[There is no upstream commit for this patch since the corresponding
code was removed from 3.2 kernel. This is a regression found only in
3.1 kernel, so please apply this only to 3.1.x series.]
Some ALC269 quirks define their own .cap_mixer field but without the
static adc_nids[]. This resulted in the mismatch of ADC because ALC269
may have the widget 0x07 for another audio-in, and the auto-parser picks
this up instead.
This patch fixes the problem by adding the static adc_nids[] and co
again to these entries.
Tested-by: Chris Vine <chris@cvine.freeserve.co.uk>
commit 6b45214277bec2193ad3ccb8d7aa6100b5a0f1a9 upstream.
It seems that Conexant CX20549 chip handle only a single input-amp even
though the audio-input widget has multiple sources. This has been never
clear, and I implemented in the current way based on the debug information
I got at the early time -- the device reacts individual input-amp values
for different sources. This is true for another Conexant codec, but it's
not applied to CX20549 actually.
This patch changes the auto-parser code to handle a single input-amp
per audio-in widget for CX20549. After applying this, you'll see only a
single "Capture" volume control instead of separate "Mic" or "Line"
captures when the device is set up to use a single ADC.
We haven't tested 20551 and 20561 codecs yet. If these show the similar
behavior like 20549, they need to set spec->single_adc_amp=1, too.
commit cc667a72d471e79fd8e5e291ea115923cf44dca0 upstream.
The revision 0x100300 was found for ALC662. It seems to work well
with patch_alc662.
BugLink: http://bugs.launchpad.net/bugs/877373
Tested-by: Shengyao Xue <Shengyao.xue@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Acked-by: Kailang Yang <kailang@realtek.com>
commit 254f296840b64b034a4c850d45dbde7c040f0819 upstream.
In the old Conexant chips (5045, 5047, 5051 and 5066), a single EAPD
may handle both headphone and speaker outputs while it's assigned only
to one of them. Turning off dynamically leads to the unexpected silent
output in such a configuration with the auto-mute function.
Since it's difficult to know how the EAPD is handled in the actual h/w
implementation, better to keep EAPD on while running for such codecs.
commit 6c5c04e509b7000617b09d4301f0b9b6d171d1e6 upstream.
The purpose of this patch is to remove a section of "bad" code that
assigns the last DAC to ports E or F in order to support notebooks
with docking in earlier days, around ALSA 1.0.19 - 21. This is not
necessary now and actually breaks some configurations that use these
ports as other devices. This have been tested on several different
configurations to make sure that it is working for different combinations.
Signed-off-by: Charles Chin <Charles.Chin@idt.com>
This is patch for Conexant codec of Intel HDA driver, adding new quirk
for Lenovo Thinkpad T520 and W520. Conexant autodetection works fine for
T520 (similar subsystem ID is used also in W520 model) and detects more
mixer features compared to generic (fallback) Lenovo quirk with
hardcoded options in Conexant codec.
Patch was activelly tested with Linux 3.0.4, 3.0.6 and 3.0.7 without any
problems.
Signed-off-by: Daniel Suchy <danny@danysek.cz>
Cc: <stable@kernel.org> [3.0+]
The previous fix for the position-buffer check gives yet another
regression on a Dell laptop. The safest fix right now is to add a
static quirk for this device (and better to apply it for stable
kernels too).
Reported-by: Éric Piel <Eric.Piel@tremplin-utc.net>
The commit a810364a0424c297242c6c66071a42f7675a5568
ALSA: hda - Handle -1 as invalid position, too
caused a regression on some machines that require the position-buffer
instead of LPIB, e.g. resulting in noises with mic recording with
PulseAudio.
This patch fixes the detection by delaying the test at the timing as
same as 3.0, i.e. doing the position check only when requested in
azx_position_ok().
Reported-and-tested-by: Rocko Requin <rockorequin@hotmail.com>
The spec->autocfg.line_out_pins[] may contain the same pins as hp_pins[]
depending on the configuration. When they are identical, detecting the
line_jack_present flag screws up the auto-mute because alc_line_automute()
is called unconditionally at initialization while it won't be triggered
by unsol events, thus the old line_jack_present flag is kept for the
whole run.
For fixing this buggy behavior, the driver needs to check whether the
line-outs are really individual, and skip if same as headphone jacks.
Reference: https://bugzilla.novell.com/show_bug.cgi?id=716104
When the headphone pin is assigned as primary output to line_out_pins[],
the automatic HP-pin assignment by ASSID must be suppressed. Otherwise
a wrong pin might be assigned to the headphone and breaks the auto-mute.
This patch is necessary to make internal speakers work on this chip.
Cc: stable@kernel.org
BugLink: http://bugs.launchpad.net/bugs/854468
Tested-by: Alex Wolfson <alex.wolfson@canonical.com>
Commit 9676001559fce06e37c7dc230ab275f605556176
("ALSA: fm801: add error handling if auto-detect fails") seems to
break systems that were previously working without a tuner.
