Since commit 7b11304 ("dma: mxs-dma: Report correct residue for cyclic DMA")
the mxs dmaengine driver has support for residue reporting. So there is no need
to specify the SND_DMAENGINE_PCM_FLAG_NO_RESIDUE flag anymore. This allows a
finer grained resolution for the PCM pointer as well as avoids the race
condition that can occur with the period counting that is used when the
dmaengine driver does not support residue reporting.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
The ASoC core assumes that the PCM component of the ASoC card transparently
moves data around and does not impose any restrictions on the memory layout or
the transfer speed. It ignores all fields from the snd_pcm_hardware struct for
the PCM driver that are related to this. Setting these fields in the PCM driver
might suggest otherwise though, so rather not set them.
Makes the code shorter.
With mxs-dma converted to generic DMA bindings, let's move mxs-pcm to
use it by removing flages SND_DMAENGINE_PCM_FLAG_NO_DT and
SND_DMAENGINE_PCM_FLAG_COMPAT. As the result, those mxs custom dma
params code can be removed now.
Use the generic dmaengine PCM driver instead of a custom implementation.
The MXS SAIF is only half-duplex so set the SNDRV_PCM_INFO_HALF_DUPLEX flag for
the PCM in order to prevent playback and capture from running at the same time.
Refactor the dmaengine PCM library to allow the DMA channel to be requested
before opening a PCM substream. snd_dmaengine_pcm_open() now expects a DMA
channel instead of a filter function and filter parameter as its parameters.
snd_dmaengine_pcm_close() is updated to not release the DMA channel. This allows
a dmaengine based PCM driver to request its channels before the substream is
opened.
The patch also introduces two new functions, snd_dmaengine_pcm_open_request_chan()
and snd_dmaengine_pcm_close_release_chan(), which have the same signature and
behaviour of the old snd_dmaengine_pcm_{open,close}() and internally use the new
variants of these functions. All users of snd_dmaengine_pcm_{open,close}() are
updated to use snd_dmaengine_pcm_open_request_chan() and
snd_dmaengine_pcm_close_release_chan().
Currently the mxs_dma_data struct, which gets passed to the dmaengine driver, is
allocated in the pcm driver's open callback. The mxs_dma_data struct has exactly
one field which is initialized from the the same field in the mxs_pcm_dma_params
struct. The mxs_pcm_dma_params struct gets passed to the pcm driver from the dai
driver. Instead of taking this indirection embed the mxs_dma_data struct
directly in the mxs_pcm_dma_params struct. This allows us to simplify the pcm
driver quite a bit, since we don't have to care about memory managing the
mxs_dma_data struct anymore.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Currently the sound dmaengine pcm helper functions implement the pcm_pointer
callback by trying to count the number of elapsed periods. This is done by
advancing the stream position in the dmaengine callback by one period.
Unfortunately there is no guarantee that the callback will be called for each
elapsed period. It may be possible that under high system load it is only called
once for multiple elapsed periods. This patch renames the current implementation
and documents its shortcomings and that it should not be used anymore in new
drivers.
The next patch will introduce a new snd_dmaengine_pcm_pointer which will be
implemented based on querying the current stream position from the dma device.
Acked-by Vinod Koul <vinod.koul@linux.intel.com>
Acked-by: Dong Aisheng <dong.aisheng@linaro.org
Same as the commit 518de86 (ASoC: tegra: register 'platform' from DAIs,
get rid of pdev), it makes mxs-pcm not a platform_driver but helper to
register "platform", so that the platform_device for mxs-pcm can be
saved completely.
Pull MTD changes from David Woodhouse:
- Artem's cleanup of the MTD API continues apace.
- Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst
others.
- More work on DiskOnChip G3, new driver for DiskOnChip G4.
- Clean up debug/warning printks in JFFS2 to use pr_<level>.
Fix up various trivial conflicts, largely due to changes in calling
conventions for things like dmaengine_prep_slave_sg() (new inline
wrapper to hide new parameter, clashing with rewrite of previously last
parameter that used to be an 'append' flag, and is now a bitmap of
'unsigned long flags').
(Also some header file fallout - like so many merges this merge window -
and silly conflicts with sparse fixes)
* tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits)
mtd: docg3 add protection against concurrency
mtd: docg3 refactor cascade floors structure
mtd: docg3 increase write/erase timeout
mtd: docg3 fix inbound calculations
mtd: nand: gpmi: fix function annotations
mtd: phram: fix section mismatch for phram_setup
mtd: unify initialization of erase_info->fail_addr
mtd: support ONFI multi lun NAND
mtd: sm_ftl: fix typo in major number.
mtd: add device-tree support to spear_smi
mtd: spear_smi: Remove default partition information from driver
mtd: Add device-tree support to fsmc_nand
mtd: fix section mismatch for doc_probe_device
mtd: nand/fsmc: Remove sparse warnings and errors
mtd: nand/fsmc: Add DMA support
mtd: nand/fsmc: Access the NAND device word by word whenever possible
mtd: nand/fsmc: Use dev_err to report error scenario
mtd: nand/fsmc: Use devm routines
mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform
mtd: fsmc_nand: add pm callbacks to support hibernation
Move the header to a more common place.
The mxs dma engine is not only used in mx23/mx28, but also used
in mx50/mx6q. It will also be used in the future chips.
Rename it to mxs-dma.h, and create a new folder include/linux/fsl/ to
store the Freescale's header files.
change mxs-dma driver, mxs-mmc driver, gpmi-nand driver, mxs-saif driver
to the new header file.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Huang Shijie <b32955@freescale.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-by: Chris Ball <cjb@laptop.org>
Request the DMA channel in the PCM open callback instead of the hwparams
callback, this allows us to let open fail if no dma channel is available. This
also fixes a bug where the channel will be requested multiple times if hwparams
is called multiple times.
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits)
ARM: mach-shmobile: specify CHCLR registers on SH7372
dma: shdma: fix runtime PM: clear channel buffers on reset
dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit
dmaengine/ste_dma40: clear LNK on channel startup
dmaengine: intel_mid_dma: remove legacy pm interface
ASoC: mxs: correct 'direction' of device_prep_dma_cyclic
dmaengine: intel_mid_dma: error path fix
dmaengine: intel_mid_dma: locking and freeing fixes
mtd: gpmi-nand: move to dma_transfer_direction
mtd: fix compile error for gpmi-nand
mmc: mxs-mmc: fix the dma_transfer_direction migration
dmaengine: add DMA_TRANS_NONE to dma_transfer_direction
dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels
dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe
dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled.
dma: mxs-dma: fix a typo in comment
DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove
video i.MX IPU: Fix display connections
i.MX IPU DMA: Fix wrong burstsize settings
dmaengine/ste_dma40: allow fixed physical channel
Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c}
The conflicts looked pretty trivial, but I'll ask people to verify them.
The commit 49920bc (dmaengine: add new enum dma_transfer_direction)
changes the type of parameter 'direction' of device_prep_dma_cyclic
from dma_data_direction to dma_transfer_direction.
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
This reverts commit dbec3b30a601791717bc5bb827e210c3b5d6e067 as it
should never have been applied to the ASoC tree at all, let alone 3.2.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
sound/soc/mxs/mxs-pcm.c
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
The sound driver refuses to load as module, because of the missing
MODULE_LICENSE("GPL").
The file header indicates that the driver is indeed published under
the GPL.
Factor out some boilerplate code.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Acked-by: Liam Girdwood <lrg@ti.com>
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
