CONFIG_SND_TEA575X is enabled by RADIO_SF16FMR2, but the latter one is
no PCI device. Since tea575x-tuner itself is independent from the board
bus type, the config should be moved out of SND_PCI dependency.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Use kzalloc rather than kmalloc followed by memset with 0
This considers some simple cases that are common and easy to validate
Note in particular that there are no ...s in the rule, so all of the
matched code has to be contiguous
The semantic patch that makes this output is available
in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
sound/pci/hda/patch_via.c:2087: warning: 'dac' may be used uninitialized in this function
Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com>
Put the exception checks for io_type switch() for possible mistakes in
future. Also this shuts up annoying compile warnings.
It works fine with auto-parser and now the digital mic workaround was
implemented in auto-parser fixup, let's drop the static model quirks for
these models.
The digital-mic unit on ASUS Eee PC gives PDM signals instead of the
normal stereo PCM, thus you can't record a mono stream from the stereo
stream as is; the summed stereo signal results in almost zero level, and
you'll hear only soft noise.
As a workaround, use ALC269-specific COEF to manipulate the dmic route
for mono, like used for ALC271x. This is implemented as a fix-up, thus
it works only with model=auto or without REALTEK_QUIRKS Kconfig.
Reported-and-tested-by: Pavel Roskin <proski@gnu.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: asihpi - Clarify adapter index validity check
ALSA: asihpi - Don't leak firmware if mem alloc fails
ALSA: rtctimer.c needs module.h
ASoC: Fix txx9aclc.c build
ALSA: hdspm - Add firmware revision 0xcc for RME MADI
ALSA: hdspm - Fix reported external sample rate on RME MADI and MADIface
ALSA: hdspm - Provide MADI speed mode selector on RME MADI and MADIface
ALSA: sound/core/pcm_compat.c: adjust array index
Avoids assigning possibly invalid address to pa, even if it
is never dereferenced.
Correct error response to reflect request object/function ids.
Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com>
We leak the memory allocated to 'firmware' when we fail to
release_firmware() after a kmalloc() failure in hpi_dsp_code_open().
This patch should take care of the leak.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
Apparently, there are multiple old firmware revisions in the wild for
the PCI RME MADI cards. Just add them to the list of supported devices
and treat them like their modern counterparts.
Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
In slave mode, the card can only detect the base frequency (32..48kHz)
on the MADI link (exception: 96k frames), so the real external sample
rate is this base frequency multiplied by 1, 2 or 4 depending on the
speed mode.
This patch enables 64..192kHz sample rates in clock slave mode, which
failed before due to an alleged sample rate mismatch between the MADI
link (e.g., 48kHz) and the application in DS/QS mode (e.g., 96kHz,
192kHz).
When running in slave mode (no clock master), there is no way to
determine the real wirespeed on the MADI link (single/double/quad
speed). Like physical gear, simply provide the user with a tristate
switch to select the appropriate format.
sound: oss: rename local change_bits to avoid powerpc bitsops.h definition
ALSA: hda - Fix duplicated DAC assignments for Realtek
ALSA: asihpi - off by one in asihpi_hpi_ioctl()
ALSA: hda - Fix Oops with Realtek quirks with NULL adc_nids
ALSA: asihpi - bug fix pa use before init.
ALSA: hda - Add support for vref-out based mute LED control on IDT codecs
Convert radio-sf16fmr2 to use generic TEA575x implementation. Most of the
driver code goes away as SF16-FMR2 is basically just a TEA5757 tuner
connected to ISA bus.
The card can optionally be equipped with PT2254A volume control (equivalent
of TC9154AP) - the volume setting is completely reworked (with balance control
added) and tested.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Takashi Iwai <tiwai@suse.de>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits)
ALSA: hda - Cirrus Logic CS421x support
ALSA: Make pcm.h self-contained
ALSA: hda - Allow codec-specific set_power_state ops
ALSA: hda - Add post_suspend patch ops
ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM
ALSA: hda - Make sure mute led reflects master mute state
ALSA: hda - Fix invalid mute led state on resume of IDT codecs
ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver"
ALSA: hda - Add support of the 4 internal speakers on certain HP laptops
ALSA: Make snd_pcm_debug_name usable outside pcm_lib
ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser
ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context.
