path: root/sound/ppc/snd_ps3.c
2011-01-03Fix spelling milisec -> ms in snd_ps3 module parameter descriptionStefan Weil
Instead of replacing 'milisec' by 'millisec', I decided to use the more common SI unit. Other drivers use 'milliseconds' or 'ms', too ('millisec' is never used). Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-13sound: Remove pr_<level> uses of KERN_<level>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-10ALSA: sound/ps3: Correct existing and add missing annotationsGeert Uytterhoeven
probe functions should be __devinit Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10ALSA: sound/ps3: Restructure driver sourceGeert Uytterhoeven
Sort includes, and reorder code so we can kill the forward declarations No functional changes Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-10ALSA: sound/ps3: Fix checkpatch issuesGeert Uytterhoeven
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-01-16powerpc/ps3: Printing fixups for l64 to ll64 conversion sound/ppcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ALSA: ps3: Add support for SPDIF/HDMI passthruTakashi Iwai
Add support for SPDIF/HDMI pass-through support of PS3 audio driver. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-21ALSA: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Add missing device linkTakashi Iwai
Added the missing link to struct device from the card instance. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Clean up duplicate includes in sound/ppc/Jesper Juhl
This patch cleans up duplicate includes in sound/ppc/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add PS3 sound driverMasakazu Mokuno
The patch adds the support for the sound feature of PS3 - the digital output of HDMI and SPDIF optical, and the analog output of AV multi. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
