gets reset. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-and-tested-by: Nathan Schagen Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-07ALSA: hda - Add quirk for Lenovo T400sTakashi Iwai
Lenovo T400s requires the quirk to make automatic HP/mic switching working. Reported-by: Frank Becker <fb@alien8.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-07ALSA: ca0106 - clean up playback pointer callbackTakashi Iwai
Clean up the playback pointer callback function a bit, and make the pointer check more strictly to avoid bogus pointers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-03Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-02ALSA: hda - Add a new hp-laptop model for Conexant 5066, tested on HP G60David Henningsson
This new model adds the following functionality to HP G60: - Automute of internal speakers - Autoswitch of internal/external mics - Remove SPDIF not physically present BugLink: http://launchpad.net/bugs/587388 Cc: stable@kernel.org Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-28Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-28ALSA: asihpi - Return hw error directly from oustream_write.Eliot Blennerhassett
If hw error is ignored, status is updated with invalid info. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-26ALSA: hda - Add Sony VAIO quirk for ALC269David Henningsson
The attached patch enables playback on a Sony VAIO machine. BugLink: http://launchpad.net/bugs/618271 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-23Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-23ALSA: hda - Add support for Lenovo S10-3tJerone Young
This patch adds quirk for the Lenovo S10-3t so the headphone & microphone jacks will now work. Signed-off-by: Jerone Young <jerone.young@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-23ALSA: ice1712: Add support for Edirol DA-2496Garnet MacPhee
This device is similar to the M-Audio Delta 1010LT in that it uses the AK4524VF ADC/DAC, but it does not use the CS8427 for SPDIF. The SPDIF appears to be set up correctly, but I am not able to test it as I do not have any devices that use it. This patch makes the ADC/DAC's and the hardware mixer visible to apps such as alsamixer and envy24control. Signed-off-by: Garnet MacPhee <dhubsith@comcast.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-20ALSA: hda - Fix stream and channel-ids codec-bus wideTakashi Iwai
The new sticky PCM parameter introduced the delayed clean-ups of stream- and channel-id tags. In the current implementation, this check (adding dirty flag) and actual clean-ups are done only for the codec chip. However, with HD-audio architecture, multiple codecs can be on a single bus, and the controller assign stream- and channel-ids in the bus-wide. In this patch, the stream-id and channel-id are checked over all codecs connected to the corresponding bus. Together with it, the mutex is moved to struct hda_bus, as this becomes also bus-wide. Reported-and-tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-20ALSA: hda - Fix conflict of sticky PCM parameter in HDMI codecsTakashi Iwai
Intel and Nvidia HDMI codec drivers have own implementations of sticky PCM parameters. Now HD-audio core part already has it, thus both setups conflict. The fix is simply remove the part in patch_intelhdmi.c and patch_nvhdmi.c and simply call snd_hda_codec_setup_stream() as usual. Reported-and-tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: intel8x0: Mute External Amplifier by default for ThinkPad X31Daniel T Chen
BugLink: https://bugs.launchpad.net/bugs/619439 This ThinkPad model needs External Amplifier muted for audible playback, so set the inv_eapd quirk for it. Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: hda - Fix build error with CONFIG_PROC_FS=nTakashi Iwai
hdmi_eld_update_pcm_info() must be always compiled in. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: hda - Add support for IDT 92HD89XX codecsCharles Chin
Just added new codec ids. These are almost compatible with existing ones. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-18Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-18ALSA: emu10k1 - delay the PCM interrupts (add pcm_irq_delay parameter)Jaroslav Kysela
With some hardware combinations, the PCM interrupts are acknowledged before the period boundary from the emu10k1 chip. The midlevel PCM code gets confused and the playback stream is interrupted. It seems that the interrupt processing shift by 2 samples is enough to fix this issue. This default value does not harm other, non-affected hardware. More information: Kernel bugzilla bug#16300 [A copmile warning fixed by tiwai] Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-17ALSA: hda - Fix ALC680 base model captureKailang Yang
- Fix capture mixer elements for ALC680 base model - Support auto change ADC for recording from MIC - Cancel capture source assigned in auto mode. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-16ALSA: hda - Add quirk for Dell Vostro 1220Takashi Iwai
model=dell-vostro is needed for Dell Vostro 1220 with Coexnat 5067. Reference: Novell bnc#631066 https://bugzilla.novell.com/show_bug.cgi?id=631066 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-16ALSA: riptide - Fix detection / load of firmware filesTakashi Iwai
