commit a8f20fd25bdce81a8e41767c39f456d346b63427 upstream.
Recently we met a problem, the codec has valid adcs and input pins,
and they can form valid input paths, but the driver does not build
valid controls for them like "Mic boost", "Capture Volume" and
"Capture Switch".
Through debugging, I found the driver needs to shrink the invalid
adcs and input paths for this machine, so it will move the whole
column bitmap value to the previous column, after moving it, the
driver forgets to set the original column bitmap value to zero, as a
result, the driver will invalidate the path whose index value is the
original colume bitmap value. After executing this function, all
valid input paths are invalidated by a mistake, there are no any
valid input paths, so the driver won't build controls for them.
Fixes: 3a65bcdc577a ("ALSA: hda - Fix inconsistent input_paths after ADC reduction")
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit d94815f917da770d42c377786dc428f542e38f71 upstream.
azx_codec_configure() loops over the codecs found on the given
controller via a linked list. The code used to work in the past, but
in the current version, this may lead to an endless loop when a codec
binding returns an error.
The culprit is that the snd_hda_codec_configure() unregisters the
device upon error, and this eventually deletes the given codec object
from the bus. Since the list is initialized via list_del_init(), the
next object points to the same device itself. This behavior change
was introduced at splitting the HD-audio code code, and forgotten to
adapt it here.
For fixing this bug, just use a *_safe() version of list iteration.
Fixes: d068ebc25e6e ("ALSA: hda - Move some codes up to hdac_bus struct")
Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 1fc2e41f7af4572b07190f9dec28396b418e9a36 upstream.
This model is actually called 92XXM2-8 in Windows driver. But since pin
configs for M22 and M28 are identical, just reuse M22 quirk.
Fixes external microphone (tested) and probably docking station ports
(not tested).
Signed-off-by: Alexander Tsoy <alexander@tsoy.me>
commit ab949d519601880fd46e8bc1445d6a453bf2dc09 upstream.
Imre Deak reported a deadlock of HD-audio driver at unbinding while
it's still in probing. Since we probe the codecs asynchronously in a
work, the codec driver probe may still be kicked off while the
controller itself is being unbound. And, azx_remove() tries to
process all pending tasks via cancel_work_sync() for fixing the other
races (see commit [0b8c82190c12: ALSA: hda - Cancel probe work instead
of flush at remove]), now we may meet a bizarre deadlock:
Unbind snd_hda_intel via sysfs:
device_release_driver() ->
device_lock(snd_hda_intel) ->
azx_remove() ->
cancel_work_sync(azx_probe_work)
azx_probe_work():
codec driver probe() ->
__driver_attach() ->
This deadlock is caused by the fact that both device_release_driver()
and driver_probe_device() take both the device and its parent locks at
the same time. The codec device sets the controller device as its
parent, and this lock is taken before the probe() callback is called,
while the controller remove() callback gets called also with the same
lock.
In this patch, as an ugly workaround, we unlock the controller device
temporarily during cancel_work_sync() call. The race against another
bind call should be still suppressed by the parent's device lock.
Reported-by: Imre Deak <imre.deak@intel.com>
Fixes: 0b8c82190c12 ("ALSA: hda - Cancel probe work instead of flush at remove")
commit 2f726aec19a9d2c63bec9a8a53a3910ffdcd09f8 upstream.
On this Dell AIO machine, the lineout jack does not work.
We found the pin 0x1a is assigned to lineout on this machine, and in
the past, we applied ALC298_FIXUP_DELL1_MIC_NO_PRESENCE to fix the
heaset-set mic problem for this machine, this fixup will redefine
the pin 0x1a to headphone-mic, as a result the lineout doesn't
work anymore.
After consulting with Dell, they told us this machine doesn't support
microphone via headset jack, so we add a new fixup which only defines
the pin 0x18 as the headset-mic.
[rearranged the fixup insertion position by tiwai in order to make the
merge with other branches easier -- tiwai]
Fixes: 59ec4b57bcae ("ALSA: hda - Fix headset mic detection problem for two dell machines")
commit 3f307834e695f59dac4337a40316bdecfb9d0508 upstream.
A new Dell laptop needs to apply ALC269_FIXUP_DELL1_MIC_NO_PRESENCE to
fix the headset problem, and the pin definiton of this machine is not
in the pin quirk table yet, now adding it to the table.
commit f363a06642f28caaa78cb6446bbad90c73fe183c upstream.
In the commit [15c75b09f8d1: ALSA: ctxfi: Fallback DMA mask to 32bit],
I forgot to put "!" at dam_set_mask() call check in cthw20k1.c (while
cthw20k2.c is OK). This patch fixes that obvious bug.
