path: root/sound/soc/codecs/wm8580.c
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-15ASoC: Remove snd_soc_suspend_device()Mark Brown
The PM core will grow pm_link infrastructure in 2.6.33 which can be used to implement the intended functionality of the ASoC-specific device suspend and resume callbacks so drop them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-05ASoC: Add source argument to PLL configurationMark Brown
More and more devices feature PLLs and FLLs with the ability to select between multiple input clocks. In order to better support these devices a new argument, source, has been added to the set_pll() configuration API. Using set_clkdiv() is often difficult due to the need to stop the PLL/FLL before any reconfiguration can be done. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-01ASoC: Debugged improper setting of PLL fields in WM8580 driverjassi brar
Bug was caught while trying to use WM8580 as I2S master on SMDK. Symptoms were lesser LRCLK read by CRO(41.02 instead of 44.1 KHz) Solved by referring to WM8580A manual and setting mask value correctly and making the code to not touch 'reserved' bits of PLL4 register. Signed-off-by: Jassi <jassi.brar@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Add I/O control bus information to factored out cache setupMark Brown
While writes tend to be able to use a fairly bus independant format to do the writes reads are all bus specific. To allow us to factor out this code include the bus type as a parameter when setting up the cache. Initially just use this to factor out hw_write_t for I2C. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-05ASoC: Factor out WM8580 register cache codeMark Brown
Note the slightly tricky cache usage in the volume update function due to the requirement for a separate write for the VU bit. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-17ASoC: Regulator support for WM8580Mark Brown
Add basic support for integration with the regulator API to WM8580. Since the core cannot yet disable biases when the CODEC is idle we simply request and enable the regulators for the entire time the driver is active. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-13ASoC: Add suspend and resume callbacks to Wolfson CODEC driversMark Brown
2009-05-28ASoC: correct print specifiers for unsignedsRoel Kluin
Unsigned variables should use `%u' rather than `%d'. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-22ASoC: Fix WM8580 volume update handling for large register changesMark Brown
The driver is out of sync with the core functions it is using. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-21ASoC: Fix offset of freqmode in WM8580 PLL configurationMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2009-03-12ASoC: Move WM8580 to normal I2C device probeMark Brown
Refactor the WM8580 device registration to probe via standard I2C device registration, registering the DAIs once the device has probed via I2C. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-11ASoC: Merge dai_ops factor outMark Brown
Merge Eric Maio's patch to merge snd_soc_dai_ops out of line. Fixed merge issues and updated drivers, plus an issue with the ops for the two s3c2443 AC97 DAIs having been merged. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-11ASoC: Remove version display from WM8580 driverMark Brown
2009-03-04ASoC: make ops a pointer in 'struct snd_soc_dai'Eric Miao
Considering the fact that most cpu_dai or codec_dai are using a same 'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better made a pointer instead, to make sharing easier and code a bit cleaner. The patch below is rather preliminary since the asoc tree is being actively developed, and this touches almost every piece of code, (and possibly many others in development need to be changed as well). Building of all codecs are OK, yet to every SoC, I didn't test that. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-27ASoC: Push the codec runtime storage into the card structureMark Brown
This is a further stage on the road to refactoring away the ASoC platform device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-19ASoC: fixes to caching implementationsIan Molton
This patch takes fixes a number of bugs in the caching code used by several ASoC codec drivers. Mostly off-by-one fixes. Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-09ASoC: cleanup duplicated code.Ian Molton
Many codec drivers were implementing cookie-cutter copies of the function that adds kcontrols to the codec. This patch moves this code to a common function snd_soc_add_controls() in soc-core.c and updates all drivers using copies of this function to use the new common version. [Edited to raise priority of error log message and document parameters. -- broonie] Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-10ALSA: ASoC - Fix wrong section typesTakashi Iwai
The module init entries should be __init instead of __devinit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-09ASoC: Register non-AC97 codec DAIsMark Brown
Currently this is done at module probe time since ASoC ties in codec device probe to the instantiation of the entire ASoC device. Subsequent patches will refactor the codec drivers to handle probing separately. Note that the core does not yet use this information. AC97 is special since the codec is controlled over the AC97 link but we want to give the machine driver a chance to set up the system before trying to instantiate since it may need to do configuration before the AC97 link will operate Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-01ASoC: Rename snd_soc_register_card() to snd_soc_init_card()Mark Brown
Currently ASoC card initialisation is completed by a function called snd_soc_register_card(). As part of the work to allow independant registration of cards, codecs and machines in ASoC v2 a new function of the same name has been added so rename the existing function to facilitate the merge of v2. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-21ASoC: Merge snd_soc_ops into snd_soc_dai_opsMark Brown
Liam Girdwood's ASoC v2 work avoids having two different ops structures for DAIs by merging the members of struct snd_soc_ops into struct snd_soc_dai_ops, allowing per DAI configuration for everything. Backport this change. This paves the way for future work allowing any combination of DAIs to be connected rather than having fixed purpose CODEC and CPU DAIs and only allowing CODEC<->CPU interconnections. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-16ALSA: ASoC: Convert wm8580 to a new-style i2c driverJean Delvare
Convert the wm8580 codec driver to the new (standard) device driver binding model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-13ALSA: ASoC codec: remove unused #include <version.h>Huang Weiyi
The files below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. sound/soc/codecs/ad1980.c sound/soc/codecs/wm8580.c sound/soc/codecs/wm8900.c This patch removes the said #include <version.h>. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-13ALSA: ASoC: Remove unused AUDIO_NAME define from codec driversJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: ASoC: Add WM8580 CODEC driverMark Brown
The WM8580 is an audio CODEC designed for DVD and surround sound applications, offering three stereo DACs and a stereo ADC. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
