Clean up Makefile using xxx- style instead of
ifeq(CONFIG_XXX,y).
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
Many of ALC262 codes don't call the automute function at the beginning,
which may keep the silence until the HP jack is replugged. Now proper
init_hook is added.
Also, sony-assamd model doesn't handle the widget 0x14 properly, thus
calling automute isn't enough. Now Front switch handles both widgets.
The init sequence set a number of registers more than once to different
values. It's only necessary to set them once to their final values.
It also never actually updated the digital attenuation settings.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Add more symbol name for SPI register values. Change the SPI_XXX_BIT defines
from the bit number to a mask. Saves having to write (1<<SPI_XXX_BIT) all the
time to convert to mask. We never end up wanting the bit number.
Use all the symbol names for the SPI DAC init sequence. The sequence is
exactly the same as it was before.
For cards with an SPI DAC (SB Live 24-bit / Audigy SE), power down channels
0-2 when not in use. They are powered up on PCM open and down again on PCM
close. Channel 4 (== Front) is not powered down, as it is used for capture
feedback. Powering it down would effectively kill line in pass-through.
The SPDIF output on AD1988 had some problems due to the wrongly routed
analog loopback to SPDIF. This patch fixes the implementation of
'IEC958 Playback Source' mixer to handle the amp bits of mixer widget
0x1d correctly.
Turn a rather long lined for loop that is duplicated multiple times into a
macro.
Add four mute controls for the analog output channels for cards that use
an SPI DAC, like the SB0570 SB Live! 24-bit / Audigy SE. The Wolfson DAC
doesn't support muting left/right so the controls are mono.
The chip state struct gets a 32-byte array to act as a shadow of the spi
dac registers. Only two registers are used for mute, but more would be
needed for analog gain, de-emphasis, DAC power down, phase inversion, and
other features.
This patch fixes an off-by-one in a snd_assert() spotted by the
Coverity checker.
There were some places I forgot to replace with snd_ctl_boolean_mono_info.
Patch submitted by Ctirad Fertr
<c.fertr@volny.cz>
Details:
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=8176
The existing code for handling the 44.1 slot's volume has two problems:
the volume is not affected by the 'Wave Playback Volume' mixer control,
and the BUF441OUTVOL register, which is used to control the per-
substream volume for this slot, uses a different scale than the gain
fields of the other slots.
This patch makes the BUF441OUTVOL register a shadow of the
NATIVEDACOUTVOL register so that the Wave volume is consistent for all
substreams.
As a consequence of this, the per-substream PCM volume control gets no
longer activated for the substream using this slot. The code for
(de)activating the mixer control is moved from the open/close to the
prepare/trigger_stop callbacks so that it is able to determine the
substream's slot.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
Notebook.
Description: The .device=0x0008 chips have new, but different EMU32 in/out
channels. Driver updated to make use of these EMU32 channels.
deal with signedness of the stuff passed to set_bit() et.al.
Various gpio and mux settings for the Osprey 440 weren't correct. Fix them
and provide some documentation about how the gpios work.
The osprey eeprom routine wasn't run for the 440, add it. It was also crap,
re-written to be better.
Add the Osprey 440 to the Bt878 ALSA driver's whitelist. Currently the sample
rate is fixed at 32kHz, as the driver doesn't support different rates for
digital input mode, though the card can select the rate from 32, 44.1, or 48
kHz via gpio.
Setting the audio gain via ALSA isn't supported yet; a userspace tool that
programs the X9221 via i2c-dev must be used.
The Bt878 digital audio format isn't programmed correctly for the CS5331A ADC
used, resulting in extremely garbled sound. That is fixed in a followup
patch.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The recent fix for STAC92xx surround outputs broke the input pin
setting for shared line-in and mic jacks. This patch fixes the
breakage.
Basic audio support for the iMac 24'' model released on 09/2006,
including
headphone jack detection with automatic speaker muting.
This iMac uses the Realtek ALC885 codec, not a Sigmatel one as in
other models.
Functionality has been tested for internal speakers, headphone and
microphone.
Signed-off-by: Nicola Fagnani <nicfagn@iol.it>
Without the proper model setting, the Asus P5LD2 rear outputs remain
completely silent unlike other systems where the front speakers usually
work. This patch adds the P5LD2 to the quirk table.
Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com>
This card is just a normal SB Live 24bit,
but under a different marketing name.
Fixed PM resume of cs46xx devices. It now restores properly the DSP
image and kick-off the DSP.
Added support for some boards with SPDIF in/out, and cleaned up the GPIO
enable function.
Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com>
HP dx2200 and dx2250 use Micro-Star International (MSI) motherboards
(models MS-7254 and MS-7297 respectively) with an ALC862 codec in
threestack configuration. Adding this quirk allows correct 5.1 sound
output in these systems.
Rename ALC888_HP_NETTLE and ALC888_HP_LUCKNOW models to the more generic
names ALC888_6ST_HP and ALC888_3ST_HP since HP seems to be consistent
in the wiring of their 3stack and 6stack ALC888-based systems.
This patch fixes 5.1 surround output for the HP Samba using the same
quirk as the HP Lucknow. If HP machines are uniform in their wiring,
we should rename ALC888_HP_NETTLE to ALC888_6ST_HP and ALC888_HP_LUCKNOW
to ALC888_3ST_HP for generic HP 6stack and 3stack configurations.
Add line-in to the list of LG LW20 capture sources. Also fix the LG LW
pin assignment list comment.
Added support for line out controls for STAC9202 cards, and fixed issue
where master mixer control was being created twice for headphone and
speaker outs.
Add VIA HDA identification to use the HDA-based Motorola modem of
the Clevo m540 laptop.
This patch adds support for the MSI K9AGM2-FIH on-board audio.
Signed-off-by: Tobin Davis <tdavis@dsl-only.net>
Fix the default pin configuration of Abit AW9D-MAX. The board has a
broken BIOS that doesn't set the correct pin default configs, which
screws up the auto-configuration of snd-hda-intel driver.
The patch enables the override of default pin config values.
One of the newly added model entries causes a regression on Toshiba A100.
It works fine with model=auto. So, let's deselect the entry again.
Show the last issued command in warning messages when any communication
error with CORB/RIRB occurs.
Also, a bit code clean-up for composing the command value in
*_send_cmd().
Use ARRAY_SIZE() to calculate the number of pin widgets for each codec
chip.
This also fixes a typo in STAC9205 code that gives a wrong number (14
instead of 12), which resulted in fatal communication errors.
Added the missing model option values for ALC262.
Added HP Lucknow (ALC888) 5.1 surround support based on ALC883 6-channel
threestack with changes in channel routing.
Fixed HP Nettle 6ch/8ch channel routing based on ALC883 sixstack and
swapping rear and center/LFE in verbs and mixer settings.
Fix the mismatch of init verb and capture mux with VAIO STAC9872.
Also, changed the item names to be more intuitive.
Fixed ALC662 auto mode, wrong NIDs were chosen.
Signed-off-by: Kailang Yang <kailang@realtek.com.tw>
- Added BenQ T31-16 AMD Turion64x2 (ALC262) support
- Added models for ASUS machines with ALC861
Implemented LG LW20 5.1 support based on ALC880 threestack modes. It was
previously set to use one DAC and 2 jack modes, giving 2-channel output
only. Analog CD playing support is still missing.
Adds mention of opl3sa2 driver to a diagnostic message for NeoMagic
nm256 driver.
Signed-off-by: Paul Vojta <vojta@math.berkeley.edu>
Added the model for HP Nettle mobo with ALC883.
Added the model for HP Spartan with Conexant codec chip.
