Fixes: ddd17531ad908 ("ASoC: omap-mcpdm: Clean up with devm_* function")
Managed irq request will not doing any good in ASoC probe level as it is
not going to free up the irq when the driver is unbound from the sound
card.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reported-by: Russell King <linux@armlinux.org.uk>
Signed-off-by: Mark Brown <broonie@kernel.org>
This reverts commit 65aca64d05b5eaa5ce15e18b458a8d338ddbd478.
The patches for twl6040 MFD and clk missed the merge window and
causing the McPDM driver to never probe since it is put back to
the deferred list because the missing drivers.
McPDM module receives it's functional clock from external source. This
clock is the pdmclk provided by the twl6040 audio IC. If the clock is not
available all register accesses to McPDM fails and the module is not
operational.
Acked-by: Rob Herring <robh@kernel.org>
Implement ASoC's suspend and resume callbacks.
Since McPDM does not use pcm_trigger for start and stop of the stream due
to strict sequencing needs with the twl6040, the callbacks will stop and
restart the McPDM in case the board suspended during audio activity.
The DS4_WD_EN bit is only touched before calling omap_mcpdm_open_streams().
Move it inside of that function for simplicity.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Make including the omap-pcm.h outside sound/soc/omap more convenient.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Use the same device for the platform driver when registering as the dai
driver. This will enable us to clean up some DT booted cases.
Assign the dai dma data at dai driver probe time, not in startup.
All OMAP IP blocks expect LE data, but CPU may operate in BE mode.
Need to use endian neutral functions to read/write h/w registers.
I.e instead of __raw_read[lw] and __raw_write[lw] functions code
need to use read[lw]_relaxed and write[lw]_relaxed functions.
If the first simply reads/writes register, the second will byteswap
it if host operates in BE mode.
Changes are trivial sed like replacement of __raw_xxx functions
with xxx_relaxed variant.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
devm_snd_soc_register_component makes code simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Remove unneeded error handling on the result of a call to
platform_get_resource_byname when the value is passed to devm_ioremap_resource.
In the case of omap-dmic.c, the error-handling code of
devm_ioremap_resource is also corrected to include releasing the clock.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression pdev,res,e,e1;
expression ret != 0;
identifier l;
res = platform_get_resource_byname(...);
- if (res == NULL) { ... \(goto l;\|return ret;\) }
e = devm_ioremap_resource(e1, res);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The DMA resource no longer available via this API when booting with DT.
McPDM is only available on OMAP4/5 and both can boot with DT only.
Set the dma_data.filter_data to the DMA name which will be used by omap-pcm
to request the DMA channel.
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Use the common DAI DMA data struct for omap, this allows us to use the common
helper function to configure the DMA slave config based on the DAI DMA data.
For omap-dmic and omap-mcpdm also move the DMA data from a global variable to
the driver state struct.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
The IO address is no longer hardwired into the driver.
Due to HW limitation within OMAP McPDM IP uplink and downlink need to be
started at the same time. This causes issues when we have two streams
running, for example:
arecord | aplay
In this case the playback stream would have no channels enabled since at the
capture start we are not aware that a playback is going to start.
The workaround is to configure the other direction to stereo when the first
stream is started. When the second stream is coming we check the new stream's
number of channels against the pre-configured channels. If it does not match
we stop and restart McPDM to update the configuration. This might result a
small pop. If the coming stream is a match we do nothing in the McPDM driver.
This workaround can handle most use cases without the need to restart McPDM.
mcpdm_link_config will collect the link direction related configurations like
channel masks, FIFO threshold.
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com>
Clean up McPDM driver with devm_ function.
Signed-off-by: Sebastien Guiriec <s-guiriec@ti.com>
Remove unused memory ressource get from McPDM driver.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v3.7
Nothing too exciting except for the ams-delta change which is relatively
lerge due to the fact that the driver loading had been totally broken as
the driver needed a newer API to function.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This contains pretty many small commits covering fairly large range of
files in sound/ directory. Partly because of additional API support
and partly because of constantly developed ASoC and ARM stuff.
