path: root/sound/soc/mxs
2015-09-14ASoC: mxs-sgtl5000: Convert to devm_snd_soc_register_cardAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-02-04Merge remote-tracking branches 'asoc/topic/fsl-spdif', 'asoc/topic/imx', ↵Mark Brown
'asoc/topic/intel', 'asoc/topic/mxs-saif' and 'asoc/topic/nuc900' into asoc-next
2015-01-06ASoC: mxs-sgtl5000: Use static DAI format setupLars-Peter Clausen
Set the dai_fmt field in the dai_link struct instead of manually calling snd_soc_dai_fmt(). This makes the code cleaner and shorter. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-30ASoC: mxs-saif: Do not store the irq number in the private structureFabio Estevam
The irq number is only used inside the probe function, so there is really no need to store it in the private structure. Use a local 'irq' variable to hold the the irq number instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-08Merge remote-tracking branches 'asoc/topic/multi-codec', ↵Mark Brown
'asoc/topic/mxs-saif', 'asoc/topic/mxs-sgtl5000', 'asoc/topic/omap' and 'asoc/topic/pxa' into asoc-next
2014-11-27ASoC: mxs-sgtl5000: Remove MCLK restrictionFabio Estevam
According to the sgtl5000 datasheet the MCLK frequency range restriction of 8 to 27 MHz only applies when the PLL is used - synchronous SYS_MCLK input mode. mxs-sgtl5000 machine sets the codec as slave, and mx28 generates MCLK in the range of 256*fs, 384*fs or 512*fs, which is called asynchronous SYS_MCLK input. In asynchronous SYS_MCLK we cannot have the 8 to 27 MHz check because if we want to play a 8KHz sample rate track, with a MCLK of 8k * 512 = 4.096MHz the current check would return -EINVAL, which is not correct. Remove the 8 to 27MHz frequency check, since this only applies to the synchronous SYS_MCLK input case. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-10ASoC: mxs: mxs-saif: Register the irq with the device nameFabio Estevam
Instead of registering the irq name with the driver name, it's better to pass the device name so that we have a more explicit indication as to what saif instance the irq is related: $ cat /proc/interrupts CPU0 ... 214: 4 - 59 80042000.saif 215: 0 - 58 80046000.saif Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20ASoC: mxs: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-01-16Merge remote-tracking branches 'asoc/topic/adsp', 'asoc/topic/atmel', ↵Mark Brown
'asoc/topic/bcm2835', 'asoc/topic/docs', 'asoc/topic/fsl', 'asoc/topic/generic', 'asoc/topic/kirkwood', 'asoc/topic/mc13783', 'asoc/topic/mxs', 'asoc/topic/nuc900', 'asoc/topic/sai', 'asoc/topic/sh', 'asoc/topic/ssm2602', 'asoc/topic/tlv320aic3x', 'asoc/topic/twl4030', 'asoc/topic/ux500', 'asoc/topic/width' and 'asoc/topic/x86' into for-tiwai
2014-01-07ASoC: mxs: Remove SND_DMAENGINE_PCM_FLAG_NO_RESIDUE flagLars-Peter Clausen
Since commit 7b11304 ("dma: mxs-dma: Report correct residue for cyclic DMA") the mxs dmaengine driver has support for residue reporting. So there is no need to specify the SND_DMAENGINE_PCM_FLAG_NO_RESIDUE flag anymore. This allows a finer grained resolution for the PCM pointer as well as avoids the race condition that can occur with the period counting that is used when the dmaengine driver does not support residue reporting. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-07ASoC: mxs: Don't set unused struct snd_pcm_hardware fieldsLars-Peter Clausen
The ASoC core assumes that the PCM component of the ASoC card transparently moves data around and does not impose any restrictions on the memory layout or the transfer speed. It ignores all fields from the snd_pcm_hardware struct for the PCM driver that are related to this. Setting these fields in the PCM driver might suggest otherwise though, so rather not set them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-02Merge remote-tracking branches 'asoc/topic/ad1836', 'asoc/topic/ad193x', ↵Mark Brown
'asoc/topic/adav80x', 'asoc/topic/adsp', 'asoc/topic/ak4641', 'asoc/topic/ak4642', 'asoc/topic/arizona', 'asoc/topic/atmel', 'asoc/topic/au1x', 'asoc/topic/axi', 'asoc/topic/bcm2835', 'asoc/topic/blackfin', 'asoc/topic/cs4271', 'asoc/topic/cs42l52', 'asoc/topic/da7210', 'asoc/topic/davinci', 'asoc/topic/ep93xx', 'asoc/topic/fsl', 'asoc/topic/fsl-mxs', 'asoc/topic/generic', 'asoc/topic/hdmi', 'asoc/topic/jack', 'asoc/topic/jz4740', 'asoc/topic/max98090', 'asoc/topic/mxs', 'asoc/topic/omap', 'asoc/topic/pxa', 'asoc/topic/rcar', 'asoc/topic/s6000', 'asoc/topic/sai', 'asoc/topic/samsung', 'asoc/topic/sgtl5000', 'asoc/topic/spear', 'asoc/topic/ssm2518', 'asoc/topic/ssm2602', 'asoc/topic/tegra', 'asoc/topic/tlv320aic3x', 'asoc/topic/twl6040', 'asoc/topic/txx9', 'asoc/topic/uda1380', 'asoc/topic/width', 'asoc/topic/wm8510', 'asoc/topic/wm8523', 'asoc/topic/wm8580', 'asoc/topic/wm8711', 'asoc/topic/wm8728', 'asoc/topic/wm8731', 'asoc/topic/wm8741', 'asoc/topic/wm8750', 'asoc/topic/wm8753', 'asoc/topic/wm8776', 'asoc/topic/wm8804', 'asoc/topic/wm8900', 'asoc/topic/wm8901', 'asoc/topic/wm8940', 'asoc/topic/wm8962', 'asoc/topic/wm8974', 'asoc/topic/wm8985', 'asoc/topic/wm8988', 'asoc/topic/wm8990', 'asoc/topic/wm8991', 'asoc/topic/wm8994', 'asoc/topic/wm8995', 'asoc/topic/wm9081' and 'asoc/topic/x86' into asoc-next
