path: root/sound/pci
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] snd-emu10k1: Add support for E-Mu 1616 PCI, 1616M PCI, 0404 PCI, E-MuJames Courtier-Dutton
Notebook. Description: The .device=0x0008 chips have new, but different EMU32 in/out channels. Driver updated to make use of these EMU32 channels. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-14long vs. unsigned long - low-hanging fruits in driversAl Viro
deal with signedness of the stuff passed to set_bit() et.al. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-30V4L/DVB (5899): bttv: Fix Viewcast Osprey 440 supportTrent Piepho
Various gpio and mux settings for the Osprey 440 weren't correct. Fix them and provide some documentation about how the gpios work. The osprey eeprom routine wasn't run for the 440, add it. It was also crap, re-written to be better. Add the Osprey 440 to the Bt878 ALSA driver's whitelist. Currently the sample rate is fixed at 32kHz, as the driver doesn't support different rates for digital input mode, though the card can select the rate from 32, 44.1, or 48 kHz via gpio. Setting the audio gain via ALSA isn't supported yet; a userspace tool that programs the X9221 via i2c-dev must be used. The Bt878 digital audio format isn't programmed correctly for the CS5331A ADC used, resulting in extremely garbled sound. That is fixed in a followup patch. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-20[ALSA] hda-codec - Fix input with STAC92xxTakashi Iwai
The recent fix for STAC92xx surround outputs broke the input pin setting for shared line-in and mic jacks. This patch fixes the breakage. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-intel: support for iMac 24'' released on 09/2006Nicola Fagnani
Basic audio support for the iMac 24'' model released on 09/2006, including headphone jack detection with automatic speaker muting. This iMac uses the Realtek ALC885 codec, not a Sigmatel one as in other models. Functionality has been tested for internal speakers, headphone and microphone. Signed-off-by: Nicola Fagnani <nicfagn@iol.it> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add quirk for Asus P5LD2Claudio Matsuoka
Without the proper model setting, the Asus P5LD2 rear outputs remain completely silent unlike other systems where the front speakers usually work. This patch adds the P5LD2 to the quirk table. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] snd-ca0106: Add support for X-Fi Extreme Audio.James Courtier-Dutton
This card is just a normal SB Live 24bit, but under a different marketing name. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] snd-emu10k1:Enable E-Mu 1616m notebook firmware loading.James Courtier-Dutton
2007-07-20[ALSA] snd-emu10k1: Initial support for E-Mu 1616 and 1616m.James Courtier-Dutton
2007-07-20[ALSA] cs46xx - Fix PM resumeTakashi Iwai
Fixed PM resume of cs46xx devices. It now restores properly the DSP image and kick-off the DSP. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda: Enable SPDIF in/out on some stac9205 boardsMatthew Ranostay
Added support for some boards with SPDIF in/out, and cleaned up the GPIO enable function. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add quirks for HP dx2200/dx2250Claudio Matsuoka
HP dx2200 and dx2250 use Micro-Star International (MSI) motherboards (models MS-7254 and MS-7297 respectively) with an ALC862 codec in threestack configuration. Adding this quirk allows correct 5.1 sound output in these systems. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Rename HP model-specific quirksClaudio Matsuoka
Rename ALC888_HP_NETTLE and ALC888_HP_LUCKNOW models to the more generic names ALC888_6ST_HP and ALC888_3ST_HP since HP seems to be consistent in the wiring of their 3stack and 6stack ALC888-based systems. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add quirk for HP SambaClaudio Matsuoka
This patch fixes 5.1 surround output for the HP Samba using the same quirk as the HP Lucknow. If HP machines are uniform in their wiring, we should rename ALC888_HP_NETTLE to ALC888_6ST_HP and ALC888_HP_LUCKNOW to ALC888_3ST_HP for generic HP 6stack and 3stack configurations. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add LG LW20 line-in capture sourceClaudio Matsuoka
Add line-in to the list of LG LW20 capture sources. Also fix the LG LW pin assignment list comment. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda: stac9202 mixer fixMatthew Ranostay
Added support for line out controls for STAC9202 cards, and fixed issue where master mixer control was being created twice for headphone and speaker outs. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add LG LW20 si3054 modem idClaudio Matsuoka
2007-07-20[ALSA] hda-codec - Add VIA HDA to si3054Claudio Matsuoka
Add VIA HDA identification to use the HDA-based Motorola modem of the Clevo m540 laptop. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] HDA-Intel - Add support for MSI K9AGM2-FIH motherboardTobin Davis
This patch adds support for the MSI K9AGM2-FIH on-board audio. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix default pin config of Abit AW9D-MAXTakashi Iwai
Fix the default pin configuration of Abit AW9D-MAX. The board has a broken BIOS that doesn't set the correct pin default configs, which screws up the auto-configuration of snd-hda-intel driver. The patch enables the override of default pin config values. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix Toshiba A100 with ALC861Takashi Iwai
One of the newly added model entries causes a regression on Toshiba A100. It works fine with model=auto. So, let's deselect the entry again. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-intel - Show the last command in warning messagesTakashi Iwai
Show the last issued command in warning messages when any communication error with CORB/RIRB occurs. Also, a bit code clean-up for composing the command value in *_send_cmd(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix number of pin widgets with STAC codecsTakashi Iwai
