path: root/sound/soc/codecs/wm8750.c
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Factor out 7 bit register 9 bit data SPI writeMark Brown
This converts all the Wolfson drivers using this format (the only devices that do) except WM8753 to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Add I/O control bus information to factored out cache setupMark Brown
While writes tend to be able to use a fairly bus independant format to do the writes reads are all bus specific. To allow us to factor out this code include the bus type as a parameter when setting up the cache. Initially just use this to factor out hw_write_t for I2C. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-05ASoC: Begin to factor out register cache I/O functionsMark Brown
A lot of CODECs share the same register data formats and therefore replicate the code to manage access to and caching of the register map. In order to reduce code duplication centralised versions of this code will be introduced with drivers able to configure the use of the common code by calling the new snd_soc_codec_set_cache_io() API call during startup. As an initial user the 7 bit address/9 bit data format used by many Wolfson devices is supported for write only CODECs and the drivers with straightforward register cache implementations are converted to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-04ASoC: make ops a pointer in 'struct snd_soc_dai'Eric Miao
Considering the fact that most cpu_dai or codec_dai are using a same 'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better made a pointer instead, to make sharing easier and code a bit cleaner. The patch below is rather preliminary since the asoc tree is being actively developed, and this touches almost every piece of code, (and possibly many others in development need to be changed as well). Building of all codecs are OK, yet to every SoC, I didn't test that. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-27ASoC: Push the codec runtime storage into the card structureMark Brown
This is a further stage on the road to refactoring away the ASoC platform device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-09ASoC: cleanup duplicated code.Ian Molton
Many codec drivers were implementing cookie-cutter copies of the function that adds kcontrols to the codec. This patch moves this code to a common function snd_soc_add_controls() in soc-core.c and updates all drivers using copies of this function to use the new common version. [Edited to raise priority of error log message and document parameters. -- broonie] Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-10ALSA: ASoC - Fix wrong section typesTakashi Iwai
The module init entries should be __init instead of __devinit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-09ASoC: Register non-AC97 codec DAIsMark Brown
Currently this is done at module probe time since ASoC ties in codec device probe to the instantiation of the entire ASoC device. Subsequent patches will refactor the codec drivers to handle probing separately. Note that the core does not yet use this information. AC97 is special since the codec is controlled over the AC97 link but we want to give the machine driver a chance to set up the system before trying to instantiate since it may need to do configuration before the AC97 link will operate Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-01ASoC: Rename snd_soc_register_card() to snd_soc_init_card()Mark Brown
Currently ASoC card initialisation is completed by a function called snd_soc_register_card(). As part of the work to allow independant registration of cards, codecs and machines in ASoC v2 a new function of the same name has been added so rename the existing function to facilitate the merge of v2. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-21ASoC: Merge snd_soc_ops into snd_soc_dai_opsMark Brown
Liam Girdwood's ASoC v2 work avoids having two different ops structures for DAIs by merging the members of struct snd_soc_ops into struct snd_soc_dai_ops, allowing per DAI configuration for everything. Backport this change. This paves the way for future work allowing any combination of DAIs to be connected rather than having fixed purpose CODEC and CPU DAIs and only allowing CODEC<->CPU interconnections. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-13ALSA: ASoC: Remove unused AUDIO_NAME define from codec driversJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-23sound: ASoC: Add WM8750 SPI supportMark Brown
Implement SPI support for WM8750, cut'n'pasting from the support for WM8731 contributed by Cliff Cai and Alan Horstmann since the wire format is the same for both codecs. Also fix a cut'n'pasted comment in the I2C side of the driver (which was clearly written in the same way) while we're at it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-09-04ALSA: ASoC: Don't suggest compile time selection of codec accessMark Brown
Currently the boiler plate code used by most ASoC codecs to provide a placeholder for SPI access suggests making the selection of SPI a compile time option which is suboptimal when trying to build kernels supporting multiple systems. Change this template to suggest allowing runtime selection instead. Leave the drivers not yet converted to new style I2C access for now to avoid collisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-09-04ALSA: ASoC: Convert wm8750 to a new-style i2c driverJean Delvare
Convert the wm8750 codec driver to the new (standard) device driver binding model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-25ALSA: ASoC: Fix double free and memory leak in many codec driversJean Delvare
Many SoC audio codec drivers have improper freeing of memory in error paths. * codec is allocated in the platform device probe function, but is not freed there in case of error. Instead it is freed in the i2c device probe function's error path. However the success or failure of both functions is not linked, so this could result in a double free (if the platform device is successfully probed, the i2c device probing fails and then the platform driver is unregistered.) * codec->private_data is allocated in many platform device probe functions but not freed in their error paths. This patch hopefully solves all these problems. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-12ALSA: wm8750: add missing VREF outputDmitry Baryshkov
