path: root/sound/ppc/powermac.c
2009-04-06ALSA: move snd_powermac's probe function to .devinit.textUwe Kleine-König
A pointer to snd_pmac_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (when having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Rene Herman <rene.herman@keyaccess.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-24Merge branch 'topic/powermac' into for-linusTakashi Iwai
2009-03-09ALSA: powermac - Add missing KERN_* prefix to printkTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2006-08-03[ALSA] make snd-powermac load even when it can't bind the deviceJohannes Berg
This patch makes snd-powermac load when it can't bind the device right away. That's the expected behaviour for hotplugging, but fixes an important problem I was seeing with doing a modprobe snd-powermac with a version that refuses loading on machines with layout-id: snd-powermac would create a bunch of uevents and then refuse to load, the uevents causing udev to reload it again, ad eternum. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] snd-powermac: no longer handle anything with a layout-id propertyJohannes Berg
This patch removes from snd-powermac the code that check for the layout-id and instead adds code that makes it refuse loading when a layout-id property is present, nothing that snd-aoa should be used. It also removes the 'toonie' codec from snd-powermac which was only ever used on the mac mini which has a layout-id property. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
This second one unregisters the platform device again when the probe is unsuccesful for sound/drivers, sound/arm/sa11xx-uda1341.c and sound/ppc/powermac.c. This gets them all. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] powermac - Use platform_deviceTakashi Iwai
Modules: PPC,PPC PMAC driver,PPC PowerMac driver Rewrite the probe/remove with platform_device. Move the PM support to platform_device's callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PowerMacTakashi Iwai
Remove xxx_t typedefs from the PowerMac driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() callTakashi Iwai
ARM,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,MIPS MIPS AU1x00 driver,PPC,PPC PowerMac driver,SPARC,SPARC AMD7930 driver SPARC cs4231 driver,SPARC DBRI driver - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-01[PATCH] ppc32: add sound support for Mac MiniBenjamin Herrenschmidt
This patch applies on top of my previous g5 related sound patches and adds support for the Mac Mini to the PowerMac Alsa driver. However, I haven't found any kind of HW support for volume control on this machine. If it exist, it's well hidden. That means that you probably want to make sure you use software with the ability to do soft volume control, or use Alsa 0.9 pre-release with the softvol plugin. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