(As a side note: although the original commit was completely wrong,
it's still working for most of machines, as it sets to 32bit DMA mask
in the end. So the bug severity is low.)
Fixes: 15c75b09f8d1 ("ALSA: ctxfi: Fallback DMA mask to 32bit")
commit 29693efcea0f38cf40d0055d2401490a4f9bf8be upstream.
On this machine, the micmute button is connected to Line2 of the
codec and the micmute led is connected to GPIO2 of the codec.
After applying this quirk, both hotkey and led work well.
commit 493de342748cc6f52938096f5480cf291da58a0b upstream.
Dell Inspiron 17 7000 Gaming laptop needs a similar quirk like
Inspiron 7599 to support its subwoofer speaker.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=194191
commit 15c75b09f8d190f89ab4db463b87d411ca349dfe upstream.
Currently ctxfi driver tries to set only the 64bit DMA mask on 64bit
architectures, and bails out if it fails. This causes a problem on
some platforms since the 64bit DMA isn't always guaranteed. We should
fall back to the default 32bit DMA when 64bit DMA fails.
Fixes: 6d74b86d3c0f ("ALSA: ctxfi - Allow 64bit DMA")
commit e7480b34ad1ab84a63540b2c884cb92c0764ab74 upstream.
Like for Sunrise Point, the total stream number of Lewisburg's
input and output stream exceeds 15 (GCAP is 0x9701), which will
cause some streams do not work because of the overflow on
SDxCTL.STRM field if using the legacy stream tag allocation method.
Fixes: 5cf92c8b3dc5 ("ALSA: hda - Add Intel Lewisburg device IDs Audio")
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 9f1bc2c4c58fcb2d86e0e26437dc8f3a18ac3276 upstream.
The issue is the same as "dd9aa335c880 ALSA: hda/realtek - Can't adjust
speaker's volume on a Dell AIO", the output requires to connect to a node
with Amp-out capability.
Applying the same fixup "ALC298_FIXUP_SPK_VOLUME" can fix the issue.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit af677166cf63c179dc2485053166e02c4aea01eb upstream.
Without this change, the HDMI/DP codec will be recognised as a
generic codec, and there is no sound when playing through this codec.
As suggested by NVidia side, after adding the new ID in the driver,
the sound playing works well.
commit c7efff9284dfde95a11aaa811c9d8ec8167f0f6e upstream.
Although the old quirk table showed ASUS X71SL with ALC663 codec being
compatible with asus-mode3 fixup, the bugzilla reporter explained that
asus-model8 fits better for the dual headphone controls. So be it.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=191781
commit 85bcf96caba8b4a7c0805555638629ba3c67ea0c upstream.
ASUS ROG Ranger VIII with ALC1150 codec requires the extra GPIO pin to
up for the front panel. Just use the existing fixup for setting up
the GPIO pins.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=189411
commit 5e0ad0d8747f3e4803a9c3d96d64dd7332506d3c upstream.
Commit [64047d7f4912 ALSA: hda - ignore the assoc and seq when comparing
pin configurations] intented to ignore both seq and assoc at pin
comparing, but it only ignored seq. So that commit may still fail to
match pins on some machines.
Change the bitmask to also ignore assoc.
v2: Use macro to do bit masking.
Thanks to Hui Wang for the analysis.
Fixes: 64047d7f4912 ("ALSA: hda - ignore the assoc and seq when comparing...")
commit f73cd43ac3b41c0f09a126387f302bbc0d9c726d upstream.
HP Z1 Gen3 AiO with Conexant codec doesn't give an unsolicited event
to the headset mic pin upon the jack plugging, it reports only to the
headphone pin. It results in the missing mic switching. Let's fix up
by simply gating the jack event.
commit 989dbe4a30728c047316ab87e5fa8b609951ce7c upstream.
This group of new pins is not in the pin quirk table yet, adding
them to the pin quirk table to fix the headset-mic problem.
commit 64047d7f4912de1769d1bf0d34c6322494b13779 upstream.
More and more pin configurations have been adding to the pin quirk
table, lots of them are only different from assoc and seq, but they
all apply to the same QUIRK_FIXUP, if we don't compare assoc and seq
when matching pin configurations, it will greatly reduce the pin
quirk table size.
We have tested this change on a couple of Dell laptops, it worked
well.
commit b5337cfe067e96b8a98699da90c7dcd2bec21133 upstream.
I'm using an Alienware 15 R2 and had to use the alienware quirks to
get my headphone output working.
