path: root/sound/pci
2010-12-30ALSA: hda: Use LPIB quirk for Dell Inspiron m101z/1120Daniel T Chen
Sjoerd Simons reports that, without using position_fix=1, recording experiences overruns. Work around that by applying the LPIB quirk for his hardware. Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-23ALSA: hda - Fix GPIO2-fixup for Sony laptopsTakashi Iwai
The fix-up entries by the commit 2785591a9760c677a7ee6f541e751c23086f5bfd ALSA: hda - Add fix-up for Sony VAIO with ALC275 codecs weren't applied in the right position. They had to be before the quirk entry matching to all Sony devices. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-23ALSA: hda - Try to find an empty control index when it's occupiedTakashi Iwai
When a mixer control element was already created with the given name, try to find another index for avoiding conflicts, instead of breaking with an error. This makes the driver more robust. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-23ALSA: hda - Fix conflict of d-mic capture volume controlsTakashi Iwai
When the d-mics are assigned to the same purpose of another analog mic pins, the driver doesn't compute the index properly, resulting in an error with "existing control". This patch fixes it. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-21ALSA: hda - Don't apply ALC269-specific initialization to ALC275Kailang Yang
ALC275 doesn't require the ALC269 (and its variants) specific init sequences. Add the check of codec id. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-21ALSA: hda - Add fix-up for Sony VAIO with ALC275 codecsKailang Yang
Set GPIO2 for some Sony VAIO with ALC275 to fix speaker output. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-20ALSA: HDA: Add auto-mute for Thinkpad SL410/SL510David Henningsson
BugLink: http://launchpad.net/bugs/580006 SKU turns off auto-mute for these machines, so ignore the SKU. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-17ALSA: hda - Fix conflict of Mic Boot controlsTakashi Iwai
Due to the recent change for multiple mics assignment, we need to handle the index of each Mic Boost control respectively. Otherwise the driver gets the control element conflicts, and gives the unsable state. Reference: kernel bug 25002 https://bugzilla.kernel.org/show_bug.cgi?id=25002 Reported-and-tested-by: Adam Williamson <awilliam@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-15ALSA: HDA: Enable subwoofer on Asus G73JwDavid Henningsson
Set default association/sequence right on pin 0x17 in order for the automatic parser to recognize the subwoofer correctly. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-15ALSA: HDA: Fix auto-mute on Lenovo Edge 14David Henningsson
BugLink: http://launchpad.net/bugs/690530 The SKU value of this machine dictates that auto-mute should be disabled. Since the SKU value is similar to the PCI SSID, the most likely conclusion is that the SKU value should be ignored. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-09ALSA: HDA: Quirk for Dell Vostro 320 to make microphone workDavid Henningsson
BugLink: http://launchpad.net/497546 Confirmed that the ideapad model works better than the current quirk for Dell Vostro 320. Cc: stable@kernel.org (2.6.35+) Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-08ALSA: hda - Reset sample sizes and max bitrates when reading ELDAnssi Hannula
When a new HDMI/DP device is plugged in, hdmi_update_short_audio_desc() is called for every SAD (Short Audio Descriptor) in the ELD data. For LPCM coding type SAD defines the supported sample sizes. For several other coding types (such as AC-3), a maximum bitrate is defined. The maximum bitrate and sample size fields are not always cleared. Therefore, if a device is unplugged and a different one is plugged in, and the coding types of some SAD positions differ between the devices, the old max_bitrate or sample_bits values will persist if the new SADs do not define those values. The leftover max_bitrate and sample_bits do not cause any issues other than wrongly showing up in eld#X.Y procfs file and kernel log. Fix that by always clearing sample_bits and max_bitrate when reading SADs. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-07ALSA: hda - Always allow basic audio irrespective of ELD infoAnssi Hannula
Commit bbbe33900d1f3c added functionality to restrict PCM parameters based on ELD info (derived from EDID data) of the audio sink. However, according to CEA-861-D no SAD is needed for basic audio (32/44.1/48kHz stereo 16-bit audio), which is instead indicated with a basic audio flag in the CEA EDID Extension. The flag is not present in ELD. However, as all audio capable sinks are required to support basic audio, we can assume it to be always available. Fix allowed audio formats with sinks that have SADs (Short Audio Descriptors) which do not completely overlap with the basic audio formats (there are no reports of affected devices so far) by always assuming that basic audio is supported. Reported-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-07ALSA: hda - Do not wrongly restrict min_channels based on ELDAnssi Hannula