2013-12-19ASoC: fsl/mxs: Remove unnecessarily gendered languageMatthew Garrett
The kernel as a number of cases of gendered language. The majority of these refer to objects that don't have gender in English, and so I've replaced them with "it" and "its". Some refer to people (developers or users), and I've replaced these with the singular "they" variant. Some are simply typos that I've fixed up. I've left cases where gendered language was used to refer to specific individuals, was a quote or is part of license text. Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-18ASoC: fsl/mxs: Remove unnecessarily gendered languageMark Brown
2013-12-02ASoC: mxs: Use devm_snd_dmaengine_pcm_register()Lars-Peter Clausen
Makes the code shorter. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-24Merge remote-tracking branch 'asoc/topic/mxs' into asoc-nextMark Brown
2013-10-14ASoC: mxs-saif: Handle errors in trigger functionMarkus Pargmann
Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-14ASoC: mxs-saif: Store saif stateMarkus Pargmann
Trigger commands may be passed multiple times. To avoid errors with clk_enable/disable, store the saif state and return if saif is already running/stopped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-19ASoC: mxs-saif: Use devm_snd_soc_register_componentSachin Kamat
devm_snd_soc_register_component makes code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17ASoC: mxs: mxs-sgtl5000: Simplify probe functionFabio Estevam
mxs is a device tree only platform, which allows us to simplify a bit mxs_sgtl5000_probe(), because there is no need to check whether device tree is supported or not. Remove mxs_sgtl5000_probe_dt() and place its content inside mxs_sgtl5000_probe() for making the code simpler. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-01Merge remote-tracking branch 'asoc/topic/fsl' into tmpMark Brown
2013-09-01ASoC: mxs-sgtl5000: Configure the dai_links as unidirectionalFabio Estevam
On a mx28 board, running "aplay -l" and "arecord -l" results in the following: $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: mxssgtl5000 [mxs_sgtl5000], device 0: Playback sgtl5000-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: mxssgtl5000 [mxs_sgtl5000], device 1: Capture sgtl5000-1 [] Subdevices: 1/1 Subdevice #0: subdevice #0 $ arecord -l **** List of CAPTURE Hardware Devices **** card 0: mxssgtl5000 [mxs_sgtl5000], device 0: Playback sgtl5000-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: mxssgtl5000 [mxs_sgtl5000], device 1: Capture sgtl5000-1 [] Subdevices: 1/1 Subdevice #0: subdevice #0 ,which is not correct because we got a capture device listed in aplay and a playback device listed in arecord. On mx28 there are two serial audio interface ports (SAIF0 and SAIF1) and each one of them are unidirectional. Allow to specify a dai link as 'playback_only' or 'capture_only', which suits well for this case. After this change we can correctly report the capabilities as follows: $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: mxssgtl5000 [mxs_sgtl5000], device 0: HiFi Playback sgtl5000-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 $ arecord -l **** List of CAPTURE Hardware Devices **** card 0: mxssgtl5000 [mxs_sgtl5000], device 1: HiFi Capture sgtl5000-1 [] Subdevices: 1/1 Subdevice #0: subdevice #0 Also tested playback and capture on the mx28evk board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-05ASoC: mxs: add some error messages to help identifying problemsLothar Waßmann
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-22ASoC: mxs: Depends on COMMON_CLKMark Brown
The SAIF driver is a clock provider so specifically needs the common clock implementedation. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2013-07-22ASoC: mxs: Remove unneeded mach-types.h inclusionsMark Brown
2013-07-19ASoC: mxs: Enable COMPILE_TEST buildsMark Brown
Since DT based boards don't have any dependency on arch/arm enable them if COMPILE_TEST is enabled. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-04Merge remote-tracking branch 'asoc/fix/mxs' into asoc-linusMark Brown
