check for revision id, it must be 0x40 as per the datasheet,
if its not 0x40 then dont allow the card to register by failing
in the codec probe. This functionality will be required when the
same board support multiple codecs. Also register the irq only
after validating the codec.
Change-Id: I8553b85d534428c7137ec2d03e2f814b898609a6
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/90061
Reviewed-by: Scott Peterson <speterson@nvidia.com>
update the TIAIC326x driver for voice call
Change-Id: I1443b462b5b7e049fe4cbf39215aea6eeb955500
Reviewed-on: http://git-master/r/88012
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Fix for pop noise 'cut' from internal speaker while booting
on kai board.
Bug 929049
Change-Id: I9c3fe7e05d869709f50036042e70abc91722885e
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/87685
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Add support for headset detection for ALC5639/40
codec for kai board.
Bug 937914
Change-Id: I0bb9e913601c37a1cc8f7094fbdd3885aeec92b3
Reviewed-on: http://git-master/r/86348
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
Tested-by: Chandler Zhang <chazhang@nvidia.com>
bug 940617
Change-Id: I83f43820761d0227d7a594123d22fe79089e2e15
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/86280
Tested-by: Gerrit_Virtual_Submit
Change-Id: Ia6fac687a6b302fa49b6f8a7cfd74abfde5b45f9
Reviewed-on: http://git-master/r/84544
configure ASI2 as master and add missing dapm widgets and routes
Change-Id: If2f9c8361888ec40147cd5537f435c91e50cbcc8
Reviewed-on: http://git-master/r/84538
Change-Id: Ie8ef49b2a76e27e07835fb61bce23ddf69c0b1f9
Reviewed-on: http://git-master/r/84537
Change-Id: I682ccc9ba44f82b8acf836c1703d5d54419da54b
Reviewed-on: http://git-master/r/84535
change the init values of aic326x registers to keep unrequired
codec elements powered off to save power, these codec elements would
be turned on when required by dapm
Change-Id: Id843fae2ca1f30b77c402da7ac24e89fb04828b6
Reviewed-on: http://git-master/r/84534
add mixer controls for configuring CM modes and use the
non-inverting modes for speaker and receiver mixers
Change-Id: I247ccea17d08dc92ac035d6e8070fb146d26b7f5
Reviewed-on: http://git-master/r/84532
Change-Id: If40c181227981696961d3c563008261e5324e807
Reviewed-on: http://git-master/r/84528
The value of reset register of ALC5639 is 0x0008
instead of 0x000c.
bug 931371
Change-Id: I5fbf31411ddab2358d61f998f74a7b1f8c151312
Signed-off-by: Kerwin Wan <kerwinw@nvidia.com>
Reviewed-on: http://git-master/r/83318
- Added suspend/resume support for ALC5640
- Fix for I2S1 interface
Bug 936013
Change-Id: I60b0eb224e9475b722ecb9e2fb8bf0a6dae12767
Reviewed-on: http://git-master/r/83058
Reviewed-by: Johnny Qiu <joqiu@nvidia.com>
Tested-by: Johnny Qiu <joqiu@nvidia.com>
The vendor supplied driver has to be fixed to work on older kernels.
Bug 931371
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/78278
(cherry picked from commit ffce206b2d67bb9618a97d08e88c6ae25ba79baa)
Change-Id: Ifd8712758307cd4f31526cc050c62a89187a7c8d
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82733
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Add files for ALC5639 codec as provided by vendor.
Bug 931371
Reviewed-on: http://git-master/r/78277
(cherry picked from commit b45ab605accb68fd303deec5ed962f213047f9bf)
Change-Id: I6c19e13c3dfec394cef812a5be1bc2ee5d58751b
Reviewed-on: http://git-master/r/82732
Add support for ALC5639 codec present in the KAI A01 board.
Bug 931371
Reviewed-on: http://git-master/r/77952
(cherry picked from commit 1747f1003be6413e0e173dee39b25afcbe522528)
Change-Id: I5180d4ed669c4100ca29e6ed508406e69a88fe88
Reviewed-on: http://git-master/r/82730
Clock function for non-integral of sample
rate clocks does not work correctly and
generates incorrect sample rate.
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/75792
Change-Id: I39977c9e2b647d4eabc8d9209c2d05665f708ab0
Reviewed-on: http://git-master/r/77752
In Voice Call when ringtone stream is opened the codec is busy and the
call mode needs to be set before closing the ringtone stream hence we
put the logic in codec driver to enable dai mode change even when codec
is busy
Bug: 919350
Reviewed-on: http://git-master/r/76954
Change-Id: Iaf7176b3a7f72709140e29c2c6071ab4101ec418
Reviewed-on: http://git-master/r/77732
Instead of using tight bitclk use 2x of minimum bitclk requirement
in codec master mode. This change is needed to have clean audio
in codec master mode on Tegra30 based cardhu platform.