Some highlights:
- Introduced the helper function and documentation for exposing the
channel map via control API, as discussed in Plumbers; most of PCI
drivers are covered, will follow more drivers later
- Most of drivers have been replaced with the new PM callbacks (if
the bus is supported)
- HD-audio controller got the support of runtime PM and the support
of D3 clock-stop. Also changing the power_save option in sysfs
kicks off immediately to enable / disable the power-save mode.
- Another significant code change in HD-audio is the rewrite of
firmware loading code. Other than that, most of changes in
HD-audio are continued cleanups and standardization for the generic
auto parser and bug fixes (HBR, device-specific fixups), in
addition to the support of channel-map API.
- Addition of ASoC bindings for the compressed API, used by the
mid-x86 drivers.
- Lots of cleanups and API refreshes for ASoC codec drivers and
DaVinci.
- Conversion of OMAP to dmaengine.
- New machine driver for Wolfson Microelectronics Bells.
- New CODEC driver for Wolfson Microelectronics WM0010.
- Enhancements to the ux500 and wm2000 drivers
- A new driver for DA9055 and the support for regulator bypass mode."
Fix up various arm soc header file reorg conflicts.
* tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits)
ALSA: hda - Add new codec ALC283 ALC290 support
ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls
ALSA: hda - fix indices on boost volume on Conexant
ALSA: aloop - add locking to timer access
ALSA: hda - Fix hang caused by race during suspend.
sound: Remove unnecessary semicolon
ALSA: hda/realtek - Fix detection of ALC271X codec
ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310
ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event
ALSA: hda - make a generic unsol event handler
ASoC: codecs: Add DA9055 codec driver
ASoC: eukrea-tlv320: Convert it to platform driver
ALSA: ASoC: add DT bindings for CS4271
ASoC: wm_hubs: Ensure volume updates are handled during class W startup
ASoC: wm5110: Adding missing volume update bits
ASoC: wm5110: Add OUT3R support
ASoC: wm5110: Add AEC loopback support
ASoC: wm5110: Rename EPOUT to HPOUT3
ASoC: arizona: Add more clock rates
ASoC: arizona: Add more DSP options for mixer input muxes
The OMAP revision check is not needed since the watchdog bit is not in use
on 4430 ES1.0 and have no effect when we set the bit. The watchdog need to
be enabled on all other revisions.
McPDM needs platt/cpu.h for omap_rev and not omap_hwmod.h.
Drivers must not include omap_hwmod.h at, it will be
private to mach-omap2 soon. Fix the problem before other
drivers will also start including omap_hwmod.h.
Note that also plat/cpu.h will be going away, so the
omap_rev check needs to be replaced with mcpdm-watchdog
flag from platform_data or DT.
Set the dma_data for the stream (snd_soc_dai_set_dma_data) at dai_startup
time so omap-pcm will have access to the needed information regarding to
the DMA channel earlier.
This is needed for the clean dmaengine support.
Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
omap-pcm can figure out the correct dma_type based on the stream's format.
In this way we can get rid of the plat/dma.h include from these drivers.
Get the needed resources in a correct way and avoid using defines for them.
The omap-pcm platform driver no longer needs this parameter to select
between ELEMENT and PACKET mode. The selection is based on the configured
packet_size.
As the plat and mach includes need to disappear for single zImage work,
we need to remove plat/hardware.h.
Do this by splitting plat/hardware.h into omap1 and omap2+ specific files.
The old plat/hardware.h already has omap1 only defines, so it gets moved
to mach/hardware.h for omap1. For omap2+, we use the local soc.h
that for now just includes the related SoC headers to keep this patch more
readable.
Note that the local soc.h still includes plat/cpu.h that can be dealt
with in later patches. Let's also include plat/serial.h from common.h for
all the board-*.c files. This allows making the include files local later
on without patching these files again.
