path: root/sound/soc/codecs/ac97.c
2010-01-04ASoC: fixup oops in generic AC97 codec glueManuel Lauss
Initialize the glue by calling snd_soc_new_ac97_codec() as is done in other ASoC AC97 codecs. Fixes an oops caused by dereferencing uninitialized members in snd_soc_new_pcms(). Run-tested on Au1250. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-02ASoC: Use a shared define for AC97 CODEC data formatsMark Brown
The AC97 wire format is completely fixed so CODECs don't have any choice about the formats they accept but controllers accept a variety of data formats and render them down onto the bus. Have a shared define so all the CODEC drivers will interoperate with any of our controller drivers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-04ASoC: make ops a pointer in 'struct snd_soc_dai'Eric Miao
Considering the fact that most cpu_dai or codec_dai are using a same 'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better made a pointer instead, to make sharing easier and code a bit cleaner. The patch below is rather preliminary since the asoc tree is being actively developed, and this touches almost every piece of code, (and possibly many others in development need to be changed as well). Building of all codecs are OK, yet to every SoC, I didn't test that. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-27ASoC: Push the codec runtime storage into the card structureMark Brown
This is a further stage on the road to refactoring away the ASoC platform device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-19ASoC: fixes to caching implementationsIan Molton
This patch takes fixes a number of bugs in the caching code used by several ASoC codec drivers. Mostly off-by-one fixes. Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-01ASoC: Rename snd_soc_register_card() to snd_soc_init_card()Mark Brown
Currently ASoC card initialisation is completed by a function called snd_soc_register_card(). As part of the work to allow independant registration of cards, codecs and machines in ASoC v2 a new function of the same name has been added so rename the existing function to facilitate the merge of v2. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-24ASoC: Remove DAI type informationMark Brown
DAI type information is only ever used within ASoC in order to special case AC97 and for diagnostic purposes. Since modern CPUs and codecs support multi function DAIs which can be configured for several modes it is more trouble than it's worth to maintain anything other than a flag identifying AC97 DAIs so remove the type field and replace it with an ac97_control flag. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-21ASoC: Merge snd_soc_ops into snd_soc_dai_opsMark Brown
Liam Girdwood's ASoC v2 work avoids having two different ops structures for DAIs by merging the members of struct snd_soc_ops into struct snd_soc_dai_ops, allowing per DAI configuration for everything. Backport this change. This paves the way for future work allowing any combination of DAIs to be connected rather than having fixed purpose CODEC and CPU DAIs and only allowing CODEC<->CPU interconnections. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-13ALSA: ASoC: update email address for Liam GirdwoodLiam Girdwood
Update the contact information for Liam Girdwood in ASoC core and drivers as my old email address is no longer valid. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-10ALSA: asoc: codecs - merge structs snd_soc_codec_dai and snd_soc_cpu_dai.Liam Girdwood
This patch merges struct snd_soc_codec_dai and struct snd_soc_cpu_dai into struct snd_soc_dai for the codec drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: ASoC: AC97 codec PMManuel Lauss
Simple suspend/resume for AC97 ASoC codec. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Acked-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-13ALSA: ASoC: Add missing includesMark Brown
Ensure that DAIs are prototyped in the codec drivers that define them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-19[ALSA] ASoC: Remove in-code changelogsMark Brown
The overwhelming majority just say 'initial version' anyway. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] soc - ac97 - Clean up checkpatch warningsMark Brown
Also change some if (x == NULL) to if (!x). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-16[ALSA] ASoC AC97 device reg bugfixLiam Girdwood
This patch fixes a bug whereby AC97 bus device data was being clobbered when AC97 codecs using the generic ac97_codec.c driver were being registered. Codecs that didn't use the generic driver were unaffected (e.g. WM9712, WM9713). Changes:- o Add new AC97 codec class for custom (or need bus dev registration) AC97 codecs. o Only register/deregister this custom codec device with the AC97 bus. The generic AC97 driver already does this for generic codec devices. This may be related to bug #3038 :- https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3038 Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16[ALSA] ASoC AC97 static GPL symbol fixLiam Girdwood
This patch fixes a bug whereby the GPL'ed symbol ac97_dai was being declared as static. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] ASoC export AC97 DAIGraeme Gregory
This patch exports the ASoC AC97 Digital Audio Interface as a GPL'ed symbol. Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] soc - ASoC 0.13 generic AC97 codecLiam Girdwood
This patch updates the AC97 codec driver to the new API in ASoC 0.13. Changes:- o Removed DAI capabilities matching code in favour of manual matching in the machine drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC codecs: generic AC97 supportRichard Purdie
This patch allows the std Alsa AC97 codec driver to use any AsoC AC97 controller driver. Currently, only HiFi playback and Capture are supported atm. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
