path: root/sound/soc/codecs/wm8961.c
2010-01-04ASoC: Only restore non-default registers for WM8961Mark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-15ASoC: Remove snd_soc_suspend_device()Mark Brown
The PM core will grow pm_link infrastructure in 2.6.33 which can be used to implement the intended functionality of the ASoC-specific device suspend and resume callbacks so drop them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Factor out I/O for Wolfson 8 bit data 16 bit register CODECsMark Brown
2009-06-29ASoC: Fix WM8961 suspend function typeMark Brown
2009-06-25ASoC: Add core suspend and resume callbacks to WM8961Mark Brown
2009-06-12ASoC: Add WM8961 driverMark Brown
The WM8961 is a low power, high quality stereo CODEC designed for portable digital applications with headphone and stereo class D speaker drivers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