2013-07-01ASoC: mxs: register saif mclk to clock frameworkShawn Guo
Mostly the mxs system design uses saif0 mclk output as the clock source of codec. Since the mclk is implemented as a general divider with the saif clk as the parent clock, let's register the mclk as a basic clk-divider to common clock framework. Then with it being a clock provdier, clk_get() call in codec driver probe function will just work. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-17Merge remote-tracking branch 'asoc/topic/mxs' into asoc-nextMark Brown
2013-05-13ASoC: mxs: move to use generic DMA helperShawn Guo
With mxs-dma converted to generic DMA bindings, let's move mxs-pcm to use it by removing flages SND_DMAENGINE_PCM_FLAG_NO_DT and SND_DMAENGINE_PCM_FLAG_COMPAT. As the result, those mxs custom dma params code can be removed now. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12ASoC: mxs: mxs-saif: Let device core handle pinctrlFabio Estevam
Since commit ab78029 (drivers/pinctrl: grab default handles from device core), we can rely on device core for handling pinctrl. So remove devm_pinctrl_get_select_default() from the driver. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12ASoC: mxs-sgtl5000: Remove unneeded fields from snd_soc_dai_linkFabio Estevam
It makes no sense to hardcode the I2C bus into the codec_name field. cpu_dai_name and platform_name are also overwritten later in mxs_sgtl5000_probe_dt(). So remove the three fields, as mxs platform is dt-only platform. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12ASoC: mxs-sgtl5000: Remove unneeded 'ret' variableFabio Estevam
Variable 'ret' is not needed here, so just remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-03Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Mostly many small changes spread as seen in diffstat in sound/* directory by this update. A significant change in the subsystem level is the introduction of snd_soc_component, which will help more generic handling of SoC and off-SoC components. Also, snd_BUG_ON() macro is enabled unconditionally now due to its misuses, so people might hit kernel warnings (it's a good thing for us). - compress-offload: support for capture by Charles Keepax - HD-audio: codec delay support by Dylan Reid - HD-audio: improvements/fixes in generic parser: better headphone mic and headset mic support, jack_modes hint consolidation, proper beep attach/detachment, generalized power filter controls by David Henningsson, et al - HD-audio: Improved management of HDMI codec pins/converters - HD-audio: Better pin/DAC assignment for VIA codecs - HD-audio: Haswell HDMI workarounds - HD-audio: ALC268 codec support, a few new quirks for Chromebooks - USB: regression fixes: USB-MIDI autopm fix, the recent ISO latency fix by Clemens Ladisch - USB: support for DSD formats by Daniel Mack - USB: A few UAC2 device endian/cock fixes by Eldad Zack - USB: quirks for Emu 192kHz support, Novation Twitch DJ controller, Yamaha THRxx devices - HDSPM: updates for TCO controls by Adrian Knoth - ASoC: Add a snd_soc_component object type for generic handling of SoC and off-SoC components by Kuninori Morimoto, - dmaengine: a large set of cleanups and conversions by Lars-Peter Clausen - ASoC DAPM: performance optimizations from Ryo Tsutsui - ASoC DAPM: support for mixer control sharing by Stephen Warren - ASoC: multiplatform ARM cleanups from Arnd Bergmann - ASoC: new codec drivers for AK5385 and TAS5086 from Daniel Mack" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (315 commits) ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatch ALSA: asihpi: add format support check in snd_card_asihpi_capture_formats ALSA: pcm_format_to_bits strong-typed conversion ALSA: compress: fix the states to check for allowing read ALSA: hda - Move Thinkpad X220 to use auto parser ALSA: USB: adjust for changed 3.8 USB API ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sources sound: oss/dmabuf: use dma_map_single ALSA: ali5451: use mdelay instead of large udelay constants ALSA: hda - Add the support for ALC286 codec ALSA: usb-audio: USB quirk for Yamaha THR10C ALSA: usb-audio: USB quirk for Yamaha THR5A ALSA: usb-audio: USB quirk for Yamaha THR10 ALSA: usb-audio: Fix autopm error during probing ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINT ALSA: sound kconfig typo ALSA: emu10k1: Fix dock firmware loading ASoC: ux500: forward declare msp_i2s_platform_data ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modes ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializers ...