Bug 915107
Change-Id: Ia59e1a906415ad8fd1ed324ab4dabef61746b62f
Reviewed-on: http://git-master/r/75706
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/76467
commit 37d5993c5cc9bc83762ae1b5bd287438022e8afe upstream.
Record the clock after the divider as that is what all SYSCLK users see.
Without this the other clock configuration in the device comes out at
half rate.
Change-Id: Ifd4d1165bc59b4cb35a3d30e43ebba442c67a68c
Reviewed-on: http://git-master/r/74167
Implementation of suspend/resume functionality
is not proper for ALC5640 codec , so remove it
temporarily.
Bug 910788
Change-Id: I243c327602a45a3084befd17a1e722e4d844e502
Reviewed-on: http://git-master/r/73478
(cherry picked from commit 3e24bcc4df716bd1e1f3772300aaa9988319f91a)
Reviewed-on: http://git-master/r/73962
Changes made to add support of ALC5640 codec
for cardhu and support wm8903 codec also without
need for code recompilation.
Bug 910788
Change-Id: Iace74293a44c38eaae516552f03d8bfa6bfe936f
Reviewed-on: http://git-master/r/71455
codec->hw_write is broken now, convert codec->hw_write to snd_soc_write.
The hardware has 2 banks of registers sharing a section in I2C register space.
The 1st bank is the primary one and is cached.
The 2nd bank is for loading coefficients only and they do not need cache.
These coefficients registers are therefore direct writes.
Thus we set cache_bypass flag to deal with this before calling snd_soc_write.
Acked-by: Liam Girdwood <lrg@ti.com>
(cherry picked from commit 0d8d293898ff0ea395840cdf2ac85fbd53c8d3ea)
Change-Id: I162206b7c542d85c0349cb5c2af8048e8cee6700
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/69969
Move the biquad channel names to a separate array and iterate over it in
max98095_get_bq_channel rather than duplicating the hardcoded channel
names. Add an error message if an invalid channel is passed and check
the error in the callers.
Also added a BUILD_BUG_ON to ensure that the bq_mode_name and controls
arrays are the same size.
Signed-off-by: Ryan Mallon <rmallon@gmail.com>
(cherry picked from commit c855a1a7ff49a43e1e35571d504e89b4c670693d)
Change-Id: Id8e6b672007292416ad60a5d988b987f841927b9
Reviewed-on: http://git-master/r/69968
Visual inspection shows that max98095_put_eq_enum() and
max98095_put_bq_enum() each have a possible NULL deref of 'pdata'.
This change moves the NULL check above the use.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
Acked-by: Peter Hsiang <Peter.Hsiang@maxim-ic.com>
(cherry picked from commit 539494253547d078089cc15490e83f6e5f2e7213)
Change-Id: I587b8d2ea14cdf8ce33a4319b6c2ba3a4df067aa
Reviewed-on: http://git-master/r/69963
This patch adds the equalizer and biquad filter controls.
Signed-off-by: Peter Hsiang <peter.hsiang@maxim-ic.com>
(cherry picked from commit dad31ec133adb20c8fd10bfd9379da3f08b8721e)
Change-Id: I5f0f1005cecc1ca28bac360a55a86de7b9cddfe1
Reviewed-on: http://git-master/r/69961
Reviewed-by: Simone Willett <swillett@nvidia.com>
Current implementation set max98095->sysclk/max98088->sysclk to freq twice.
Set it once is enough, this patch removes the first assignment in case
we may set invalid clock frequency to max98095->sysclk/max98088->sysclk.
Acked-by: Peter Hsiang <peter.hsiang@maxim-ic.com>
(cherry picked from commit 74ab24af4fe165de5af01d0507250dd099f096b0)
Change-Id: Ia287942e113a5e13598f537a5d976c49ace8af63
Reviewed-on: http://git-master/r/69964
This patch adds the MAX98095 CODEC driver.
(cherry picked from commit 82a5a936f6dea13849d93a2899a9b7294a8db336)
Change-Id: I0a9805a90f46e30c756e5a266e96904597242185
Reviewed-on: http://git-master/r/69960
Change-Id: Ifd53d0cb0cd6022c3f526df3ba79cd4369796749
Reviewed-on: http://git-master/r/69783
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
set global shutdown bit to zero so that codec will shutdown in
bias off case
bug 899662
Change-Id: I86cf5d9567463166fc3ee0585083faba35dac301
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/63858
When codec enters suspend mic bias gets turned off. As a result if a
mic is already plugged in a mic removal event gets triggered. Once
codec driver gets mic removal interrupt it sleeps for the duration
of debounce time which causes kernel power manager to abort suspend.
To avoid this scenario disable mic detect IRQ before powering off
codec and enable the same during resume.
