Calculate SYS_MCLK using sample rate or SYS_FS.
These helpers allow to simplify a code to set up external system clock
for different sample rates.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Backported commit 8326ab1285e71e24481d8e1eee3e72a6b3abbb38
If VDDA != VDDIO and any of them is greater than 3.1V, charge pump
source can be assigned automatically [1].
[1] https://www.nxp.com/docs/en/data-sheet/SGTL5000.pdf
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Backported commit 8337f764b45e122bd17b8c84b7ac26da3086fe26
To enable "zero cross detect" for ADC/HP, change
HP_ZCD_EN/ADC_ZCD_EN bits only instead of writing the whole
CHIP_ANA_CTRL register.
Backported from commit 19a1d41649f695658a67898dcb9312de02878eb1.
This control mute/unmute the ADC input of SGTL5000
using its CHIP_ANA_CTRL register.
Tuned: add Headphone and Line-Out mute/unmute controlling.
Backported from commit 55e23d488cd1367638ee304bd8bb6210f53d13db.
SGTL5000_SMALL_POP is a bit mask, not a value. Usage of
correct definition makes device probing code more clear.
Backported from commit e6e98e2e05baa3862ac7d1d2334f88ec927c8f66.
VAG power control is improved to fit the manual [1]. This patch fixes as
minimum one bug: if customer muxes Headphone to Line-In right after boot,
the VAG power remains off that leads to poor sound quality from line-in.
I.e. after boot:
- Connect sound source to Line-In jack;
- Connect headphone to HP jack;
- Run following commands:
$ amixer set 'Headphone' 80%
$ amixer set 'Headphone Mux' LINE_IN
Change VAG power on/off control according to the following algorithm:
- turn VAG power ON on the 1st incoming event.
- keep it ON if there is any active VAG consumer (ADC/DAC/HP/Line-In).
- turn VAG power OFF when there is the latest consumer's pre-down event
come.
- always delay after VAG power OFF to avoid pop.
- delay after VAG power ON if the initiative consumer is Line-In, this
prevents pop during line-in muxing.
According to the data sheet [1], to avoid any pops/clicks,
the outputs should be muted during input/output
routing changes.
Fixes: 9b34e6cc3bc2 ("ASoC: Add Freescale SGTL5000 codec support")
On a mx28evk with a sgtl5000 codec we notice a loud 'click' sound to happen
5 seconds after the end of a playback.
The SMALL_POP bit should fix this, but its definition is incorrect:
according to the sgtl5000 manual it is bit 0 of CHIP_REF_CTRL register, not
bit 1.
Fix the definition accordingly and enable the bit as intended per the code
comment.
After applying this change, no loud 'click' sound is heard after playback
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
(cherry picked from commit c251ea7bd7a04f1f2575467e0de76e803cf59149)
CHRGPUMP_POWERUP
The SGTL5000_CHIP_ANA_POWER register is cached. Update the cached
value instead of writing it directly.
Upstream-status: sent
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
(cherry picked from commit 309abdeda8c9331013f25b1a1209d9ce8334237b)
(cherry picked from commit 8a8b303a7431e66a7ec6ec52bc0e04ed0a1335d0)
Since commit e5d80e82e32e (ASoC: sgtl5000: Convert to use regmap directly) a
kernel oops is observed after a suspend/resume sequence.
The kernel oops happens inside sgtl5000_restore_regs() as codec->reg_cache is no
longer a valid pointer.
Add the remaining register entries into sgtl5000_reg_defaults[] and remove
sgtl5000_restore_regs() completely, which allows suspend/resume to work fine and
make the code simpler.
Tested on a im53-qsb board.
Reported-by: Shawn Guo <shawn.guo@freescale.com>
Tested-by: Shawn Guo <shawn.guo@freescale.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 29aa37cddfb9b721013ff28608200d73a9426368)
Powering down PLL before switching to a mode that does not use it
is a bad idea. It would cause the SGTL5000 be without internal
clock supply, especially on the I2C interface, which would make
subsequent access to it fail.
Thus, in case of not using PLL any longer, first set the mode
control, then power down PLL.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
(cherry picked from commit e06e4c2d530fd4995c41083009647263ccd77d3b)
The SGTL5000 Capture Attenuate Switch (or "ADC Volume Range Reduction"
as it is called in the manual) is single bit only.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
(cherry picked from commit 65f2b226763bc348a9b9145aa5e17e7e3f6d8c35)
When a sound capture/playback is terminated while a playback/capture
is running, power_vag_event() will clear SGTL5000_CHIP_ANA_POWER in
the SND_SOC_DAPM_PRE_PMD event, thus muting the respective other
channel.
Don't clear SGTL5000_CHIP_ANA_POWER when both DAC and ADC are active
to prevent this.