2013-04-23Merge remote-tracking branch 'asoc/topic/dma' into asoc-nextMark Brown
2013-04-22ASoC: mxs: Use generic dmaengine PCMLars-Peter Clausen
Use the generic dmaengine PCM driver instead of a custom implementation. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ASoC: mxs: Setup dma data in DAI probeLars-Peter Clausen
This allows us to access the DAI DMA data when we create the PCM. We'll use this when converting mxs to generic DMA engine PCM driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ASoC: mxs-pcm: Set SNDRV_PCM_INFO_HALF_DUPLEXLars-Peter Clausen
The MXS SAIF is only half-duplex so set the SNDRV_PCM_INFO_HALF_DUPLEX flag for the PCM in order to prevent playback and capture from running at the same time. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-17ASoC: dmaengine-pcm: Make requesting the DMA channel at PCM open optionalLars-Peter Clausen
Refactor the dmaengine PCM library to allow the DMA channel to be requested before opening a PCM substream. snd_dmaengine_pcm_open() now expects a DMA channel instead of a filter function and filter parameter as its parameters. snd_dmaengine_pcm_close() is updated to not release the DMA channel. This allows a dmaengine based PCM driver to request its channels before the substream is opened. The patch also introduces two new functions, snd_dmaengine_pcm_open_request_chan() and snd_dmaengine_pcm_close_release_chan(), which have the same signature and behaviour of the old snd_dmaengine_pcm_{open,close}() and internally use the new variants of these functions. All users of snd_dmaengine_pcm_{open,close}() are updated to use snd_dmaengine_pcm_open_request_chan() and snd_dmaengine_pcm_close_release_chan(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-12Merge remote-tracking branch 'asoc/topic/dma' into asoc-nextMark Brown
2013-04-01ASoC: mxs-saif: remove mach header inclusionShawn Guo
The header <mach/hardware.h> is not needed at all, and <mach/mxs.h> is needed only for macros MXS_SET_ADDR and MXS_CLR_ADDR. Define the macros and remove the mach header inclusions. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-26ASoC: switch over to use snd_soc_register_component() on mxs saifKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-26ASoC: mxs: Embed the mxs_dma_data struct in the mxs_pcm_dma_params structLars-Peter Clausen
Currently the mxs_dma_data struct, which gets passed to the dmaengine driver, is allocated in the pcm driver's open callback. The mxs_dma_data struct has exactly one field which is initialized from the the same field in the mxs_pcm_dma_params struct. The mxs_pcm_dma_params struct gets passed to the pcm driver from the dai driver. Instead of taking this indirection embed the mxs_dma_data struct directly in the mxs_pcm_dma_params struct. This allows us to simplify the pcm driver quite a bit, since we don't have to care about memory managing the mxs_dma_data struct anymore. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-01-22ASoC: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-08ASoC: mxs-saif: Use a signed integer for error valueFabio Estevam
saif->id and saif->master_id are unsigned, so they can not be negative. Fix the following warning when building with W=1 option: sound/soc/mxs/mxs-saif.c: In function 'mxs_saif_probe': sound/soc/mxs/mxs-saif.c:676:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] sound/soc/mxs/mxs-saif.c:688:3: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] sound/soc/mxs/mxs-saif.c:692:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] Use a signed variable 'ret' to handle the error values. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-01-08ASoC: mxs-saif: Remove platform dataFabio Estevam
All MXS users have been converted to device tree and the board files have been removed. No need to keep platform data in the driver. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: mxs: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-27ASoC: mxs-saif: export mxs_saif_put_mclk,mxs_saif_get_mclkLothar Waßmann
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
