path: root/sound/soc/atmel
2011-06-10sound/atmel_ssc_dai: add a missing space to an error messageUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-07ASoC: core - Optimise and refactor pcm_new() to pass only rtdLiam Girdwood
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI. Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains card, pcm and DAI along with other members too that are useful too. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-06ASoC: Add context parameter to card DAPM callbacksMark Brown
The card callback will get called for each DAPM context in the card so it can be useful for it to know which device is currently undergoing a transition. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-06-06Merge branch 'for-3.0' into for-3.1Mark Brown
2011-06-03ASoC: atmel_ssc: Don't try to free ssc if request failedJoachim Eastwood
We should only call ssc_free() when ssc_request() succeeds or bad things will happen. Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-30Merge branch 'for-2.6.40' into for-2.6.41Mark Brown
2011-05-26ASoC: sam9g20_wm8731: use the proper SYSCKL valueNicolas Ferre
at91sam9g20 is providing master clock to wm8731: not using a crystal but an external MCLK. We can avoid conflict and save power using WM8731_SYSCLK_MCLK as we do not need oscillator to be powered. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26ASoC: atmel_ssc_dai: fix ssc error pathNicolas Ferre
We do not have to free a resource that is not allocated yet. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26ASoC: trivial: typo in atmel_pcm_dma_params strucutre commentNicolas Ferre
2011-05-26ASoC: trivial: typo in debug commentNicolas Ferre
2011-04-18ASoC: Merge branch 'for-2.6.39' into for-2.6.40Mark Brown
Fix trivial conflict caused by silly spelling fix patch. Conflicts: sound/soc/codecs/wm8994.c
2011-03-30ASoC: Remove -codec from WM8731 driver nameMark Brown
2011-01-25ASoC: Fix codec device id format used by some dai_linksLars-Peter Clausen
The id part of an I2C device name is created with the "%d-%04x" format string. So for example for an I2C device which is connected to the adapter with the id 0 and has its address set to 0x1a the id part of the devices name would be "0-001a". Currently some sound board drivers have the id part the codec_name field of their dai_link structures set as if it had been created by a "%d-0x%x" format string. For example "0-0x1a" instead of "0-001a". As a result there is no match between the codec device and the dai_link and no sound card is instantiated. This patch fixes it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-11-25Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-25ASoC: sam9g20_wm8731: fix resource leak in at91sam9g20ek_init error pathAxel Lin
Fix the error path to properly free allocated resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: snd-soc-afeb9260: remove unneeded platform_device_del in error pathAxel Lin
2010-11-22Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-22ASoC: atmel: test wrong variableVasiliy Kulikov
After clk_get() mclk is checked second time instead of pllb check. In patch v1 Jarkko Nikula noticed that PTR_ERR() is also has wrong argument. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-11Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-11Fix Atmel soc audio boards Kconfig dependencyRyan Mallon
Add Kconfig dependency on AT91_PROGRAMMABLE_CLOCKS for the Atmel SoC audio SAM9G20-EK and PlayPaq boards. Fixes link errors on missing clk_set_parent and clk_set_rate when building without AT91_PROGRAMMABLE_CLOCKS. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Geoffrey Wossum <gwossum@acm.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-18ASoC: Add simplfied device registration for Atmel SSC devicesMark Brown
Since the SSC is already being registered as a device under arch and the DMA and SSC hardware are pretty much the same provide a simplified device registration function for the Atmel SSC which will add the ASoC-specific devices within the ASoC code, parenting the SSC device off the actual SSC device. Also use it in the sam9g20-ek driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-18ASoC: Fix device name for AT91SAM9G20-EK devicesMark Brown
A couple of typos in the multi-component conversion. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-18ASoC: Support non-crystal master clocks for WM8731Mark Brown
Instead of unconditionally enabling the crystal oscillator on the WM8731 only enable it when explicitly selected via set_sysclk(), allowing machine drivers to specify that they drive a clock into MCLK alone. This avoids any conflicts between the oscillator and the external MCLK source and saves power for systems which do not need the oscillator. This should also deliver a small power saving on systems using the crystal since the oscillator will only be enabled when the ADC or DAC is active. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-07ASoC: atmel: trivial code cleanupWan ZongShun
Remove break after return, it is not needed. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-06-03ASoC: atmel: patch for the unnecessary variable removalWan ZongShun
The variable 'periods' of structure 'atmel_runtime_data' seems no use in whole atmel alsa driver,so I make a patch to remove the unnecessary variable. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-19ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_streamDaniel Mack
This fixes a memory corruption when ASoC devices are used in full-duplex mode. Specifically for pxa-ssp code, where this pointer is dynamically allocated for each direction and destroyed upon each stream start. All other platforms are fixed blindly, I couldn't even compile-test them. Sorry for any breakage I may have caused. Reported-by: Sven Neumann <s.neumann@raumfeld.com> Reported-by: Michael Hirsch <m.hirsch@raumfeld.com> Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-22ASoC: Change how suspend and resume obtain the PCM runtimejassi brar
Currently only the atmel driver make use of snd_soc_dai.runtime field. If the dais are to be shared among two or more dai_links, the field must be got rid of. So, in atmel driver reach the substream via dai_link->pcm so as to not depend of snd_soc_dai.runtime field. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-22ASoC: Pass dai_link as argument to platform suspend and resumejassi brar
Passing pointer to relevant dai_link provides easier reach to the ASoC tree in suspend/resume of snd_soc_platform. It also provides direct access to the dai at the other end of the dai_link. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-09ASoC: at91sam9g20ek_2mmc board uses same audio connexion as at91sam9g20ekNicolas Ferre