Commit bbbe33900d1f3c added functionality to restrict PCM parameters based on ELD info (derived from EDID data) of the audio sink. However, it wrongly assumes that the bits 0-2 of the first byte of CEA Short Audio Descriptors mean a supported number of channels. In reality, they mean the maximum number of channels (as per CEA-861-D 7.5.2). This means that the channel count can only be used to restrict max_channels, not min_channels. Restricting min_channels causes us to deny opening the device in stereo mode if the sink only has SADs that declare larger numbers of channels (like Primare SP32 AV Processor does). Fix that by not restricting min_channels based on ELD information. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Reported-by: Jean-Yves Avenard <jyavenard@gmail.com> Tested-by: Jean-Yves Avenard <jyavenard@gmail.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-06ALSA: hda: Use position_fix=1 for Acer Aspire 5538 to enable capture on ↵Daniel T Chen
internal mic BugLink: https://launchpad.net/bugs/685161 The reporter of the bug states that he must use position_fix=1 to enable capture for the internal microphone, so set it for his machine's PCI SSID. Verified using 2.6.35 and the 2010-12-04 alsa-driver build. Reported-and-tested-by: Ralph Wabel <rwabel@gmx.net> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-04ALSA: hda - Enable jack sense for Thinkpad Edge 13Manoj Iyer
Added a quirk to cxt5066_cfg_tbl to enable jack sense for ThinkPad Edge 13. Reference: http://launchpad.net/bugs/685015 Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-03ALSA: hda - Fix ThinkPad T410[s] docking station line-outJohn Baboval
On the docking station for the Lenovo T410 and T410s, the line-out doesn't work. The trouble seems to be that it generates a plug event, but then doesn't report that the jack is connected. So automute mutes the jack when you plug something into it. The following patch (next message) fixes it. Signed-off-by: John Baboval <john.baboval at virtualcomputer.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-03ALSA: hda: Use model=lg quirk for LG P1 Express to enable playback and captureDaniel T Chen
BugLink: https://launchpad.net/bugs/595482 The original reporter states that audible playback from the internal speaker is inaudible despite the hardware being properly detected. To work around this symptom, he uses the model=lg quirk to properly enable both playback, capture, and jack sense. Another user corroborates this workaround on separate hardware. Add this PCI SSID to the quirk table to enable it for further LG P1 Expresses. Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com> Tested-by: nikhov Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-02ALSA: hda: Use "alienware" model quirk for another SSIDDaniel T Chen
BugLink: https://launchpad.net/bugs/683695 The original reporter states that headphone jacks do not appear to work. Upon inspecting his codec dump, and upon further testing, it is confirmed that the "alienware" model quirk is correct. Reported-and-tested-by: Cody Thierauf Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-29ALSA: hda: Use BIOS auto-parsing instead of existing model quirk for MEDION MD2Daniel T Chen
BugLink: https://launchpad.net/bugs/682199 A 2.6.35 (Ubuntu Maverick) user, burningphantom1, reported a regression in audio: playback was inaudible through both speakers and headphones. In commit 272a527c04 of sound-2.6.git, a new model was added with this machine's PCI SSID. Fortunately, it is now sufficient to use the auto model for BIOS auto-parsing instead of the existing quirk. Playback, capture, and jack sense were verified working for both 2.6.35 and the alsa-driver snapshot from 2010-11-27 when model=auto is used. Reported-and-tested-by: burningphantom1 Cc: <stable@kernel.org> [2.6.35+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-26ALSA: hda - Use ALC_INIT_DEFAULT for really default initializationTakashi Iwai
When SKU assid gives no valid bits for 0x38, the driver didn't take any action, so far. This resulted in the missing initialization for external amps, etc, thus the silent output in the end. Especially users hit this problem on ALC888 newly since 2.6.35, where the driver doesn't force to use ALC_INIT_DEFAULT any more. This patch sets the default initialization scheme to use ALC_INIT_DEFAULT when no valid bits are set for SKU assid. Reference: https://bugzilla.redhat.com/show_bug.cgi?id=657388 Reported-and-tested-by: Kyle McMartin <kyle@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-25ALSA: hda - Fix ALC660-VD/ALC861-VD capture/playback mixersHerton Ronaldo Krzesinski
The mixer nids passed to alc_auto_create_input_ctls are wrong: 0x15 is a pin, and 0x09 is the ADC on both ALC660-VD/ALC861-VD. Thus with current code, input playback volume/switches and input source mixer controls are not created, and recording doesn't work. Select correct mixers, 0x0b (input playback mixer) and 0x22 (capture source mixer). Reference: https://qa.mandriva.com/show_bug.cgi?id=61159 Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-24ALSA: HDA: Add an extra DAC for Realtek ALC887-VDDavid Henningsson
