path: root/sound/ppc/Makefile
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-07-20[ALSA] Add PS3 sound driverMasakazu Mokuno
The patch adds the support for the sound feature of PS3 - the digital output of HDMI and SPDIF optical, and the analog output of AV multi. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] snd-powermac: no longer handle anything with a layout-id propertyJohannes Berg
This patch removes from snd-powermac the code that check for the layout-id and instead adds code that makes it refuse loading when a layout-id property is present, nothing that snd-aoa should be used. It also removes the 'toonie' codec from snd-powermac which was only ever used on the mac mini which has a layout-id property. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-01[PATCH] ppc32: add sound support for Mac MiniBenjamin Herrenschmidt
This patch applies on top of my previous g5 related sound patches and adds support for the Mac Mini to the PowerMac Alsa driver. However, I haven't found any kind of HW support for volume control on this machine. If it exist, it's well hidden. That means that you probably want to make sure you use software with the ability to do soft volume control, or use Alsa 0.9 pre-release with the softvol plugin. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
