Freescale PowerPC and ARM/IMX families share the same SSI IP block.
The patch merges sound/soc/imx into sound/soc/fsl, so that the possible
code sharing and consolidation can happen.
This is a plain merge, except that menuconfig SND_POWERPC_SOC is added
in Kconfig for PowerPC platform as a correspondence to SND_IMX_SOC for
IMX platform.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Timur Tabi <timur@freescale.com>
Pull "ARM: driver specific updates" from Arnd Bergmann:
"These are all specific to some driver. They are typically the
platform side of a change in the drivers directory, such as adding a
new driver or extending the interface to the platform. In cases where
there is no maintainer for the driver, or the maintainer prefers to
have the platform changes in the same branch as the driver changes,
the patches to the drivers are included as well.
A much smaller set of driver updates that depend on other branches
getting merged first will be sent later.
The new export of tegra_chip_uid conflicts with other changes in
fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED
conflicts with the cleanup of the interrupt handling of that driver.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up aforementioned trivial conflicts.
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci
mmc: sdhci-s3c: add platform data for the second capability
ARM: SAMSUNG: support the second capability for samsung-soc
ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC
ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1
ARM: EXYNOS: Enable MDMA driver
regulator: Remove bq24022 regulator driver
rtc: sa1100: add OF support
pxa: magician/hx4700: Convert to gpio-regulator from bq24022
ARM: OMAP3+: SmartReflex: fix error handling
ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API
ARM: OMAP3+: SmartReflex: micro-optimization for sanity check
ARM: OMAP3+: SmartReflex: misc cleanups
ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument
ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata()
ARM: OMAP3+: hwmod: add SmartReflex IRQs
ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need
ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register
ARM: OMAP3+: SmartReflex: Add a shutdown hook
ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP
arch/arm/mach-tegra/Makefile
arch/arm/mach-tegra/fuse.c
drivers/rtc/rtc-sa1100.c
Fix the following section mismatch warning:
WARNING: vmlinux.o(.data+0x35be8): Section mismatch in reference from the variable imx_audmux_driver to the function .init.text:imx_audmux_probe()
The variable imx_audmux_driver references
the function __init imx_audmux_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console
It adds device tree probe support for imx-audmux driver.
Signed-off-by: Richard Zhao <richard.zhao@linaro.org>
It renames the legacy name mxc used in audmux function and macro
to imx.
As audmux becomes a platform driver and its callers are all ASoC
machine drivers, there is no reason to keep it in arch folder, so
move it to sound/soc/imx.
One bonus point would be those ASoC machine drivers stop including
mach/audmux.h, since it's been moved to sound/soc/imx/imx-audmux.h.
This should be a move to the right direction in terms of single kernel
image goal.
