path: root/sound/ppc/daca.c
2009-06-03ALSA: sound/ppc: update annotations of serveral functionsStephen Rothwell
[I am not sure if this is the correct approach as I don't know if any of this actual hardware or drivers are really hot pluggable.] Gets rid of these build warnings: WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x5c): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_new() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_new(). If .snd_pmac_new is only used by .snd_pmac_probe then annotate .snd_pmac_new with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x10c): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_burgundy_init() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_burgundy_init(). If .snd_pmac_burgundy_init is only used by .snd_pmac_probe then annotate .snd_pmac_burgundy_init with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x164): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_daca_init() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_daca_init(). If .snd_pmac_daca_init is only used by .snd_pmac_probe then annotate .snd_pmac_daca_init with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x1dc): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_tumbler_init() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_tumbler_init(). If .snd_pmac_tumbler_init is only used by .snd_pmac_probe then annotate .snd_pmac_tumbler_init with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x1ec): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_tumbler_post_init() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_tumbler_post_init(). If .snd_pmac_tumbler_post_init is only used by .snd_pmac_probe then annotate .snd_pmac_tumbler_post_init with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x28c): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_awacs_init() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_awacs_init(). If .snd_pmac_awacs_init is only used by .snd_pmac_probe then annotate .snd_pmac_awacs_init with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x2bc): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_pcm_new() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_pcm_new(). If .snd_pmac_pcm_new is only used by .snd_pmac_probe then annotate .snd_pmac_pcm_new with a matching annotation. WARNING: sound/ppc/snd-powermac.o(.devinit.text+0x2f8): Section mismatch in reference from the function .snd_pmac_probe() to the function .init.text:.snd_pmac_attach_beep() The function __devinit .snd_pmac_probe() references a function __init .snd_pmac_attach_beep(). If .snd_pmac_attach_beep is only used by .snd_pmac_probe then annotate .snd_pmac_attach_beep with a matching annotation. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-09ALSA: powermac - Add missing KERN_* prefix to printkTakashi Iwai
2008-07-10ALSA: remove CONFIG_KMOD from soundJohannes Berg
A bunch of things in alsa depend on CONFIG_KMOD, use CONFIG_MODULES instead where the dependency is needed at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-02-14Dont touch fs_struct in driversJan Blunck
The sound drivers and the pnpbios core test for current->root != NULL. This test seems to be unnecessary since we always have rootfs mounted before initializing the drivers. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] powermac - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in snd-powermac driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
sound: Conversions from kmalloc+memset to k(c|z)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-04-21[PATCH] powerpc: fix oops in alsa powermac driverBenjamin Herrenschmidt
This fixes an oops in 2.6.16.X when loading the snd_powermac module. The name of the requested module changed during the 2.6.16 development cycle from i2c-keylargo to i2c-powermac. Signed-off-by: Guido Guenther <agx@sigxcpu.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-23[PATCH] I2C: Drop unneeded i2c-dev.h includesJean Delvare
Several media/video and sound drivers include i2c-dev.h while they don't need it at all. Clean it up. This header file is really only needed by i2c-dev.c and compat_ioctl.c, other drivers should never need it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PowerMacTakashi Iwai
Remove xxx_t typedefs from the PowerMac driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-27[PATCH] ppc32: Remove CONFIG_PMAC_PBOOKBenjamin Herrenschmidt
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some powerbooks have, CONFIG_PM for power management related code, and just left out of any CONFIG_* option for some generally useful stuff that can be used on non-laptops as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