I fixed it by adding, SND_PCI_QUIRK(0x1028, 0x0708, "Alienware 15 R2
2016", QUIRK_ALIENWARE) to the patch.
Signed-off-by: Sven Hahne <hahne@zeitkunst.eu>
The commit [1a3f099101b8: ALSA: hda - Fix surround output pins for
ASRock B150M mobo] introduced a fixup of pin configs for ASRock
mobos to fix the surround outputs. However, this overrides the pin
configs of the mic pins as if they are outputs-only, effectively
disabling the mic inputs. Of course, it's a regression wrt mic
functionality.
Actually the pins 0x18 and 0x1a don't need to be changed; we just need
to disable the bogus pins 0x14 and 0x15. Then the auto-parser will
pick up mic pins as switchable and assign the surround outputs there.
This patch removes the incorrect pin overrides of NID 0x18 and 0x1a
from the ASRock fixup.
Fixes: 1a3f099101b8 ('ALSA: hda - Fix surround output pins for ASRock...')
Reported-and-tested-by: Vitor Antunes <vitor.hda@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=187431
Cc: <stable@vger.kernel.org>
Latest Thinkpad laptops use the HKEY_HID LEN0268 instead of the
LEN0068, as a result neither audio mute led nor mic mute led can work
any more.
After adding the new HKEY_HID into the is_thinkpad(), both of them
works well as before.
ASRock B150M Pro4/D3 mobo with ALC892 codec doesn't seem to provide
proper pins for the surround outputs, hence we need to specify the
pincfgs manually with a couple of other corrections.
Reported-and-tested-by: Benjamin Valentin <benpicco@googlemail.com>
They uses the codec ALC255, and have the different pin cfg definition
from the ones in the existing pin quirk table. Now adding them into
the table to fix the problem.
Cc: stable@vger.kernel.org
Some elements in hr are not cleared before being copied to user space,
leaking kernel heap memory to user space. For example, this happens in
the error handling code for the HPI_ADAPTER_DELETE case. Zero the memory
before it's copied.
Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net>
We have a new Dell laptop model which uses ALC295, the pin definition
is different from the existing ones in the pin quirk table, to fix the
headset mic detection and mic mute led's problem, we need to add the
new pin defintion into the pin quirk table.
Commit 49d9e77e72cf ("ALSA: hda - Fix system panic when DMA > 40 bits
for Nvidia audio controllers") simply disabled any DMA exceeding 32
bits for NVidia devices, even though they are capable of performing
DMA up to 40 bits. On some architectures (such as arm64), system memory
is not guaranteed to be 32-bit addressable by PCI devices, and so this
change prevents NVidia devices from working on platforms such as AMD
Seattle.
Since the original commit already mentioned that up to 40 bits of DMA
is supported, and given that the code has been updated in the meantime
to support a 40 bit DMA mask on other devices, revert commit 49d9e77e72cf
and explicitly set the DMA mask to 40 bits for NVidia devices.
Fixes: 49d9e77e72cf ('ALSA: hda - Fix system panic when DMA > 40 bits...')
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
On a Dell laptop, there is no global adcs for all input devices, so
the input devices use the different adc, as a result, dyn_adc_switch
is set to true.
In this situation, it is safe to control the micmute led according to
user's choice of muting/unmuting the current input device, since only
current input device path is active, while other input device paths
are inactive and powered down.
Fixes: 00ef99408b6c ('ALSA: hda - add mic mute led hook for dell machines')
HP Spectre x360 with CX20724 codec has two speaker outputs while the
BIOS sets up only the bottom one (NID 0x17) and disables the top one
(NID 0x1d).
This patch adds a fixup simply defining the proper pincfg for NID 0x1d
so that the top speaker works as is.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=169071
We have two new Dell laptop models, they have the same ALC255 pin
definition, but not in the pin quirk table yet, as a result, the
headset microphone can't work. After adding the definition in the
table, the headset microphone works well.
The pointer callbacks of ali5451 driver may return the value at the
boundary occasionally, and it results in the kernel warning like
snd_ali5451 0000:00:06.0: BUG: , pos = 16384, buffer size = 16384, period size = 1024
It seems that folding the position offset is enough for fixing the
warning and no ill-effect has been seen by that.
Reported-by: Enrico Mioso <mrkiko.rs@gmail.com>
Tested-by: Enrico Mioso <mrkiko.rs@gmail.com>
Trival fix, the dev_err message is missing a \n so add it.
For structure types defined in the same file or local header files, find
top-level static structure declarations that have the following
properties:
1. Never reassigned.
2. Address never taken
3. Not passed to a top-level macro call
4. No pointer or array-typed field passed to a function or stored in a
variable.