Add missing output VREF. After a65f0568f6cc8433877fb71dd7d36b551854b0bc it's critical, since it makes chip routing initialisation to fail. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-11ALSA: wm8750: it's MONO1, not MONODmitry Baryshkov
Since first commit wm8750 contained output named MONO, but all routes mentioned MONO1. Correct MONO to be MONO1. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-10ALSA: asoc: codecs - merge structs snd_soc_codec_dai and snd_soc_cpu_dai.Liam Girdwood
This patch merges struct snd_soc_codec_dai and struct snd_soc_cpu_dai into struct snd_soc_dai for the codec drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-26ALSA: ASoC: Replace custom debug macros with pr_ equivalentsMark Brown
Several ASoC codec drivers use custom macros equivalent to the standard pr_ macros, most of which are not actually used. Replace these custom macros with the standard ones. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-13ALSA: ASoC: Fix register cache sizes for Wolfson codecsMark Brown
The register cache size is used by the codec_reg sysfs file which works in terms of the register cache access functions rather than in terms of raw access to the cache so the size specified needs to be in terms of the number of elements. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-19[ALSA] soc - Convert Wolfson codec drivers to use bulk DAPM registrationMark Brown
2008-05-19[ALSA] ASoC: Clarify API for bias configurationMark Brown
Currently the ASoC core configures the bias levels in the system using a callback on codecs and machines called 'dapm_event', passing it PCI style power levels as SNDRV_CTL_POWER_ constants. This is more obscure than it needs to be and has caused confusion to driver authors, especially given that DAPM is also performing power management. Address this by renaming the callback function to 'set_bias_level' and using constants explicitly representing the off, standby, pre-on and on states which DAPM transitions through. Also unexport the API for setting bias level: there are currently no in-tree users of this API other than the core itself and it is likely that the core would need to be extended to cater for any users. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] soc - wm8750 - Clean up checkpatch warningsMark Brown
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] use convenient treble scale on WM8750Stanislav Brabec
On Zaurus SL-C3200 (terrier/spitz) based on WM8750, treble scale is inconveniently reverted (increase level = decrease treble), in opposite to bass scale, which uses convenient scale. Fix ALSA WM8750 mixer treble to use convenient treble scale (increase = increase treble level) From: Stanislav Brabec <utx@penguin.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-11[ALSA] wm8750 typo fixAndrew Morton
I quuestion the testing status of that patch! Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] soc - Clean up with kmemdup()Takashi Iwai
Clean up by replacing with kmemdup(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] soc - ASoC 0.13 WM8750 codec driverLiam Girdwood
This patch updates the WM8750 codec driver to the new API in ASoC 0.13. Changes:- o Removed DAI capabilities matching code in favour of manual matching in the machine drivers. o Added DAI operations for codec and CPU interfaces. o Removed config_sysclk() function and struct snd_soc_clock_info. No longer needed as clocking is now configured manually in the machine drivers. Also removed other clocking data from structures. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC codec error reportingLiam Girdwood
This patch improves the codec probe() error reporting by printing error messages when the card or pcms fail to register. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] soc - Fix delayed_work related changes on 2.6.20 kernelTakashi Iwai
Fix the changes realted to delayed_work in soc/codecs/wm8750.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] soc - Use global workqueueTakashi Iwai
Use global workqueue for simplicity instead of own workqueue in SoC core and wm8750 codes. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC - mixer name changes for older OSS app supportLiam Girdwood
This patch suggested by Richard Purdie changes the names of some WM8731 and WM8750 mixers so that they will be recognised by some older OSS mixer apps. Changes:- o WM8731 Playback changed to Master Playback o WM8750 Out1 changed to Headphone o WM8750 Out2 changed to Speaker Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC: Add support for BCLK based on (Rate * Chn * Word Size)Liam Girdwood
This patch adds support for the DAI BCLK to be generated by multiplying Rate * Channels * Word Size (RCW). This now gives 3 options for BCLK clocking and synchronisation :- 1. BCLK = Rate * x 2. BCLK = MCLK / x 3. BCLK = Rate * Chn * Word Size. (New) Changes:- o Add support for RCW generation of BCLK o Update Documentation to include RCW. o Update DAI documentation for label = value DAI modes. o Add RCW support to wm8731, wm8750 and pxa2xx-i2s drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Remove trailing whitespaces from soc/* filesTakashi Iwai
Remove trailing whitespaces from soc/* files added by the conversion to C99-style initialization. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC DAI capabilities labellingLiam Girdwood
This patch suggested by Takashi changes the DAI capabilities definitions in pxa-i2s.c, at91rm9200-i2s.c, wm8731.c, wm8750.c and wm9712.c to use a label = value style. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC codecs: WM8750 supportRichard Purdie
This patch adds ASoC support for the WM8750 codec. Supported features:- o Capture/Playback/Sidetone/Bypass. o 16 & 24 bit audio. o 8k - 96k sample rates. o DAPM. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