The detection and loading of firmeware on riptide driver has been broken due to rewrite of some codes, checking the presense wrongly. This patch fixes the logic again. Reference: kernel bug 16596 https://bugzilla.kernel.org/show_bug.cgi?id=16596 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sound/usb/format: silence uninitialized variable warnings MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices MAINTAINERS: Make Wolfson entry also cover CODEC drivers ASoC: Only tweak WM8994 chip configuration on devices up to rev D ASoC: Optimise DSP performance for WM8994 ALSA: hda - Fix dynamic ADC change working again ALSA: hda - Restrict PCM parameters per ELD information over HDMI sound: oss: sh_dac_audio.c removed duplicated #include
2010-08-13ALSA: hda - Fix dynamic ADC change working againTakashi Iwai
The commit eb541337b7a43822fce7d0c9d967ee149b2d9a96 ALSA: hda - Make converter setups sticky changes the semantics of snd_hda_codec_cleanup_stream() not to clean up the stream at that moment but delay the action. This broke the codes expecting that the clean-up is done immediately, such as dynamic ADC changes in some codec drivers. This patch fixes the issue by introducing a lower helper, __snd_hda_codec_cleanup_stream(), to allow the immediate clean up. The original snd_hda_codec_cleanup_stream() is kept as is now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ALSA: hda - Restrict PCM parameters per ELD information over HDMITakashi Iwai
When a device is plugged over HDMI, it passes some information in ELD including the supported PCM parameters like formats, rates, channels. This patch adds the check to PCM open callback of HDMI streams so that only valid parameters the device supports are used. When no device is plugged, the parameters the codec supports are used; it's mostly all parameters the hardware can work. This is for apps that are started before device plugging and do probing (e.g. a sound daemon), so that at least, probing would work even before the device plugging. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: add AD1980 obsolete information ASoC: register cache should be 1 byte aligned for 1 byte long register ALSA: hda - Adding support for new IDT 92HD87XX codecs ASoC: Fix inverted mute controls for WM8580 ALSA: HDA: Use model=auto for LG R510 ALSA: hda - Update model entries in HD-Audio-Models.txt ALSA: hda: document VIA models ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify names ALSA: hda - add support for Conexant CX20584 ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000 ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codec ALSA: hda - Make converter setups sticky ALSA: hda - Add support for Acer ZGA ALC271 (1025:047c) sound/oss: Adjust confusing if indentation sound: oss: au1550_ac97.c removed duplicated #include ASoC: Fix for changed Eureka Kconfig symbol names
2010-08-10ALSA: hda - Adding support for new IDT 92HD87XX codecsCharles Chin
Added the entries for 92HD87B1/3 and 92HD87B2/4 codecs. These are compatible with existing 83xxx codecs. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-10ALSA: HDA: Use model=auto for LG R510David Henningsson
Two users report model=auto is needed to make the internal mic work properly. BugLink: https://bugs.launchpad.net/bugs/495134 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-10ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify namesStephen Warren
* Add missing codec IDs. * Modify some existing codec names for discrete GPUs to match newly added IDs. Note: existing names were a mixture of marketing and engineering GPU names. Equally, there's no reason that codec IDs have to be specific to a particular GPU or board, so identify codecs in a less marketing-oriented fashion. * Reformat codec ID table so it's easier to read, for me at least. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09ALSA: hda - add support for Conexant CX20584Takashi Iwai
The Conexant CX20584 with 141f:5068 seems compatible with other cxt5066 code. Just add the missing id. Tested-by: Cristopher Camacho Leandro <ccamacho@linuxmail.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000Steven Eastland
This provides a new model and pin config for the snd-hda-intel 92HD83XXX codec for hp laptop model dv7-4000, enabling the subwoofer. Signed-off-by: Steven Eastland <seastland at gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codecJonathan Woithe
I discovered tonight that ALSA no longer sets up a stream for the second ADC provided by the Realtek ALC260 HDA codec. At some point alc_build_pcms() started using stream_analog_alt_capture when constructing the second ADC stream, but patch_alc260() was never updated accordingly. I have no idea when this regression occurred. The trivial patch to patch_alc260() given below fixes the problem as far as I can tell. The patch is against 2.6.35. Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-08-06ALSA: hda - Make converter setups stickyTakashi Iwai
So far, we reset the converter setups like the stream-tag, the channel-id and format-id in prepare callbacks, and clear them in cleanup callbacks. This often causes a silence of the digital receiver for a couple of seconds. This patch tries to delay the converter setup changes as much as possible. The converter setups are cached and aren't reset as long as the same values are used. At suspend/resume, they are cleared to be recovered properly, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-06ALSA: hda - Add support for Acer ZGA ALC271 (1025:047c)Kailang Yang
2010-08-05Merge branch 'topic/misc' into for-linusTakashi Iwai
