The DAPM widgets are now insntantiated by the core when creating the card
so there is no need for the individual CODEC drivers to do so.
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
The PM core will grow pm_link infrastructure in 2.6.33 which can be
used to implement the intended functionality of the ASoC-specific
device suspend and resume callbacks so drop them.
Store the TDM slot width then if it's set use that rather than the
sample size to calculate BCLK. Leave imposing constraints to the
core (which should do this but doesn't yet) or machine driver.
Also allow 0 TDM slots to be configure (for use when disabling TDM).
Extend set_tdm_slot to allow the user to arbitrarily set the frame width
and active TX/RX slots.
Updates magician.c and wm9081.c for the new set_tdm_slot(). wm9081.c
still doesn't handle the slot_width override.
While being there, correct an incorrect use of SlotsPerFrm(7) use in
bitmask on pxa-ssp.c (SSCR0_SlotsPerFrm(x) is (((x) - 1) << 24)) ).
(this series is meant for Mark's for-2.6.32 branch)
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com>
Due to the flexibility of the WM9081 FLL this should never happen
in a real system.
Reported-by: Jaswinder Singh Rajput <jaswinder@kernel.org>
Ensure that we always set a new sysclk when using the FLL in master mode
and pick out the correct value for the sample rate in hw_params().
The WM9081 is designed to provide high power output at low distortion
levels in space-constrained portable applications.