Note that only minimal changes are done in this patch for the
drivers/watchdog/omap_wdt.c driver to keep things compiling. Further
patches are needed to eventually remove cpu_is_omap usage in the drivers.
Also only minimal changes are done to sound/soc/omap/* to remove the
unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's
no need to include omap44xx.h.
While at it, also sort some of the includes in the standard way.
Cc: linux-watchdog@vger.kernel.org
Cc: alsa-devel@alsa-project.org
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Switch to use devm_* te make the probe/remove code more cleaner.
The MODULE_ALIAS() was missing from the driver.
Device tree support for OMAP4+ McPDM cpu dai driver.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
McPDM internal FIFO is 24 bit wide. From the 32 bit sample
8 bit is discarded. Let application know about this
via msbits constraint.
Now that the core holds a pm_runtime reference to the device while the
link is active there is no need for the driver to do so.
Factor out some boilerplate code.
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
The offset cancellation values can be different from board to board, even
on the same HW platform.
Provide a way for the machine drivers to configure the McPDM offset
cancellation.
OMAP4 McPDM supports 5 downlink (playback), and
3 uplink (capture) channels.
Reasons for the replacement:
The current driver for McPDM was developed to support the legacy mode only.
In preparation for the ABE support the current driver stack need the be
replaced.
The new driver is much simpler, easier to extend, and it also fixes some of the
issues with the old stack.
Main changes:
- single file for omap-mcpdm (mcpdm.c/h removed)
- Define names for registers, bits cleaned up, prefixed
- Full-duplex audio operation (arecord | aplay) has been fixed
- Less code
McPDM need to be turned off after all streams has been stopped.
This might cause pop noise on the output, if the codec's DAC is
still powered at this time.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
In order to probe, and operate correctly, the OMAP McPDM driver needs to
be converted to use hwmod.
The device name has been changed to probe the driver.
Replace the clk_* with pm_runtime_* calls to manage the clocks correctly.
Missing request_mem_region/release_mem_region added.
Acked-by: Liam Girdwood <lrg@ti.com>
DMA packet_size must be configured based on the McPDM FIFO threshold
value, number of channels.
Due to the FIFO operation the DMA muse be configured differently for
playback, and capture.
At the same time fix the McPDM threshold values used for playback, and
capture to avoid broken code.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
Commit 346a5c890 (OMAP: control: move plat-omap/control.h
to mach-omap2/control.h) in the linux-omap tree removed
plat/control.h and most of its callers. This one slipped
through - breaking the build as below when
CONFIG_SND_OMAP_SOC_MCPDM is defined. Fix this.
CC sound/soc/omap/omap-mcpdm.o
sound/soc/omap/omap-mcpdm.c:35: fatal error: plat/control.h: No such file or directory
compilation terminated.
make[3]: *** [sound/soc/omap/omap-mcpdm.o] Error 1
make[2]: *** [sound/soc/omap] Error 2
make[1]: *** [sound/soc] Error 2
make: *** [sound] Error 2
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Misael Lopez Cruz <misael.lopez@ti.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Paul Walmsley <paul@pwsan.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This fixes a memory corruption when ASoC devices are used in
full-duplex mode. Specifically for pxa-ssp code, where this pointer
is dynamically allocated for each direction and destroyed upon each
stream start.
All other platforms are fixed blindly, I couldn't even compile-test
them. Sorry for any breakage I may have caused.
[Note that this is a backported version for 2.6.34.
Upstream commit is fd23b7dee]
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Reported-by: Sven Neumann <s.neumann@raumfeld.com>
Reported-by: Michael Hirsch <m.hirsch@raumfeld.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
McPDM platform driver is configured to use sDMA in order to transfer
to/from memory. Support for interfacing with ABE will be added later.
McPDM dai currently supports up to 4 downlink channels and 2 uplink
channels simultaneously, as well as 88.2 and 96 KHz, and a sample
size of 32 bits.
Signed-off-by: Misael Lopez Cruz <x0052729@ti.com>
Signed-off-by: Margarita Olaya <x0080101@ti.com>
Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com>
