The platform_device_id is not modified by the driver and core uses it as
const.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Since we pass the port number through file private data for debugfs we cast
it to and from a pointer so use uintptr_t in order to ensure that the
types are compatible, avoiding warnings on 64 bit platforms where pointers
are 64 bit and unsigned integers 32 bit.
Signed-off-by: Mark Brown <broonie@linaro.org>
audmux_debugfs_init() is marked as __init, but is called from imx_audmux_probe()
which is not marked as __init. This creates a section mismatch and a potential
runtime crash (if imx_audmux_probe() is called after the .init section was
dropped). This patch removes the __init annotation from audmux_debugfs_init(),
which fixes the following warning:
WARNING: sound/soc/built-in.o(.text+0x86960): Section mismatch in reference
from the function imx_audmux_probe() to the function
.init.text:audmux_debugfs_init()
When audmux_clk is used and clk_prepare_enable function succeed,
the memory alloc'd to buf variable is leaked
Signed-off-by: Felipe Pena <felipensp@gmail.com>
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
kernel
Booting a mx51babbage board with a non-dt kernel leads to the following crash:
Unable to handle kernel NULL pointer dereference at virtual address 0000001c
pgd = 80004000
[0000001c] *pgd=00000000
Internal error: Oops: 5 [#1] SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.11.0-next-20130903 #287
task: 9f860000 ti: 9f862000 task.ti: 9f862000
PC is at of_get_next_available_child+0x5c/0x68
LR is at of_get_next_available_child+0x1c/0x68
pc : [<8043ea58>] lr : [<8043ea18>] psr: 60000193
sp : 9f863d58 ip : 00000000 fp : 9f863d74
r10: 9f89a010 r9 : 9f862000 r8 : 807bb26c
r7 : 80615d5c r6 : 00000000 r5 : 60000113 r4 : 00000000
r3 : 00000000 r2 : 808770a4 r1 : 00000011 r0 : 60000113
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 90004019 DAC: 00000017
Process swapper/0 (pid: 1, stack limit = 0x9f862240)
Stack: (0x9f863d58 to 0x9f864000)
This is caused by commit 8548a464b9 (ASoC: imx-audmux: Read default
configuration from devicetree).
In order to fix this, add a check for 'of_id' so that
imx_audmux_parse_dt_defaults() only gets called when a dt kernel is running.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Adds a function to parse a default port configuration from devicetree.
clk_prepare_enable() may fail, so let's check its return value and propagate it
in the case of error.
Since commit ab78029 (drivers/pinctrl: grab default handles from device core),
we can rely on device core for handling pinctrl.
So remove devm_pinctrl_get_select_default() from the driver.
By using devm_clk_get() we can save a call to clk_put().
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
Fix the following sparse warning:
sound/soc/fsl/imx-audmux.c:182:3: warning: symbol 'audmux_type' was not declared. Should it be static?
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Liam Girdwood <lrg@ti.com>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
When audmux_read_file is called, it means the driver is already
initialised successfully, so we don't need to check audmux_base.
It also fix smatch warning:
sound/soc/fsl/imx-audmux.c:78 audmux_read_file() warn: possible memory leak of 'buf'
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
The MX31 Audmux also has 7 Ports.
This patch adds the missing define, and makes the debugfs code iterate
over that port too.
Signed-off-by: Torben Hohn <torbenh@linutronix.de>
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Linux 3.4-rc3 contains a bunch of Tegra changes which are conflicting
annoyingly with the new development that's going on for Tegra so merge
it up to resolve those conflicts.
sound/soc/soc-core.c
sound/soc/tegra/tegra_i2s.c
sound/soc/tegra/tegra_spdif.c
Linux 3.4-rc2 contains some bug fixes we need, including the addition of
an export for regcache_sync_region().
Freescale PowerPC and ARM/IMX families share the same SSI IP block.
The patch merges sound/soc/imx into sound/soc/fsl, so that the possible
code sharing and consolidation can happen.
This is a plain merge, except that menuconfig SND_POWERPC_SOC is added
in Kconfig for PowerPC platform as a correspondence to SND_IMX_SOC for
IMX platform.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Timur Tabi <timur@freescale.com>