The patch enables ALC887-VD to use the DAC at nid 0x26, which makes it possible to use this DAC for e g Headphone volume. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-24ALSA: hda - Fix Acer 7730G supportDenis Kuplyakov
Fixes automatic EAPD configuration on Acer 7730G laptop. Signed-off-by: Denis Kuplyakov <dener.kup@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-23ALSA: hda - Identify more variants for ALC269Kailang Yang
Give more correct chip names for ALC269-variant codecs. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-23ALSA: hda - Fix wrong ALC269 variant checkKailang Yang
The refactoring commit d433a67831ab2c470cc53a3ff9b60f656767be15 ALSA: hda - Optimize the check of ALC269 codec variants introduced a wrong check for ALC269-vb type. This patch corrects it. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-23ALSA: hda - Enable jack sense for Thinkpad Edge 11Manoj Iyer
Add a quirk entry for Thinkpad Edge 11 as well as other TP Edge models. Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-23ALSA: Revert "ALSA: hda - Fix switching between dmic and mic using the same ↵Takashi Iwai
mux on IDT/STAC" This reverts commit f41cc2a85d52ac6971299922084ac5ac59dc339d. The patch broke the digital mic pin handling wrongly. Reference: bko#23162 https://bugzilla.kernel.org/show_bug.cgi?id=23162 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: hda - Fixed ALC887-VD initial errorKailang Yang
ALC887-VD is like ALC888-VD. It can not be initialized as ALC882. Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: hda: Use hp-laptop quirk to enable headphones automute for Asus A52JDaniel T Chen
BugLink: https://launchpad.net/bugs/677652 The original reporter states that, in 2.6.35, headphones do not appear to work, nor does inserting them mute the A52J's onboard speakers. Upon inspecting the codec dump, it appears that the newly committed hp-laptop quirk will suffice to enable this basic functionality. Testing was done with an alsa-driver build from 2010-11-21. Reported-and-tested-by: Joan Creus Cc: <stable@kernel.org> [2.6.35+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: azt3328: period bug fix (for PA), add missing ACK on stop timerAndreas Mohr
. Fix PulseAudio "ALSA driver bug" issue (if we have two alternated areas within a 64k DMA buffer, then max period size should obviously be 32k only). Back references: http://pulseaudio.org/wiki/AlsaIssues http://fedoraproject.org/wiki/Features/GlitchFreeAudio . In stop timer function, need to supply ACK in the timer control byte. . Minor log output correction When I did my first PA testing recently, the period size bug resulted in quite precisely observeable half-period-based playback distortion. PA-based operation is quite a bit more underrun-prone (despite its zero-copy optimizations etc.) than raw ALSA with this rather spartan sound hardware implementation on my puny Athlon. Note that even with this patch, azt3328 still doesn't work for both cases yet, PA tsched=0 and tsched (on tsched=0 it will playback tiny fragments of periods, leading to tiny stuttering sounds with some pauses in between, whereas with timer-scheduled operation playback works fine - minus some quite increased underrun trouble on PA vs. ALSA, that is). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: hda: Add Samsung R720 SSID for subwoofer pin fixupDaniel T Chen
BugLink: https://launchpad.net/bugs/677830 The original reporter states that the subwoofer does not mute when inserting headphones. We need an entry for his machine's SSID in the subwoofer pin fixup list, so add it there (verified using hda_analyzer). Reported-and-tested-by: i-NoD Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: sound/pci/asihpi/hpioctl.c: Remove unnecessary casts of pci_get_drvdataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: ac97: Apply quirk for Dell Latitude D610 binding Master and Headphone ↵Daniel T Chen
controls BugLink: https://launchpad.net/bugs/669279 The original reporter states: "The Master mixer does not change the volume from the headphone output (which is affected by the headphone mixer). Instead it only seems to control the on-board speaker volume. This confuses PulseAudio greatly as the Master channel is merged into the volume mix." Fix this symptom by applying the hp_only quirk for the reporter's SSID. The fix is applicable to all stable kernels. Reported-and-tested-by: Ben Gamari <bgamari@gmail.com> Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11ALSA: sound/pci/ctxfi/ctpcm.c: Remove potential for use after freeJulia Lawall