Use ARRAY_SIZE() to calculate the number of pin widgets for each codec chip. This also fixes a typo in STAC9205 code that gives a wrong number (14 instead of 12), which resulted in fatal communication errors. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add missing model parameter strings for ALC262Takashi Iwai
Added the missing model option values for ALC262. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add HP Lucknow 5.1 supportClaudio Matsuoka
Added HP Lucknow (ALC888) 5.1 surround support based on ALC883 6-channel threestack with changes in channel routing. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix HP Nettle 5.1 outputClaudio Matsuoka
Fixed HP Nettle 6ch/8ch channel routing based on ALC883 sixstack and swapping rear and center/LFE in verbs and mixer settings. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix the recording selection on VAIO laptopTakashi Iwai
Fix the mismatch of init verb and capture mux with VAIO STAC9872. Also, changed the item names to be more intuitive. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix ALC662 auto modeKailang Yang
Fixed ALC662 auto mode, wrong NIDs were chosen. Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Some fixes for Realtek codec supportsKailang Yang
- Added BenQ T31-16 AMD Turion64x2 (ALC262) support - Added models for ASUS machines with ALC861 Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix 5.1 output in LG LW20Claudio Matsuoka
Implemented LG LW20 5.1 support based on ALC880 threestack modes. It was previously set to use one DAC and 2 jack modes, giving 2-channel output only. Analog CD playing support is still missing. Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] nm256 - Add mention of opl3sa2 to a diagnostic messagePaul Vojta
Adds mention of opl3sa2 driver to a diagnostic message for NeoMagic nm256 driver. Signed-off-by: Paul Vojta <vojta@math.berkeley.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add support for HP NettleClaudio Matsuoka
Added the model for HP Nettle mobo with ALC883. From: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add support for HP SpartanClaudio Matsuoka
Added the model for HP Spartan with Conexant codec chip. From: Claudio Matsuoka <cmatsuoka@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix the error in DAC assignment of STAC codecTakashi Iwai
The STAC codec support code has the automatic recognition of additional side-output pins, and this may result in an error when the assigned pin has no corresponding DAC connection. The patch fixes the problem -- it corrects the line_outs again without such additional pins. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] sound/pci/hda/patch_realtek.c: remove dead codeAdrian Bunk
This patch removes some dead code spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] fix ensoniq section mismatchRandy Dunlap
Fix ensoniq driver sections when HOTPLUG=n, but code is used during resume, so it cannot be discarded: WARNING: sound/pci/snd-ens1371.o(.text+0x5c0): Section mismatch: reference to .init.text: (between 'snd_ensoniq_chip_init' and 'snd_ensoniq_free') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] HDA - Change default configuration for Fujitsu Si3515Tobin Davis
This patch changes the default configuration for the Fujitsu Siemens Si3515 Laptop to the correct model=laptop. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda: support for S/PDIF out on ASUS M2VMike Crash
Added support for S/PDIF digital output on ASUS M2V motheboard - added new model '3stack-660-digout' and ALC660VD_3ST_DIG Signed-off-by: Mike Crash <mike@mikecrash.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Fix invalid schedule_timeout_interruptible()Takashi Iwai
Fixed the invalid use of schedule_timeout_interruptible() without checking pending signals. Simply replaced with schedule_timeout(). Suggestions thanks to Jeff Garzik. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add AD1882 codec supportTakashi Iwai
Added AD1882 codec support. It has currently two models, 3stack and 6stack. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Output MFG information for HDA devicesJonathan Phenix
This patch output information about the MFG (Modem Function Group) to the /proc/asound/card?/codec#? file. This information is important to identify if a HDA device has a modem or not. Signed-off-by: Jonathan Phenix <jonathan@linuxant.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda: add eapd support to additional idt codecsMatthew Ranostay
Added support for EAPD on the 927x, and 9227-8 IDT HDA codecs. Enabling EAPD powers the internal speaker amp otherwise there is no sound on systems with an internal amp. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add model dell for Dell XPS M1210Takashi Iwai
Added a new model 'dell' for Dell XPS M1210 with STAC922x codec chip. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add Fujitsu Siemens v3515 support to patch_conexantTobin Davis
This patch adds support for the Fujitsu Seimens Amilo Pro v3515 notebook. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Fix ALC662 auto-configuration codeTakashi Iwai
The auto-configuration code didn't initialize the verbs correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add model for Toshiba A135Takashi Iwai
Added model=lenovo for Toshiba A135 with ALC861VD codec. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] hda-codec - Add HP Pavillion quirk to Realtek codeTobin Davis
This patch adds the HP Pavillion a1589L desktop system to the ALC883 configuration table. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] ali5451 warning fixAndrew Morton
sound/pci/ali5451/ali5451.c: In function 'snd_ali_prepare': sound/pci/ali5451/ali5451.c:716: warning: 'R2' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] emu10k1 - EMU 1212 with 16 capture channelsPavel Hofman
* adding 8 more 32-bit capture channels (total of 16) for emu1010 cards * adding some code comments and card details description Signed-off-by: Pavel Hofman <dustin@seznam.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