As a bonus, this should fix init and cleanup for the case where the
tuner is explicitly disabled.
Reported-and-tested-by: Hor Jiun Shyong <jiunshyong@gmail.com>
References: http://bugs.debian.org/641946
Cc: stable@kernel.org [v3.0+]
("ALSA: fm801: add error handling if auto-detect fails") added
incorrect error handling.
Once we have successfully called snd_device_new(), the cleanup
function fm801_free() will automatically be called by snd_card_free()
and we must *not* also call fm801_free() directly.
Reported-by: Hor Jiun Shyong <jiunshyong@gmail.com>
When the system has only the headphone and the line-out jacks without
speakers, the current auto-mute code doesn't work. It's because the
spec->automute_lines flag is wrongly referred in update_speakers().
This flag must be meaningless when spec->automute_hp_lo isn't set, thus
they should be always coupled.
The patch fixes the problem and add a comment to indicate the
relationship briefly.
BugLink: http://bugs.launchpad.net/bugs/851697
Reported-by: David Henningsson <david.henningsson@canonical.com>
Tested-By: Jayne Han <jayne.han@canonical.com>
Cc: stable@kernel.org (3.0)
This patch fixes "Surround Speaker Playback Volume" being cut off.
(Commit b4dabfc452a10 was probably meant to fix this, but it fixed
only the "Switch" name, not the "Volume" name.)
The recursive search of widget connections in snd_hda_get_conn_index()
must be terminated at the pin and the audio-out widgets. Otherwise
you'll get "too deep connection" warnings unnecessarily.
Reported-by: Francis Moreau <francis.moro@gmail.com>
Headphones has stopped working for the original reported (a regression
compared to 2.6.38). This is because Speaker and Headphones share the
same DAC, in which case no Headphones volume control was created.
This patch fixes so that both Speaker and Headphones volume
controls are created in such scenario.
BugLink: http://bugs.launchpad.net/bugs/817943
The ADC-switching can work also in the auto-mic mode, too.
When multiple headphones or speakers are assigned but no individual
DACs are available, the driver should take the first HP/SPK DAC instead
of another primary output. The patch adds a bit-flag to dac field of
struct pin_dac_pair indicating that it's a slave DAC.
The internal states, jack_present and line_jack_present should be
updated upon unsolicited events even if no automute is set.
Otherwise the wrong state is referred when the automute behavior is
changed by the mixer control.
When the headphone or speaker output has no own DAC, initialize the path
using the primary DAC. Otherwise the path won't be set properly and
can result in the silence.
snd_hda_get_conn_index() returns a negative value while the current code
stores it in an unsigned int. It must be stored in a signed integer.
Reported-by: Jesper Juhl <jj@chaosbits.net>
Currently HD-audio driver shows the all error ELD byte as an error
in the kernel message. This is annoying when the video driver doesn't
set the correct ELD from the beginning. e.g. radeon sends a zero-byte
data, but we still check ELD with the fixed 128 byte as a workaround
for some broken devices, it spews 128-times errors.
For avoiding this, the driver aborts reading when the first byte is
invalid. In such a case, the whole data is certainly invalid.
The new parser may use "PCM" volume, but it was missing the vmaster
slave list, thus "Master" volume didn't control it.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=41342
Fix the duplicated creation of capture-mixer elements for some static
ALC268 configurations. The capture mixers must be put to cap_mixer field
instead of mixers array.
BugLink: https://bugs.launchpad.net/bugs/826081
The original reporter needs 'Headphone Jack Sense' enabled to have
audible audio, so add his PCI SSID to the whitelist.
Reported-and-tested-by: Muhammad Khurram Khan
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
snd_azf3328_dbgcallenter is called at the very beginning of the function,
so it could be useful to call snd_azf3328_dbgcallleave at all exit points.
In commit 45eebda7, it add new function stac_vrefout_set, but it
is only used in code between CONFIG_SND_HDA_POWER_SAVE macro, so
add the macro to avoid such warning:
sound/pci/hda/patch_sigmatel.c:676:12: warning: 'stac_vrefout_set' defined but not used
Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com>
CONFIG_SND_TEA575X is enabled by RADIO_SF16FMR2, but the latter one is
no PCI device. Since tea575x-tuner itself is independent from the board
bus type, the config should be moved out of SND_PCI dependency.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Use kzalloc rather than kmalloc followed by memset with 0
This considers some simple cases that are common and easy to validate
Note in particular that there are no ...s in the rule, so all of the
matched code has to be contiguous
The semantic patch that makes this output is available
in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
sound/pci/hda/patch_via.c:2087: warning: 'dac' may be used uninitialized in this function
Put the exception checks for io_type switch() for possible mistakes in
future. Also this shuts up annoying compile warnings.