Declare structures having all of these properties as const.
Done using Coccinelle.
Based on a suggestion by Joe Perches <joe@perches.com>.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Back-merge from for-linus just to make the further development easier.
One of the laptops has the codec ALC256 on it, applying the
ALC255_FIXUP_DELL1_MIC_NO_PRESENCE can fix the problem, the rest
of laptops have the codec ALC295 on them, they are similar to machines
with ALC225, applying the ALC269_FIXUP_DELL1_MIC_NO_PRESENCE can fix
the problem.
Realtek codec driver expects an implicit rule where either the codec
SSID or the pincfg NID 0x1d contains the some information encoded in
some bits. One of the expected information is there is the
availability of PC beep, and the driver doesn't build up the PC beep
control if this is *supposed* to be disabled there.
Meanwhile, Lenovo doesn't seem to follow this requirement (yes it's
non-standard after all), and the BIOS sets just the normal SSID and
the pincfg values. This resulted in the lack of PC beep on a few
machines, purely with a lucky or unlucky number. It didn't bother
most people, but some people still demand the PC beep, as found in bug
reports.
This patch just adds the fixup chain to Lenovo machines to skip the
SKU checks. Then the beep control will show up in the mixer, and user
can still decide to enable / disable it via the standard mixer
interface.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=156311
Remove unneeded variables and assignments.
Check for snd_pcm_ops structures that are only stored in the ops field of a
snd_soc_platform_driver structure or passed as the third argument to
snd_pcm_set_ops. The corresponding field or parameter is declared const,
so snd_pcm_ops structures that have this property can be declared as const
also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_pcm_ops i@p = { ... };
@ok1@
identifier r.i;
struct snd_soc_platform_driver e;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
snd_pcm_set_ops(e1, e2, &i@p)
@bad@
position p != {r.p,ok1.p,ok2.p};
identifier r.i;
struct snd_pcm_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct snd_pcm_ops i = { ... };
// </smpl>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
also.
// <smpl>
identifier i;
position p;
@ok1@
identifier r.i;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2;
position p;
@bad@
identifier r.i;
e@i@p
identifier r.i;
static
+const
// </smpl>
Trivial fix to typos dev_dbg messages and comment.
The subwoofer on Inspiron 7559 was disabled originally.
Applying a pin fixup to node 0x1b can enable it and make it work.
Old pin: 0x411111f0
New pin: 0x90170151
This patch enables headset microphone on some variants of
Dell Inspiron 5468. (Dell SSID 0x07ad)
BugLink: https://bugs.launchpad.net/bugs/1617900
Signed-off-by: Shrirang Bagul <shrirang.bagul@canonical.com>
MSI Cubi MS-B120 needs the same fixup as the Gigabyte BXBT-2807 for its
mic to work.
They both use a single 3-way jack for both mic and headset with an
ALC283 codec, with the same pins used.
Cc: Daniel Drake <drake@endlessm.com>
Signed-off-by: Anisse Astier <anisse@astier.eu>
Trivial fix to spelling mistake in dev_warn message.
For SKL and later Intel chips, we control the power well per codec
basis via link_power callback since the commit [03b135cebc47: ALSA:
hda - remove dependency on i915 power well for SKL].
However, there are a few exceptional cases where the gfx registers are
accessed from the audio driver: namely the wakeup override bit
toggling at (both system and runtime) resume. This seems causing a
kernel warning when accessed during the power well down (and likely
resulting in the bogus register accesses).
This patch puts the proper power up / down sequence around the resume
code so that the wakeup bit is fiddled properly while the power is
up. (The other callback, sync_audio_rate, is used only in the PCM
callback, so it's guaranteed in the power-on.)
Also, by this proper power up/down, the instantaneous flip of wakeup
bit in the resume callback that was introduced by the commit
[033ea349a7cd: ALSA: hda - Fix Skylake codec timeout] becomes
superfluous, as snd_hdac_display_power() already does it. So we can
clean it up together.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96214
Fixes: 03b135cebc47 ('ALSA: hda - remove dependency on i915 power well for SKL')
Cc: <stable@vger.kernel.org> # v4.2+
Tested-by: Hans de Goede <hdegoede@redhat.com>
The HDA controller from SKL onwards support additional timestamp
reporting of the link time. The link time is read from HW
registers and converted to audio values.
Signed-off-by: Guneshwor Singh <guneshwor.o.singh@intel.com>
Signed-off-by: Hardik T Shah <hardik.t.shah@intel.com>