ASoC: SAMSUNG: Modify I2S driver to support idma
ASoC: davinci: add missing break statement
ASoC: davinci: fix codec start and stop functions
ASoC: dapm - add DAPM macro for external enum widgets
ASoC: Acknowledge WM8962 interrupts before acting on them
ASoC: sgtl5000: guide user when regulator support is needed
ASoC: sgtl5000: refactor registering internal ldo
Copying hp_pins and speaker_pins from line_out_pins may confuse the
parser, and it can lead to duplicated initializations for the same pin
with a wrong DAC assignment. The problem appears in 3.0 kernel code.
Cc: <stable@kernel.org> (for 3.0)
"adapter" is used as an array index in the adapters[] array so
the off by one would make us read past the end.
1c073b67979 "ALSA: asihpi - Remove spurious adapter index check"
reverted Dan Rosenberg's check that would have prevented the
overflow here.
Somce quirk models don't set adc_nids but let the parser filling it.
But the recent code has unnecessary NULL-checks of spec->input_mux,
and it resulted in NULL dereferences.
This patch fixes that regression.
Reported-and-tested-by: Oliver Neukum <oneukum@suse.de>
Fixes bug introduced by 1c073b67.
Also declare pa local to block in which it is used.
This patch also registers all necessary callbacks to support mute LED
only when such control is enabled. And it keeps codec AFG in D0 or D1
state all the time when aggressive power managemnt is enabled for vref-out
control (and mute LED) work correctly.
Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
This update includes the changes necessary for supporting the
CS421x family of codecs. Previously this file only supported
the CS420x family of codecs.
This file also contains init verbs to correct several issues in
the CS421x hardware.
Behavior between the CS421x and CS420x codec families is similar,
so several functions have been reused with "if" statements to
determine which codec family (CS421x or CS420x) is present.
Also, this file will be updated sometime in the near future in
order to add support for a system using CS421x that requires
mono mix on the speaker output only.
[Fix const usages and adaption for new APIs by tiwai]
Signed-off-by: Tim Howe <tim.howe@cirrus.com>
The procedure for codec D-state change may have exceptional cases
depending on the codec chip, such as a longer delay or suppressing D3.
This patch adds a new codec ops, set_power_state() to override the system
default function. For ease of porting, snd_hda_codec_set_power_to_all()
helper function is extracted from the default set_power_state() function.
As an example, the Conexant codec-specific delay is removed from the
default routine but moved to patch_conexant.c.
Add a new ops, post_suspend(), which is called after suspend() ops is
performed. This is called only in the case of the real PM suspend, and
the codec driver can use this for further changing of D-state or
clearing the LED, etc.
It makes little sense to enable power-saving without PM.
This removes SND_HDA_NEEDS_RESUME define so that we can use CONFIG_PM
in all places.
This patch adds checking of mute state on all outputs besides just
speakers to calculate the master mute state for mute led support.
It also renames and splits the function that does it for better code
clarity.
Codec state is not restored immediately on resume but on the first
access when power-save is enabled. That leads to an invalid mute led
state after resume until either sound is played or some control is
changed. This patch adds a possibility for a vendor specific patch to
restore codec state immediately after resume if required. And it adds
code to restore IDT codecs state immediately on resume on HP systems
with mute led support.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Formatting a PCM name is useful for module debug too.
Add snd_prefix when making function public.
[minor coding-style fixes by tiwai]
Fix a regression in the DAC filling code in patch_realtek.c. The already
filled DACs in multiout.dac_nids[] were ignored because of num_dacs=0,
thus always pointed to the first DAC.
HPI Version is used to check for firmware compatibility.
This version will accept 4.08.xx released firmware,
and will also accept 4.09.xx beta firmware
Mute functionality was recently added to the DSP firmware
Add names corresponding to new HPI node types.
Shorten some names so that constructed names don't overflow the
maximum name length.
Because mutex is used in adapter struct defined here.
Fixes a sparse warning.
Subsystem requests don't have or need a valid adapter index.
The adapter index is already checked further on, before it is used to index
the adapters array. (Reverts 4a122c10f)
Work towards moving the function into alsa common header.
The loader API has been revised so that OS specific data is kept
local to hpidspcd.c, and the public API is unchanged across OSes.
code
Some cobranet control data would not fit in an original HPI message.
Now that HPI is able to transfer larger messages, this special handling
is no longer required.
Allow for up to 256 bytes of extra data on top of standard hpi
request and response sizes.
