when needed
We don't always need soc-compress in soc, here add a config item
SND_SOC_COMPRESS, when nobody select it, the soc-compress will
not be compiled.
Here also change Kconfig to 'select SND_SOC_COMPRESS' for drivers
that needed soc-compress.
Signed-off-by: Jie Yang <yang.jie@intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
The sun4i, sun5i and sun7i SoC families have a built-in codec, capable
of both audio capture and playback.
While this is called a codec by Allwinner, it really is an in-SoC
combination of a codec and a DAI, with its own DAC/ADC and amplifiers
in a single memory-mapped controller.
The capture part has been left out for now, and will be added eventually.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
'asoc/topic/sti' and 'asoc/topic/sti-sas' into asoc-next
Allow the topology code to be compiled out so that users who don't need
topology don't need to havve the code compiled in, saving them some
memory.
Some more configuration could be added to remove some of the hooks into
the core data structures but that is probably best done with some
refactoring to use functions to do the updates of the data structures
rather than ifdefing in the code as we'd need to do at the minute.
Suggested-by: Takashi Iwai <tiwai@suse.de>
Define the platform and codec drivers, and how to build them.
Signed-off-by: Arnaud Pouliquen <arnaud.pouliquen@st.com>
and 'asoc/topic/omap' into asoc-next
This is the DPCM based platform driver of AFE (Audio Front End) unit.
Signed-off-by: Koro Chen <koro.chen@mediatek.com>
'asoc/topic/zx' into asoc-next
Add driver for zx296702 SPDIF controller
Signed-off-by: Jun Nie <jun.nie@linaro.org>
The topology core parses the FW topology file for known block types and
instanciates any common ALSA/ASoC objects that it discovers. The core
also passes any block that is does not understand to client component
drivers for enumeration.
The core exports some APIs to client drivers in order to load and unload
firmware topology data as use case require.
Currently the core deals with the following object types :-
o kcontrols. This includes TLV, enumerated and bytes controls.
o DAPM widgets. All types with any associated kcontrol.
o DAPM graph.
o FE PCM. FE PCM capabilities and configuration can be defined.
o BE DAI Link. BE DAI link capabilities and configuration can be defined.
o Codec <-> codec style links capabilities and configuration.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Allow for the Qualcomm Technologies ASoC drivers
to build.
Signed-off-by: Kenneth Westfield <kwestfie@codeaurora.org>
Acked-by: Banajit Goswami <bgoswami@codeaurora.org>
XTFPGA boards provides an audio subsystem that consists of TI CDCE706
clock synthesizer, I2S transmitter and TLV320AIC23 audio codec.
I2S transmitter has MMIO-based interface that resembles that of the
OpenCores I2S transmitter. I2S transmitter is always a master on I2S
bus. There's no specialized audio DMA, sample data are transferred to
I2S transmitter FIFO by CPU through memory-mapped queue interface.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
'asoc/topic/adau1373' and 'asoc/topic/adau17x1' into asoc-next
Currently the AC'97 support is splattered all throughout soc-core.c. Some
parts are #ifdef'd some parts are not. This patch moves the AC'97 support to
its own file, this should make the code a bit more clearer and also makes it
possible to easily not compile it into the kernel when not needed.
The main ASoC source file is getting quite large and the standard ops don't
really have anything to do with the rest of the file so split them out into
a separate file.
The s6000 Xtensa support is removed from the kernel. There are no
other chips known to use this I2S controller.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
Add driver for i2s controller found on rk3066, rk3168 and rk3288
processors from rockchip.
Tested on the RK3288 SDK board.
Signed-off-by: Jianqun Xu <xjq@rock-chips.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
This driver is used by SIRF internal audio codec.
Use dedicated SiRF audio port TXFIFO and RXFIFO
Supports two DMA channels for SiRF audio port TXFIFO and RXFIFO
The audio port like as audio bus such as i2s.
Signed-off-by: Rongjun Ying <rongjun.ying@csr.com>
'asoc/topic/adav80x', 'asoc/topic/adsp', 'asoc/topic/ak4641', 'asoc/topic/ak4642', 'asoc/topic/arizona', 'asoc/topic/atmel', 'asoc/topic/au1x', 'asoc/topic/axi', 'asoc/topic/bcm2835', 'asoc/topic/blackfin', 'asoc/topic/cs4271', 'asoc/topic/cs42l52', 'asoc/topic/da7210', 'asoc/topic/davinci', 'asoc/topic/ep93xx', 'asoc/topic/fsl', 'asoc/topic/fsl-mxs', 'asoc/topic/generic', 'asoc/topic/hdmi', 'asoc/topic/jack', 'asoc/topic/jz4740', 'asoc/topic/max98090', 'asoc/topic/mxs', 'asoc/topic/omap', 'asoc/topic/pxa', 'asoc/topic/rcar', 'asoc/topic/s6000', 'asoc/topic/sai', 'asoc/topic/samsung', 'asoc/topic/sgtl5000', 'asoc/topic/spear', 'asoc/topic/ssm2518', 'asoc/topic/ssm2602', 'asoc/topic/tegra', 'asoc/topic/tlv320aic3x', 'asoc/topic/twl6040', 'asoc/topic/txx9', 'asoc/topic/uda1380', 'asoc/topic/width', 'asoc/topic/wm8510', 'asoc/topic/wm8523', 'asoc/topic/wm8580', 'asoc/topic/wm8711', 'asoc/topic/wm8728', 'asoc/topic/wm8731', 'asoc/topic/wm8741', 'asoc/topic/wm8750', 'asoc/topic/wm8753', 'asoc/topic/wm8776', 'asoc/topic/wm8804', 'asoc/topic/wm8900', 'asoc/topic/wm8901', 'asoc/topic/wm8940', 'asoc/topic/wm8962', 'asoc/topic/wm8974', 'asoc/topic/wm8985', 'asoc/topic/wm8988', 'asoc/topic/wm8990', 'asoc/topic/wm8991', 'asoc/topic/wm8994', 'asoc/topic/wm8995', 'asoc/topic/wm9081' and 'asoc/topic/x86' into asoc-next
This patch adds support for the AXI-I2S softcore. The core implements a simple
bidirectional I2S transceiver and is used by Analog Devices in some of their
reference designs for various FPGA platforms.
