path: root/sound/soc/omap/n810.c
2008-10-13ALSA: ASoC: Use snd_soc_dapm_nc_pin() in N810 machine driverMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-23ALSA: ASoC: Convert tlv320aic3x to a new-style i2c driver (v2)Jean Delvare
Convert the tlv320aic3x codec driver to the new (standard) device driver binding model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Vladimir Barinov <vbarinov@ru.mvista.com> Tested-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-26ALSA: ASoC: Fix error paths in N810 machine driver init and release clocks ↵Jarkko Nikula
at exit Thanks to Felipe Balbi <felipe.balbi@nokia.com> by noticing that if clk_get to sys_clkout2_src fails, then n810_snd_device is never released. Add also sys_clkout2_src release into error path, error code return and release the clocks at exit. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-10ALSA: asoc: n810 - fix build error.Liam Girdwood
This patch adds a missing " that was recently introduced (removed) in the DAI struct merge patch series. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: asoc: machines - add Digital Audio Interface (DAI) control functions.Liam Girdwood
This patch adds several functions for DAI control and config and replaces the current method of calling function pointers within the DAI struct within the machine drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: asoc: omap - merge structs snd_soc_codec_dai and snd_soc_cpu_dai.Liam Girdwood
This patch merges struct snd_soc_codec_dai and struct snd_soc_cpu_dai into struct snd_soc_dai for the Omap platform. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: asoc: core - refactored DAPM pin control API.Liam Girdwood
Refactored snd_soc_dapm_set_endpoint() to snd_soc_dapm_enable_pin() and snd_soc_dapm_disable_pin(). Renamed snd_soc_dapm_sync_endpoints() to snd_soc_dapm_sync(). Renamed snd_soc_dapm_get_endpoint_status() to snd_soc_dapm_get_pin_status(). Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-26ALSA: ASoC: Add digital mic configuration to N810 machine driverJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-13ALSA: ASoC: Cover also Nokia N810 WiMAX Edition in N810 machine driverJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-19[ALSA] ASoC: Convert N810 machine driver to use gpiolibJarkko Nikula
Use gpiolib since it is now available for OMAPs. Change also references to HW version RX44 to product name N810. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-19[ALSA] soc - n810 - Update for bulk DAPM registration APIsMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-13[ALSA] ASoC: Fix wrong enum count for jack_function in N810 machine driverJarkko Nikula
Fix this typo and avoid similar errors by using ARRAY_SIZE macro. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-29[ALSA] ASoC: Add drivers for the Texas Instruments OMAP processorsJarkko Nikula
Add common OMAP ASoC drivers and machine driver for Nokia N810. Currently supported features are: - Covers OMAPs from 1510 to 2420 - Common DMA driver - DAI link driver using McBSP port in I2S mode - Basic machine driver for Nokia N810 Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
