path: root/sound/ppc/beep.c
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] powermac - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in snd-powermac driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10Input: ppc-beep - switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion, switch to using input_dev->dev.parent when specifying device position in sysfs tree. Also, do not access input_dev->private directly, use helpers. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-09-23[ALSA] ppc-beep - handle errors from input_register_device()Dmitry Torokhov
ppc-beep: handle errors from input_register_device() (Also fixed the wrong memory release in the error path.) Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-03[ALSA] Remove xxx_t typedefs: PowerMacTakashi Iwai
Remove xxx_t typedefs from the PowerMac driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove obsolete chip_tTakashi Iwai
Modules: Documentation,MIPS AU1x00 driver,PPC Beep,SPARC DBRI driver Removed the use of chip_t, which was obsoleted. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-10-28[PATCH] Input: convert sound/ppc/beep to dynamic input_dev allocationDmitry Torokhov
Input: convert sound/ppc/beep to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-16[PATCH] ppc64: very basic desktop g5 sound supportBenjamin Herrenschmidt
This patch hacks the current PowerMac Alsa driver to add some basic support of analog sound output to some desktop G5s. It has severe limitations though: - Only 44100Khz 16 bits - Only work on G5 models using a TAS3004 analog code, that is early single CPU desktops and all dual CPU desktops at this date, but none of the more recent ones like iMac G5. - It does analog only, no digital/SPDIF support at all, no native AC3 support Better support would require a complete rewrite of the driver (which I am working on, but don't hold your breath), to properly support the diversity of apple sound HW setup, including dual codecs, several i2s busses, all the new codecs used in the new machines, proper clock switching with digital, etc etc etc... This patch applies on top of the other PowerMac sound patches I posted in the past couple of days (new powerbook support and sleep fixes). Note: This is a FAQ entry for PowerMac sound support with TI codecs: They have a feature called "DRC" which is automatically enabled for the internal speaker (at least when auto mute control is enabled) which will cause your sound to fade out to nothing after half a second of playback if you don't set a proper "DRC Range" in the mixer. So if you have a problem like that, check alsamixer and raise your DRC Range to something reasonable. Note2: This patch will also add auto-mute of the speaker when line-out jack is used on some earlier desktop G4s (and on the G5) in addition to the headphone jack. If that behaviour isn't what you want, just disable auto-muting and use the manual mute controls in alsamixer. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