The modified revision of at91sam9g20 Evaluation Kit rev. C and onwards share with previous ones its audio connexion to Wolfson wm8731. Modify the SoC file to extend the machine ID checking. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-06Merge branch 'for-2.6.32' into for-2.6.33Mark Brown
2009-09-14Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (257 commits) [ARM] Update mach-types ARM: 5636/1: Move vendor enum to AMBA include ARM: Fix pfn_valid() for sparse memory [ARM] orion5x: Add LaCie NAS 2Big Network support [ARM] pxa/sharpsl_pm: zaurus c3000 aka spitz: fix resume ARM: 5686/1: at91: Correct AC97 reset line in at91sam9263ek board ARM: 5640/1: This patch modifies the support of AC97 on the at91sam9263 ek board ARM: 5689/1: Update default config of HP Jornada 700-series machines ARM: 5691/1: fix cache aliasing issues between kmap() and kmap_atomic() with highmem ARM: 5688/1: ks8695_serial: disable_irq() lockup ARM: 5687/1: fix an oops with highmem ARM: 5684/1: Add nuc960 platform to w90x900 ARM: 5683/1: Add nuc950 platform to w90x900 ARM: 5682/1: Add cpu.c and dev.c and modify some files of w90p910 platform ARM: 5626/1: add suspend/resume functions to amba-pl011 serial driver ARM: 5625/1: fix hard coded 4K resource size in amba bus detection MMC: MMCI: convert realview MMC to use gpiolib ARM: 5685/1: Make MMCI driver compile without gpiolib ARM: implement highpte ARM: Show FIQ in /proc/interrupts on CONFIG_FIQ ... Fix up trivial conflict in arch/arm/kernel/signal.c. It was due to the TIF_NOTIFY_RESUME addition in commit d0420c83f ("KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures") and follow-ups.
2009-09-05ASoC: Add source argument to PLL configurationMark Brown
More and more devices feature PLLs and FLLs with the ability to select between multiple input clocks. In order to better support these devices a new argument, source, has been added to the set_pll() configuration API. Using set_clkdiv() is often difficult due to the need to stop the PLL/FLL before any reconfiguration can be done. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-09[ARM] 5596/1: at91sam9g20-ek: Register WM8731 in board fileMark Brown
The WM8731 driver has been updated to allow registration via normal device model methods rather than from within the ASoC driver probe so update the AT91SAM9G20-EK to make use of this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-08ASoC: Configure WM8731 SYSCLK at startup on AT91SAM9G20-EKMark Brown
The system clock is currently fixed by the driver and this avoids the need for us to handle errors with enabling and disabling MCLK (which was incorrect previously so this fixes bugs in error handling). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-08ASoC: Disable microphone input for AT91SAM9G20-EK by defaultMark Brown
As shipped the board does not have inputs but it is relatively straightforward to modify the board to hook them up so support is provided in the driver. When these modifications have not been made enabling the microphone stage can cause problems. Add an ifdef to disable this by default. Don't put it into Kconfig since users will have to get their soldering irons out to change things. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-08ASoC: Use CODEC as clock master on AT91SAM9G20-EKMark Brown
This simplifies the driver by removing the need to manually configure dividers within the CPU and improve audio performance by ensuring that the optimal phase relationships between the clocks in the system are maintained. Note that currently this means that for playback to work the Output Mixer HiFi switch must be enabled since otherwise CODEC will not generate the DAC clock. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-28ASoC: correct print specifiers for unsignedsRoel Kluin
Unsigned variables should use `%u' rather than `%d'. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-08ASoC: AFEB9260 driverSergey Lapin
ASoC driver for AT91SAM9260-based AFEB9260 board Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-11ASoC: Merge dai_ops factor outMark Brown
Merge Eric Maio's patch to merge snd_soc_dai_ops out of line. Fixed merge issues and updated drivers, plus an issue with the ops for the two s3c2443 AC97 DAIs having been merged. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-04ASoC: make ops a pointer in 'struct snd_soc_dai'Eric Miao
Considering the fact that most cpu_dai or codec_dai are using a same 'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better made a pointer instead, to make sharing easier and code a bit cleaner. The patch below is rather preliminary since the asoc tree is being actively developed, and this touches almost every piece of code, (and possibly many others in development need to be changed as well). Building of all codecs are OK, yet to every SoC, I didn't test that. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-04ASoC: wm8510 pll settingsJonas Andersson
When setting WM8510_MCLKDIV the pll was turned off. When setting pll frequency you got twice the expected freq, because the code calculated with postscaler of 8, but the hardware divide by 4. Signed-off-by: Jonas Andersson <jonas@microbit.se> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-18ASoC: Refactor WM8731 device registrationMark Brown
Move the WM8731 driver to use a more standard device registration scheme where the device can be registered independantly of the ASoC probe. As a transition measure push the current manual code for registering the WM8731 into the individual machine driver probes. This allows separate patches to update the relevant architecture files with less risk of merge issues. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-18ASoC: Rename AT91SAMG20-EK for applicationsMark Brown
This is a bit more idiomatic and makes identifying a configuration based on the board type work better. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-18ASoC: Actively manage MCLK for AT91SAM9G20-EKMark Brown
We have software control of the MCLK for the WM8731 so save a bit of power by actively managing it within the machine driver, enabling it only while the codec is active. Once ASoC supports multiple boards and doesn't require the soc-audio device the initial clock setup should be pushed down into the arch/arm code but for now this reduces merge issues. Tested-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-18ASoC: Check machine type before loading on AT91SAM9G20-EKMark Brown
2009-02-18ASoC: Improve diagnostics for AT91SAM9G20-EK probeMark Brown
We should display an error by default if we fail to register. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