Change-Id: Ic3c90d73c9f2742b6771f7e3fe0e3fb1f59e1cd9
Reviewed-on: http://git-master/r/68662
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit 72531c9434fa884d20cb3c36fcec83752f32fdf4 upstream.
According to the datasheet:
The BIT[5:4] of ADC Control Register 2 is to control the word width.
00 = 25 Bits
01 = 20 Bits
10 = 16 Bits
11 = Invalid
Thus, the AD1836_ADC_WORD_OFFSET should be defined as 4.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
commit ed3e80c4c991a52f9fce3421536a78e331ae0949 upstream.
commit 2391a0e06789a3f1718dee30b282562f7ed28c87 upstream.
This patch makes it possible to set DAI mode to its currently applied
value even if codec is active. This is necessary to allow
aplay -t raw -r 44100 -f S16_LE -c 2 < /dev/urandom &
alsactl store -f backup.state
alsactl restore -f backup.state
to work without returning errors. This patch is based on a patch sent
by Klaus Kurzmann <mok@fluxnetz.de>.
Signed-off-by: Timo Juhani Lindfors <timo.lindfors@iki.fi>
commit 54dc6cabe684375b3cf549c7b0545613d694aba8 upstream.
The coefficient RAM must be saved in a shadow so it can
be restored when the codec is powered on using
regulator_bulk_enable().
Signed-off-by: Johannes Stezenbach <js@sig21.net>
Change the executable permission on the files.
Change-Id: I8109f4e255847ec5453c98c47974a89e4cf56af9
Reviewed-on: http://git-master/r/68336
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Using snd_soc_write is causing some issue with TI codec.
So register read and write are handled locally inside the codec calls.
Added checking to continue card register based on codec availability, this
help to use either TI codec or wm8753 codec being present in the board.
bug 816608
Change-Id: Ie5edd1c70609991c28216bbc3a0ffcafd0f815ab
Reviewed-on: http://git-master/r/68044
Adding the code for supporting TI AIC3262 codec.
bug 816608
Change-Id: I19c3e03e8fd442c0c19a72a7efeddcd0ca05a7e1
Reviewed-on: http://git-master/r/67279
Integrating the mini dsp headers to support the TI codec.
Change-Id: I2191627f96db9134a2cbd6258b9b958bccc0e6e7
Reviewed-on: http://git-master/r/67045
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R1afd379263506d2f17e5cdd0ca0398a8ba0a93b8
Add a dummy capture DAI to dit_stub_dai so that it can also be used
for audio capture path.
Bug 872652
Change-Id: Ic7092931b02e323fa7ae07239d6a6e19880b6bc4
Reviewed-on: http://git-master/r/61481
Rebase-Id: R2446d2806f96d0def7938a78a4117cdb69c22183
with the idle bias off flag set, dapm will turn
the codec bias off in standby
Bug: 862023
Change-Id: I21758bb08efbfba0e06dba5a129a57be38331cb9
Reviewed-on: http://git-master/r/61087
Rebase-Id: Rc27d29eceff9ccfa2cf896b5aa08728b48cfe6f6
Bug: 890385
Bug: 862023
Change-Id: Icec0be967ead5733aa600707c3ba4af99375e4ae
Reviewed-on: http://git-master/r/59102
Rebase-Id: Rc16aeac4ea1ba15e214fda504ef17aaef2c83ed5
Bug: 862023
Change-Id: I17352ed290b3f1e319dc8efd112bb6dfddc51f52
Reviewed-on: http://git-master/r/58416
Rebase-Id: Re6ec1485173c3504a13d760a25d34ccd571489e5
Bug: 862023
Change-Id: I1784a813ad8ef224f0587ba977518c2940b66e01
Reviewed-on: http://git-master/r/55674
Rebase-Id: R960030914089aa1eefcbb0d8ac2eda28c8095785
Bug: 862023
Change-Id: Ibaa3ffbb9e81736e45c2bccb0d6e1828cde4025b
Reviewed-on: http://git-master/r/55474
Rebase-Id: Rf4af409992ad20aa854736727df5060ce82435ed
Bug: 862023
Change-Id: Ieb9247cef5feecf3e241d8980f9c4376cadf2965
Reviewed-on: http://git-master/r/55465
Rebase-Id: Rf725fad369dbbe4d5f6eaa7b667170a127fa0a08
Bug: 862023
Change-Id: I26789c9e5bc7ebd51f086a3be650186d8e541519
Reviewed-on: http://git-master/r/57035
Rebase-Id: Rfe45465b2369c8cbb864233e33ff70367a5a1e2d
commit 8eeea521d9d0fa6afd62df8c6e6566ee946117fa upstream.
The field is no longer initialised so this will crash if running on
wm8958.
Reported-by: Thomas Abraham <thomas.abraham@linaro.org>
