Currently pcm_new() passes in 3 arguments :- card, pcm and DAI.
Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains
card, pcm and DAI along with other members too that are useful too.
Signed-off-by: Liam Girdwood <lrg@ti.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Liam Girdwood <lrg@ti.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
The variable 'periods' of structure 'atmel_runtime_data'
seems no use in whole atmel alsa driver,so I make a patch
to remove the unnecessary variable.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This fixes a memory corruption when ASoC devices are used in
full-duplex mode. Specifically for pxa-ssp code, where this pointer
is dynamically allocated for each direction and destroyed upon each
stream start.
All other platforms are fixed blindly, I couldn't even compile-test
them. Sorry for any breakage I may have caused.
Reported-by: Sven Neumann <s.neumann@raumfeld.com>
Reported-by: Michael Hirsch <m.hirsch@raumfeld.com>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Currently only the atmel driver make use of snd_soc_dai.runtime field.
If the dais are to be shared among two or more dai_links, the field
must be got rid of.
So, in atmel driver reach the substream via dai_link->pcm so as to
not depend of snd_soc_dai.runtime field.
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
Passing pointer to relevant dai_link provides easier reach to the
ASoC tree in suspend/resume of snd_soc_platform. It also provides
direct access to the dai at the other end of the dai_link.
The PCM operations tables are not exported directly but are instead
included in the platform structure so should be declared static.
<mach/hardware.h> doesn't exist on AVR32 and therefore this driver won't
build on that arch. AFAICT this driver doesn't actually use the content
of that header so easiest just to remove it.
Signed-off-by: Ben Nizette <bn@niasdigital.com>
The module init entries should be __init instead of __devinit.
I wish I had boards which work with unmodified kernels :/
This is done at modprobe time, mirroring current behaviour, except for
mpc5200_psc_i2s where we do registration at the same time as we register
with soc-of-simple. Since the core currently ignores registration this
has no practical impact.
None of the platforms are actually using the SoC device so remove it
(only atmel actually has a suspend method).
The Ateml AT91 and AVR32 SoC share common IP for audio and can share the
same driver code using the atmel-ssc API provided for both architectures.
Do this, creating a new unified atmel ASoC architecture to replace the
previous at32 and at91 ones.
[This was contributed as a patch series for reviewability but has been
squashed down to a single commit to help preserve both the history and
bisectability. A small bugfix from Jukka is included.]
Tested-by: Jukka Hynninen <ext-jukka.hynninen@vaisala.com>
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
