path: root/sound/soc/codecs/wm8971.c
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-04-17ASoC: Add indirection for CODEC private dataMark Brown
One of the features of the multi CODEC work is that it embeds a struct device in the CODEC to provide diagnostics via a sysfs class rather than via the device tree, at which point it's much better to use the struct device private data rather than having two places to store it. Provide an accessor function to allow this change to be made more easily, and update all the CODEC drivers are updated. To ensure use of the accessor the private data structure member is renamed, meaning that if code developed with older an older core that still uses private_data is merged it will fail to build. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Add I/O control bus information to factored out cache setupMark Brown
While writes tend to be able to use a fairly bus independant format to do the writes reads are all bus specific. To allow us to factor out this code include the bus type as a parameter when setting up the cache. Initially just use this to factor out hw_write_t for I2C. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-05ASoC: Begin to factor out register cache I/O functionsMark Brown
A lot of CODECs share the same register data formats and therefore replicate the code to manage access to and caching of the register map. In order to reduce code duplication centralised versions of this code will be introduced with drivers able to configure the use of the common code by calling the new snd_soc_codec_set_cache_io() API call during startup. As an initial user the 7 bit address/9 bit data format used by many Wolfson devices is supported for write only CODECs and the drivers with straightforward register cache implementations are converted to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-04ASoC: make ops a pointer in 'struct snd_soc_dai'Eric Miao
Considering the fact that most cpu_dai or codec_dai are using a same 'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better made a pointer instead, to make sharing easier and code a bit cleaner. The patch below is rather preliminary since the asoc tree is being actively developed, and this touches almost every piece of code, (and possibly many others in development need to be changed as well). Building of all codecs are OK, yet to every SoC, I didn't test that. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-27ASoC: Push the codec runtime storage into the card structureMark Brown
This is a further stage on the road to refactoring away the ASoC platform device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-09ASoC: cleanup duplicated code.Ian Molton
Many codec drivers were implementing cookie-cutter copies of the function that adds kcontrols to the codec. This patch moves this code to a common function snd_soc_add_controls() in soc-core.c and updates all drivers using copies of this function to use the new common version. [Edited to raise priority of error log message and document parameters. -- broonie] Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-10ALSA: ASoC - Fix wrong section typesTakashi Iwai
The module init entries should be __init instead of __devinit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-09ASoC: Register non-AC97 codec DAIsMark Brown
Currently this is done at module probe time since ASoC ties in codec device probe to the instantiation of the entire ASoC device. Subsequent patches will refactor the codec drivers to handle probing separately. Note that the core does not yet use this information. AC97 is special since the codec is controlled over the AC97 link but we want to give the machine driver a chance to set up the system before trying to instantiate since it may need to do configuration before the AC97 link will operate Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-01ASoC: Rename snd_soc_register_card() to snd_soc_init_card()Mark Brown
Currently ASoC card initialisation is completed by a function called snd_soc_register_card(). As part of the work to allow independant registration of cards, codecs and machines in ASoC v2 a new function of the same name has been added so rename the existing function to facilitate the merge of v2. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-21ASoC: Merge snd_soc_ops into snd_soc_dai_opsMark Brown
Liam Girdwood's ASoC v2 work avoids having two different ops structures for DAIs by merging the members of struct snd_soc_ops into struct snd_soc_dai_ops, allowing per DAI configuration for everything. Backport this change. This paves the way for future work allowing any combination of DAIs to be connected rather than having fixed purpose CODEC and CPU DAIs and only allowing CODEC<->CPU interconnections. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-13ALSA: ASoC: Remove unused AUDIO_NAME define from codec driversJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-23sound: ASoC: Add WM8971 CODEC driverKenneth Kiraly
The WM8971 is a low power, high quality stereo codec designed for portable digital audio applications. This driver was originally written by Kenneth Kiraly. While out of tree it has had updates to reflect current kernel APIs and coding standards from Graeme Gregory and Mark Brown. Signed-off-by: Kenneth Kiraly <kiraly@lab126.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
