path: root/sound/ppc
2015-01-28ALSA: Include linux/io.h instead of asm/io.hTakashi Iwai
Nowadays it's recommended. Replace all in a shot. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-01-04ALSA: Deletion of checks before the function call "iounmap"Markus Elfring
The iounmap() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-01-02ALSA: ps3: Remove unnecessary snd_pcm_lib_preallocate_free_for_all()Lars-Peter Clausen
The ALSA core takes care that all preallocated memory is freed when the card (and the PCM) itself is freed. There is no need to do this manually in the driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-17ALSA: powermac: Deletion of an unnecessary check before the function call ↵Markus Elfring
"pci_dev_put" The pci_dev_put() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-21ALSA: ppc: Use snd_ctl_enum_info()Takashi Iwai
... and reduce the open codes. Also add missing const to the text array. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-20ALSA: ppc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-26of: Migrate of_find_node_by_name() users to for_each_node_by_name()Grant Likely
There are a bunch of users open coding the for_each_node_by_name() by calling of_find_node_by_name() directly instead of using the macro. This is getting in the way of some cleanups, and the possibility of removing of_find_node_by_name() entirely. Clean it up so that all the users are consistent. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Takashi Iwai <tiwai@suse.de>
2014-02-14ALSA: ppc: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-18Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c changes from Wolfram Sang: - new drivers for exynos5, bcm kona, and st micro - bigger overhauls for drivers mxs and rcar - typical driver bugfixes, cleanups, improvements - got rid of the superfluous 'driver' member in i2c_client struct This touches a few drivers in other subsystems. All acked. * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits) i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe() i2c: i2c-eg20t: do not print error message in syslog if no ACK received i2c: bcm-kona: Introduce Broadcom I2C Driver i2c: cbus-gpio: Fix device tree binding i2c: wmt: add missing clk_disable_unprepare() on error i2c: designware: add new ACPI IDs i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH i2c: exynos5: Remove incorrect clk_disable_unprepare i2c: i2c-st: Add ST I2C controller i2c: exynos5: add High Speed I2C controller driver i2c: rcar: fixup rcar type naming i2c: scmi: remove some bogus NULL checks i2c: sh_mobile & rcar: Enable the driver on all ARM platforms i2c: sh_mobile: Convert to clk_prepare/unprepare i2c: mux: gpio: use reg value for i2c_add_mux_adapter i2c: mux: gpio: use gpio_set_value_cansleep() i2c: Include linux/of.h header i2c: mxs: Fix PIO mode on i.MX23 i2c: mxs: Rework the PIO mode operation i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller ...
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-11-06ALSA: ps3: Use WARN_ON() instead of BUG_ON()Takashi Iwai
BUG_ON() is rather useless for debugging as it leads to panic(). Use WARN_ON() and handle the error cases accordingly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-10-03ALSA: ppc: keywest: Don't use i2c_client->driverLars-Peter Clausen
The 'driver' field of the i2c_client struct is redundant and is going to be removed. Use 'to_i2c_driver(client->dev.driver)' instead to get direct access to the i2c_driver struct. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-05-23ALSA: powermac: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: ppc: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: sound/ps3: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Geoff Levand <geoff@infradead.org> Cc: linuxppc-dev@lists.ozlabs.org Cc: cbe-oss-dev@lists.ozlabs.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/ppc/snd_ps3.c: fix error return codeJulia Lawall
Initialize ret before returning on failure, as done elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-09ALSA: platform: Check CONFIG_PM_SLEEP instead of CONFIG_PMTakashi Iwai
When CONFIG_PM is set but CONFIG_PM_SLEEP is unset, SIMPLE_DEV_PM_OPS() ignores the given functions, and this leads to compile warnings. For avoiding this, simply check CONFIG_PM_SLEEP instead of CONFIG_PM. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-03ALSA: convert PM ops of platform_driver to new pm opsTakashi Iwai
2012-07-02ALSA: Add missing .owner=THIS_MODULE to platform_driver definitionsTakashi Iwai
2012-01-12Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-08powerpc/ps3: Fix lv1_gpu_attribute hcallGeoff Levand
The lv1_gpu_attribute hcall takes three, not five input arguments. Adjust the lv1 hcall table and all calls. Signed-off-by: Geoff Levand <geoff@infradead.org> CC: Takashi Iwai <tiwai@suse.de> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-12ALSA: keywest: Remove obsolete cleanup for clientdataAxel Lin
The i2c core will clear the clientdata pointer automatically. We don't have to set the `data' field to NULL in remove() or if probe() failed anymore. Signed-off-by: Axel Lin <axel.lin@gmail.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-04-22ALSA: powermac - Correct lineout detection on PowerMac G4 DARisto Suominen
Correct lineout (Pro Speaker) detection on PowerMac G4 Digital Audio (Tumbler). Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-28ALSA: powermac - Allow input from microphone on TumblerRisto Suominen
Allow input from microphone on remaining PowerBooks and iBooks with Tumbler. Tested only with PowerBook G4 Gigabit Ethernet (PowerBook3,3). [Fixed to use of_machine_is_compatible by tiwai] Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-03Fix spelling milisec -> ms in snd_ps3 module parameter descriptionStefan Weil
Instead of replacing 'milisec' by 'millisec', I decided to use the more common SI unit. Other drivers use 'milliseconds' or 'ms', too ('millisec' is never used). Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-22ALSA: sound/ppc: Use printf extension %pR for struct resourceJoe Perches
Using %pR standardizes the struct resource output. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-14ALSA: sound/ppc/powermac: remove undefined operationsAndreas Schwab
Modifying an object twice without an intervening sequence point is undefined. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-13sound: Remove pr_<level> uses of KERN_<level>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13Merge branch 'topic/bkl' into topic/core-cleanupTakashi Iwai
2010-04-07ALSA: powermac - Fix obsoleted machine_is_compatible()Takashi Iwai
machine_is_compatible() was renamed to of_machine_is_compatible(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-04ALSA: powermac - Add debug logRisto Suominen
Add some debug log in tumbler.c. Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-04ALSA: powermac - Lineout detection on G4 DARisto Suominen
Lineout (Pro Speaker) detection on PowerMac G4 Digital Audio (Tumbler). Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-04ALSA: powermac - Reverse HP detection on G4 DARisto Suominen
Reverse headphone detection bit on PowerMac G4 Digital Audio (Tumbler). Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2009-12-01Merge branch 'topic/beep-rename' into topic/core-changeTakashi Iwai
2009-11-05ALSA: rename "PC Speaker" controls to "Speaker"Jaroslav Kysela
To unify control names, rename "PC Speaker" to "Speaker" for PPC ALSA drivers. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-27powerpc: Minor cleanup to sound/ppc/KconfigKumar Gala
We can replace PPC32 || PPC64 as a dependancy with just PPC as all powerpc platforms (32-bit and 64-bit) define PPC now. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-02sound: Make keywest_driver staticJean Delvare
I can't see any reason for struct i2c_driver keywest_driver to not be static. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-01ALSA: Don't assume i2c device probing always succeedsTakashi Iwai
The client->driver pointer can be NULL when i2c-device probing fails in i2c_new_device(). This patch adds the NULL checks for client->driver and return the error instead of blind assumption of driver availability. Reported-by: Tim Shepard <shep@alum.mit.edu> Cc: Jean Delvare <khali@linux-fr.org> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-12Merge branch 'topic/ps3' into for-linusTakashi Iwai
* topic/ps3: ALSA: sound/ps3: Correct existing and add missing annotations ALSA: sound/ps3: Restructure driver source ALSA: sound/ps3: Fix checkpatch issues