(cherry picked from commit f091f3f07328f75d20a2a5970d1f8b58d95fc990)
According to the sgtl5000 reference manual, the default value of CHIP_SSS_CTRL
is 0x10.
Reported-by: Oskar Schirmer <oskar@scara.com>
(cherry picked from commit 016fcab8ff46fca29375d484226ec91932aa4a07)
The VAG_POWER must be enabled after all other bits in CHIP_ANA_POWER
and disabled before any other bit in CHIP_ANA_POWER. See the SGTL5000
datasheet (Table 31, BIT 7, page 42-43). Failing to follow this order
will result in ugly loud "POP" noise at the end of playback.
To achieve such order, use the _PRE and _POST DAPM widgets to trigger
the power_vag_event, where the event type check has to be fixed
accordingly as well.
(cherry picked from commit dd4d2d6dfb49e8916064f2cb07f0ad7b32a82fb7)
After a 'reboot' command in Linux or after pressing the system's reset button
the sgtl5000 driver fails to probe:
sgtl5000 0-000a: Device with ID register ffff is not a sgtl5000
sgtl5000 0-000a: ASoC: failed to probe CODEC -19
imx-sgtl5000 sound.12: ASoC: failed to instantiate card -19
imx-sgtl5000 sound.12: snd_soc_register_card failed (-19)
sgtl5000 codec does not have a reset line, nor a reset command in software, so
after a system reset the codec does not contain the default register values
from sgtl5000_reg_defaults[] anymore, as these are only valid after a
power-on-reset cycle.
Fix this issue by explicitly reading all the reset register values from
sgtl5000_reg_defaults[] and writing them back into sgtl5000 to ensure a sane
state.
Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
(cherry picked from commit af8ee11209e749c75eabf32b2a4ca631f396acf8)
sound/soc/codecs/sgtl5000.c
sgtl5000 microphone gain only has 2 bits of resolution, so maximum value is 3.
From Eric Nelson:
"We also found that for the microphones we have here (commodity PC boom mics) a
default value of 2 for the gain gives the best results."
So change the default microphone gain as well.
LINE_IN also needs VAG_POWER on or we may hear noise when directly
route LINE_IN to Headphone Mux.
Tested on imx28evk.
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
Correct SGTL5000_CHIP_CLK_CTRL to SGTL5000_CHIP_REF_CTRL in
sgtl5000_restore_regs(), and add comment to explain the
restore order.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Zeng Zhaoming <zengzm.kernel@gmail.com>
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
As manual described, VAG is an internal voltage reference of DAC/ADC,
So enabled it before DAC/ADC up.
One more thing should care about is VAG fully ramped down requires 400ms,
wait it to avoid pop.
Give the correct number of entries to TLV_DB_RANGE_HEAD to prevent
reading more data than actually is in the array.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Ensure all mask bits are clear before setting new value.
Acked-by: Dong Aisheng <b29396@freescale.com>
Acked-by: Liam Girdwood <lrg@ti.com>
We have defined SGTL5000_LINREG_VDDD_MASK in sgtl5000.h,
use it instead of hardcoded (0x1 << 4) - 1 for the mask.
Otherwise calling ldo_regulator_remove() does not unregister regulator
and free memories.
According to the datasheet:
CHIP_MIC_CTRL 0x002A
BITS[9:8] BIAS_RESISTOR
0x0 = Powerd off
0x1 = 2.0 kohm
0x2 = 4.0 kohm
0x3 = 8.0 kohm
To set mic bias resistor, we need to update bits[9:8] of
SGTL5000_CHIP_MIC_CTRL register.
0x0 = Powerd off
0x1 = 2.0 kohm
0x2 = 4.0 kohm
0x3 = 8.0 kohm
Thus SGTL5000_BIAS_R_MASK should be defined as 0x0300 instead of 0x0200.
The module device table for of_device_id should use "of" type.
version.
Bug 1034241
Change-Id: Id0037f18afa58be82cbeeb43e97b606614fb8ba8
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/125273
GVS: Gerrit_Virtual_Submit
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Add latest TI aic326x driver.
Bug 1034241
Change-Id: I8457538025b2989c4baa5eaefef48bdd5535def9
Reviewed-on: http://git-master/r/125167
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
98088 codec register value is altered to fix no audio issue after
reset. Previously after reset the register value was getting wiped
out.
Bug 1017782
Change-Id: I060929bfb868c48dc4db9def171a3bdd167a3913
Reviewed-on: http://git-master/r/120319
Tested-by: Sayak Choudhury <sayakc@nvidia.com>
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Add code for headset detection according to that
state transitions mentioned for JKSNS field in the
max98088 codec datasheet
Bug: 110529
Bug: 1008246
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/112127
(cherry picked from commit 12a2259e0e9cf7da4bf64bad2a97c32cec41477c)
Change-Id: I7d45b210dd02f181e71a08d9b3de7cff109dd88b
Reviewed-on: http://git-master/r/114445
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Bug 964287
1) Add support for resetting the codec while entering in lp0
state to save codec power in lpo for KAI.