It works fine with auto-parser and now the digital mic workaround was
implemented in auto-parser fixup, let's drop the static model quirks for
these models.
The digital-mic unit on ASUS Eee PC gives PDM signals instead of the
normal stereo PCM, thus you can't record a mono stream from the stereo
stream as is; the summed stereo signal results in almost zero level, and
you'll hear only soft noise.
As a workaround, use ALC269-specific COEF to manipulate the dmic route
for mono, like used for ALC271x. This is implemented as a fix-up, thus
it works only with model=auto or without REALTEK_QUIRKS Kconfig.
Reported-and-tested-by: Pavel Roskin <proski@gnu.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: asihpi - Clarify adapter index validity check
ALSA: asihpi - Don't leak firmware if mem alloc fails
ALSA: rtctimer.c needs module.h
ASoC: Fix txx9aclc.c build
ALSA: hdspm - Add firmware revision 0xcc for RME MADI
ALSA: hdspm - Fix reported external sample rate on RME MADI and MADIface
ALSA: hdspm - Provide MADI speed mode selector on RME MADI and MADIface
ALSA: sound/core/pcm_compat.c: adjust array index
Avoids assigning possibly invalid address to pa, even if it
is never dereferenced.
Correct error response to reflect request object/function ids.
Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com>
We leak the memory allocated to 'firmware' when we fail to
release_firmware() after a kmalloc() failure in hpi_dsp_code_open().
This patch should take care of the leak.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
Apparently, there are multiple old firmware revisions in the wild for
the PCI RME MADI cards. Just add them to the list of supported devices
and treat them like their modern counterparts.
Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
In slave mode, the card can only detect the base frequency (32..48kHz)
on the MADI link (exception: 96k frames), so the real external sample
rate is this base frequency multiplied by 1, 2 or 4 depending on the
speed mode.
This patch enables 64..192kHz sample rates in clock slave mode, which
failed before due to an alleged sample rate mismatch between the MADI
link (e.g., 48kHz) and the application in DS/QS mode (e.g., 96kHz,
192kHz).
When running in slave mode (no clock master), there is no way to
determine the real wirespeed on the MADI link (single/double/quad
speed). Like physical gear, simply provide the user with a tristate
switch to select the appropriate format.
sound: oss: rename local change_bits to avoid powerpc bitsops.h definition
ALSA: hda - Fix duplicated DAC assignments for Realtek
ALSA: asihpi - off by one in asihpi_hpi_ioctl()
ALSA: hda - Fix Oops with Realtek quirks with NULL adc_nids
ALSA: asihpi - bug fix pa use before init.
ALSA: hda - Add support for vref-out based mute LED control on IDT codecs
Convert radio-sf16fmr2 to use generic TEA575x implementation. Most of the
driver code goes away as SF16-FMR2 is basically just a TEA5757 tuner
connected to ISA bus.
The card can optionally be equipped with PT2254A volume control (equivalent
of TC9154AP) - the volume setting is completely reworked (with balance control
added) and tested.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Takashi Iwai <tiwai@suse.de>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits)
ALSA: hda - Cirrus Logic CS421x support
ALSA: Make pcm.h self-contained
ALSA: hda - Allow codec-specific set_power_state ops
ALSA: hda - Add post_suspend patch ops
ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM
ALSA: hda - Make sure mute led reflects master mute state
ALSA: hda - Fix invalid mute led state on resume of IDT codecs
ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver"
ALSA: hda - Add support of the 4 internal speakers on certain HP laptops
ALSA: Make snd_pcm_debug_name usable outside pcm_lib
ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser
ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context.
ASoC: SAMSUNG: Modify I2S driver to support idma
ASoC: davinci: add missing break statement
ASoC: davinci: fix codec start and stop functions
ASoC: dapm - add DAPM macro for external enum widgets
ASoC: Acknowledge WM8962 interrupts before acting on them
ASoC: sgtl5000: guide user when regulator support is needed
ASoC: sgtl5000: refactor registering internal ldo
Copying hp_pins and speaker_pins from line_out_pins may confuse the
parser, and it can lead to duplicated initializations for the same pin
with a wrong DAC assignment. The problem appears in 3.0 kernel code.
Cc: <stable@kernel.org> (for 3.0)
"adapter" is used as an array index in the adapters[] array so
the off by one would make us read past the end.
1c073b67979 "ALSA: asihpi - Remove spurious adapter index check"
reverted Dan Rosenberg's check that would have prevented the
overflow here.
Somce quirk models don't set adc_nids but let the parser filling it.
But the recent code has unnecessary NULL-checks of spec->input_mux,
and it resulted in NULL dereferences.
This patch fixes that regression.
Reported-and-tested-by: Oliver Neukum <oneukum@suse.de>
Fixes bug introduced by 1c073b67.
Also declare pa local to block in which it is used.