In each function, the value apcm is stored in the private_data field of runtime. At the same time the function ct_atc_pcm_free_substream is stored in the private_free field of the same structure. ct_atc_pcm_free_substream dereferences and ultimately frees the value in the private_data field. But each function can exit in an error case with apcm having been freed, in which case a subsequent call to the private_free function would perform a dereference after free. On the other hand, if the private_free field is not initialized, it is NULL, and not invoked (see snd_pcm_detach_substream in sound/core/pcm.c). To avoid the introduction of a dangling pointer, the initializations of the private_data and private_free fields are moved to the end of the function, past any possible free of apcm. This is safe because the previous calls to snd_pcm_hw_constraint_integer and snd_pcm_hw_constraint_minmax, which take runtime as an argument, do not refer to either of these fields. In each function, there is one error case where apcm needs to be freed, and a call to kfree is added. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e,e1,e2,e3; identifier f,free1,free2; expression a; @@ *e->f = a ... when != e->f = e1 when any if (...) { ... when != free1(...,e,...) when != e->f = e2 * kfree(a) ... when != free2(...,e,...) when != e->f = e3 } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11ALSA: sound/mixart: avoid redefining {readl,write}_{le,be} accessorsFlorian Fainelli
If the platform already provides a definition for these accessors do not redefine them. The warning was caught on MIPS. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11ALSA: HDA: Enable digital mic on IDT 92HD87BDavid Henningsson
BugLink: http://launchpad.net/bugs/673075 According to the datasheet of 92HD87B, there is a digital mic at nid 0x11, so enable it in order to be able to use the mic. Cc: stable@kernel.org Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-03Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-11-03ALSA: hda - MacBookAir3,1(3,2) alsa supportEdgar (gimli) Hucek
This patch add support for the MacBookAir3,1 and MacBookAir3,2 to the alsa sound system. Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-02ALSA: asihpi - Unsafe memory management when allocating control cacheJesper Juhl
I noticed that sound/pci/asihpi/hpicmn.c::hpi_alloc_control_cache() does not check the return value from kmalloc(), which may fail. If kmalloc() fails we'll dereference a null pointer and things will go bad fast. There are two memory allocations in that function and there's also the problem that the first may succeed and the second may fail and nothing is done about that either which will also go wrong down the line. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Eliot Blennerhassett <linux@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-01ALSA: lx6464es - make 1 bit signed bitfield unsignedTim Blechmann
converts a 1 bit signed bitfield to an unsigned. Reported-by: Dr. David Alan Gilbert <linux@treblig.org> Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-01ALSA: cs46xx memory management fixes for cs46xx_dsp_spos_create()Jesper Juhl
When reading through sound/pci/cs46xx/dsp_spos.c I noticed a couple of things in cs46xx_dsp_spos_create(). It seems to me that we don't always free the various memory buffers we allocate and we also do some work (structure member assignment) early, that is completely pointless if some of the memory allocations fail and we end up just aborting the whole thing. I don't have hardware to test, so the patch below is compile tested only, but it makes the following changes: - Make sure we always free all allocated memory on failures. - Don't do pointless work assigning to structure members before we know all memory allocations, that may abort progress, have completed successfully. - Remove some trailing whitespace. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Tested-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: usb-audio: automatically detect feedback format ASoC: sound/wm9090: add missing __devexit marker ASoC: sound/max98088: add missing __devexit marker ASoC: sound/ad73311: add missing __devexit marker ASoC: fsl - fix build error in pcm030-audio-fabric.c sound/oss/sb_ess.c: delete double assignment ALSA: hda - Change BTL amp level on some HP notebooks
2010-10-25ALSA: hda - Change BTL amp level on some HP notebooksVitaliy Kulikov
Some HP laptops have lower amplifier levels for speakers in comparison with headphone outputs. This patch changes the BTL amp level for these machines to balance both the speaker and headphone output levels. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-10-25ALSA: hda - Disable sticky PCM stream assignment for AD codecsTakashi Iwai
The sticky PCM stream assignment introduced in 2.6.36 kernel seems causing problems on AD codecs. At some time later, the streaming no longer works by unknown reason. A simple workaround is to disable sticky-assignment for these codecs. Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-23ALSA: ca0106: Use card specific dac id for mute controls.Andy Owen
Signed-off-by: Andy Owen <andy-alsa@ultra-premium.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-23ALSA: ca0106: Allow different sound cards to use different SPI channel mappings.Andy Owen