2) Fix for cache sync.
3) Add index sync functionality.
Change-Id: I04039eb55944bfe7f06e6a1405ac3c810c5688a1
Reviewed-on: http://git-master/r/104480
Tested-by: Daniel Solomon <daniels@nvidia.com>
disable the compilation of minidsp specific code,
we are disabling the minidsp in codec because the driver is
not stable and different customers are using different process flows
for mini dsp
Change-Id: I08f8f485f1a379773f2f1f7ae2fd1b3a89c45d07
Reviewed-on: http://git-master/r/101232
Reviewed-by: Simone Willett <swillett@nvidia.com>
Allow setting bias level to turn off clock extern1 on enterprise
when codec is idle. Added a dummy widget to make the
target_bias_level to BIAS_OFF as per required by the new ALSA
kernel.
Bug 984678
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: I29de405c26286eee0a49e655f1d4236f6093ce8a
Reviewed-on: http://git-master/r/100287
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
Bug 949219
Change-Id: I9c2a0aa22432c586a7e72273ad935d42332e873f
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/95087
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
This reverts commit 774fa71fc9834fbdcb297048d9e9a4bc7b944b48
Change-Id: Ib187dff51d3b2fd2b2ac0c98a53abe07c99148aa
Reviewed-on: http://git-master/r/101359
bug 949219
Change-Id: I4409eaff4042967133cc948452ca8e52d15b2d18
Reviewed-on: http://git-master/r/92279
Use non-inverting type alsa control for headphones as same have
been used for spk and recv
Change-Id: I39d2613071063782dff8151b07ef46ca8e16db5c
Reviewed-on: http://git-master/r/101234
disable the flags for turning off the mini dsp support
Change-Id: Ieb0b18fc3cc1143cbd0a315c85688d2f1ae4efe1
Reviewed-on: http://git-master/r/101233
Allow setting bias level to turn off clock extern1 on KAI when
codec is idle. Added a dummy widgets to make the target_bias_level
to BIAS_OFF as per required by the new ALSA kernel.
Bug 964287
Change-Id: I628744040866a9879eedc41ed4ee25af38ed86fb
Reviewed-on: http://git-master/r/99667
Tested-by: Hunk Lin <hulin@nvidia.com>
The bias control must be done after the default register value
been restored.
Bug 964400
Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/96658
1. Use rt5639/40 internal clk source during jack insert detection.
2. Add delay to 100ms.
Bug 955019
Reviewed-on: http://git-master/r/93510
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
(cherry picked from commit 4c07fc1b10ac8abbbf167952071e47aa6179a635)
Change-Id: I4021232674f5432392dc013ddc76c3bf08b44ed0
Reviewed-on: http://git-master/r/95874
Tested-by: Manoj Gangwal <mgangwal@nvidia.com>
check max98095_reset() return value, this function fails if codec
read/write fails.
Change-Id: I4dddd75e0870e4168288396a462133f7287ad72e
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/95078
Allow bias off in order to turn off clock extern1 when codec
is not used.
Bug 957635
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
(cherry picked from commit adc6929ab3170acd6a0b2cee4f65fa20a1c1d30f)
Change-Id: I4f2e91b0cd9bb4516a5722d2df268f08e78f92e2
Reviewed-on: http://git-master/r/93949
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
check for revision id, it must be 0x40 as per the datasheet,
if its not 0x40 then dont allow the card to register by failing
in the codec probe. This functionality will be required when the
same board support multiple codecs. Also register the irq only
after validating the codec.
Change-Id: I8553b85d534428c7137ec2d03e2f814b898609a6
Reviewed-on: http://git-master/r/90061
update the TIAIC326x driver for voice call
Change-Id: I1443b462b5b7e049fe4cbf39215aea6eeb955500
Reviewed-on: http://git-master/r/88012
Fix for pop noise 'cut' from internal speaker while booting
on kai board.
Bug 929049
Change-Id: I9c3fe7e05d869709f50036042e70abc91722885e
Reviewed-on: http://git-master/r/87685
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Add support for headset detection for ALC5639/40
codec for kai board.
Bug 937914
Change-Id: I0bb9e913601c37a1cc8f7094fbdd3885aeec92b3
Reviewed-on: http://git-master/r/86348
Tested-by: Chandler Zhang <chazhang@nvidia.com>
bug 940617
Change-Id: I83f43820761d0227d7a594123d22fe79089e2e15
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/86280
Tested-by: Gerrit_Virtual_Submit
Change-Id: Ia6fac687a6b302fa49b6f8a7cfd74abfde5b45f9
Reviewed-on: http://git-master/r/84544