The driver uses the generic PCM dmaengine driver for its PCM. The only
restriction is that we need to set the SND_DMAENGINE_PCM_FLAG_NO_RESIDUE flag as
the dmaengine driver for the DMA core (PL330) that is used with this core has no
residue reporting capabilities yet. This will be fixed in the future though.
This driver adds support for digital audio (I2S)
for the BCM2835 SoC that is used by the
Raspberry Pi. External audio codecs can be
connected to the Raspberry Pi via P5 header.
It relies on cyclic DMA engine support for BCM2835.
Signed-off-by: Florian Meier <florian.meier@koalo.de>
We have other Intel platforms coming having the Smart Sound Technology (SST)
so rename the mid-x86 directory to intel as originally directory name
reflected only Intel MID platform.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Since with the wider use of devres many drivers are now only calling
snd_soc_unregister_component() in their remove functions providing a
managed version will save a reasonable amount of code.
For the PXA DMA rework, we need the generic dmaengine implementation
that currently lives in sound/soc for standalone (non-ASoC) AC'97
support.
Move it to sound/core, and rename the Kconfig symbol.
Signed-off-by: Daniel Mack <zonque@gmail.com>
This patch adds Kconfig and Makefile to support SPEAr Audio driver.
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com>
This patch adds a generic dmaengine PCM driver. It builds on top of the
dmaengine PCM library and adds the missing pieces like DMA channel management,
buffer management and channel configuration. It will be able to replace the
majority of the existing platform specific dmaengine based PCM drivers.
Devicetree is used to map the DMA channels to the PCM device.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
soc-dmaengine-pcm library need to be part of the snd-soc-core in order to
be able to compile ASoC as modules when dmaengine is enabled on the platform.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
This patch is to rename the directory "ep93xx" in "cirrus".
Name more accurately reflects the manufacturer and allows to add
drivers not only for architecture ep93xx in this directory.
Patch not contain any functional changes.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
This patch adds the support to parse the compress dai's and then also adds the
soc-compress.c file while handles the compress stream operations, mostly analogus
to what is done in the soc-pcm.c and aditional handling of the compress
opertaions
Signed-off-by: Namarta Kohli <namartax.kohli@intel.com>
Signed-off-by: Ramesh Babu K V <ramesh.babu@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
This patch add support for synopsys I2S controller as per the ASoC
framework.
Add driver for running I2S with the MSP-block.
Signed-off-by: Ola Lilja <ola.o.lilja@stericsson.com>
[Fixed trailing whitespace -- broonie]
Current ASoC requires card.c file to each platforms in order to
specifies its CPU and Codecs pair.
But the differences between these were only value/strings of setting.
In order to reduce duplicate driver, this patch adds generic/simple-card.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Freescale PowerPC and ARM/IMX families share the same SSI IP block.
The patch merges sound/soc/imx into sound/soc/fsl, so that the possible
code sharing and consolidation can happen.
This is a plain merge, except that menuconfig SND_POWERPC_SOC is added
in Kconfig for PowerPC platform as a correspondence to SND_IMX_SOC for
IMX platform.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Timur Tabi <timur@freescale.com>
This patch adds a set of functions which are intended to be used when
implementing a dmaengine based sound PCM driver.
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Acked-by: Liam Girdwood <lrg@ti.com>
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
For clarity and to help ongoing refactoring in this area create a new file
to contain the physical I/O functions, separating them out from the cache
operations.
In preparation for Dynamic PCM support (AKA DSP support).
There will be future patches that add support to allow PCMs to be dynamically
routed to multiple DAIs at startup and also during stream runtime. This patch
moves the ASoC core PCM operaitions into a new file called soc-pcm.c. This will
in simplify the ASoC core features into distinct files.
Signed-off-by: Liam Girdwood <lrg@ti.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch adds the makefile and kconfig changes for mid asoc drivers:
platform and machine driver which are introduced in 2 preceeding patches
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Signed-off-by: Harsha Priya <priya.harsha@intel.com>
Finally, move the 's3c24xx' directory to 'samsung'
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
This patch adds ASoC support for JZ4740 SoCs I2S module.
Add ep93xx i2s audio driver
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
This patch enables support for the i2s controller available on kirkwood
platforms
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
Add support for NUC900 AC97
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Many devices need to calculate the bit clock rate desired to
work out the clock configuration required for the device.
Provide utility functions to do this using both hw_params
structures and raw numbers.
sound/soc/Makefile
This adds support for DMA platform valid for i.MX1 and i.MX2 platforms.
This is not valid for i.MX3 since it doesn't share the same DMA
interface than i.MX1 and i.MX2.
It has been tested on i.MX27 board.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
