path: root/sound/soc/codecs/wm8988.c
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-15ASoC: Remove snd_soc_suspend_device()Mark Brown
The PM core will grow pm_link infrastructure in 2.6.33 which can be used to implement the intended functionality of the ASoC-specific device suspend and resume callbacks so drop them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-10Merge branch 'topic/asoc' into for-linusTakashi Iwai
* topic/asoc: (226 commits) ASoC: au1x: PSC-AC97 bugfixes ASoC: Fix WM835x Out4 capture enumeration ASoC: Remove unuused hw_read_t ASoC: fix pxa2xx-ac97.c breakage ASoC: Fully specify DC servo bits to update in wm_hubs ASoC: Debugged improper setting of PLL fields in WM8580 driver ASoC: new board driver to connect bfin-5xx with ad1836 codec ASoC: OMAP: Add functionality to set CLKR and FSR sources in McBSP DAI ASoC: davinci: i2c device creation moved into board files ASoC: Don't reconfigure WM8350 FLL if not needed ASoC: Fix s3c-i2s-v2 build ASoC: Make platform data optional for TLV320AIC3x ASoC: Add S3C24xx dependencies for Simtec machines ASoC: SDP3430: Fix TWL GPIO6 pin mux request ASoC: S3C platform: Fix s3c2410_dma_started() called at improper time ARM: OMAP: McBSP: Merge two functions into omap_mcbsp_start/_stop ASoC: OMAP: Fix setup of XCCR and RCCR registers in McBSP DAI OMAP: McBSP: Use textual values in DMA operating mode sysfs files ARM: OMAP: DMA: Add support for DMA channel self linking on OMAP1510 ASoC: Select core DMA when building for S3C64xx ...
2009-08-03ASoC: Factor out 7 bit register 9 bit data SPI writeMark Brown
This converts all the Wolfson drivers using this format (the only devices that do) except WM8753 to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Add I/O control bus information to factored out cache setupMark Brown
While writes tend to be able to use a fairly bus independant format to do the writes reads are all bus specific. To allow us to factor out this code include the bus type as a parameter when setting up the cache. Initially just use this to factor out hw_write_t for I2C. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-12Sound: remove direct access of driver_dataGreg Kroah-Hartman
This is the last in-kernel direct usage of driver_data, replace it with the proper dev_get/set_drvdata() calls. Cc: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@perex.cz> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-05ASoC: Begin to factor out register cache I/O functionsMark Brown
A lot of CODECs share the same register data formats and therefore replicate the code to manage access to and caching of the register map. In order to reduce code duplication centralised versions of this code will be introduced with drivers able to configure the use of the common code by calling the new snd_soc_codec_set_cache_io() API call during startup. As an initial user the 7 bit address/9 bit data format used by many Wolfson devices is supported for write only CODECs and the drivers with straightforward register cache implementations are converted to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-05ASoC: Fix leaks in WM8988 registration error handlingMark Brown
2009-06-13ASoC: Add suspend and resume callbacks to Wolfson CODEC driversMark Brown
2009-04-07ASoC: Add WM8988 CODEC driverMark Brown
The WM8988 is a low power, high quality stereo CODEC designed for portable digital audio applications. The device integrates complete interfaces to 2 stereo headphone or line out ports. External component requirements are drastically reduced as no separate headphone amplifiers are required. Advanced on-chip digital signal processing performs graphic equaliser, 3-D sound enhancement and automatic level control for the microphone or line input. The WM8988 can operate as a master or a slave, with various master clock frequencies including 12 or 24MHz for USB devices, or standard 256fs rates like 12.288MHz and 24.576MHz. Different audio sample rates such as 96kHz, 48kHz, 44.1kHz are generated directly from the master clock without the need for an external PLL. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
