path: root/sound/soc/pxa/Makefile
2011-05-19ASoC: add iPAQ hx4700 machine driverDmitry Artamonow
AK4641 connected via I2S and I2C, jack detection via GPIO. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-18ASoC: add saarb machine driver for 88pm860xHaojian Zhuang
88PM860x codec is used in Marvell saarb development board. 88PM860x codec is used as master mode for SSP communication. Only I2S format is supported. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-18ASoC: add tavorevb3 machine driver for 88pm860xHaojian Zhuang
2010-04-12ASoC: Zipit Z2 WM8750 ASoC driverMarek Vasut
This patch adds support for sound through the WM8750 codec on Zipit Z2. Also, this patch incorporates support for detecting headset jack insertion through the jack detection API. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-27ALSA: ARM: add Raumfeld audio supportDaniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-05ASoC: IMote2 ASoC SupportJonathan Cameron
This patch adds the ASoC side of the board support for the Crossbow IMB400 daughter board. Thanks to Crossbow for considerable assistance. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-02ASoC: Add Magician machine supportPhilipp Zabel
HTC Magician has a Philips UDA1380 codec connected via SSP1 (playback) and I2S (capture). There is a flip-flop between the SSP frame clock output and the codec's word select input pin. To make the codec see proper I2S input, the SSP has to send two frames per sample. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-08ASoC: Add initial support of Mitac mioa701 device SoC.Robert Jarzmik
This machine driver enables sound functions on Mitac mio a701 smartphone. Build upon ASoC v1, it handles : - rear speaker - front speaker - microphone - GSM A global "Mio Mode" switch is not yet provided to cope with audio path setup. As balance on audio chip line is no more assured, an incorrect setup can produce a lot of heat and even fry the battery behind the wm9713 and the speaker amplifier. It doesn't cope with : - headset jack - mio master mode - master volume control This driver is backported from ASoc v2, and amputated from scenario setups and master volume control. [Minor mods for terminology in comments -- broonie] Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-19ASoC: machine support for Toshiba e740 PDAIan Molton
This patch provides suupport for the wm9705 AC97 codec on the Toshiba e740. Note: The e740 has a hard headphone switch that turns the speaker off and is not software detectable or controlable. Also both headphone and speaker amps share a common output enable. Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-16ASoC: machine driver for Toshiba e750Ian Molton
This patch adds support for the wm9705 ac97 codec as used in the Toshiba e750 PDA. It includes support for powering up / down the external headphone and speaker amplifiers on this machine. Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-21ASoC: Add Marvell Zylonite machine supportMark Brown
Implement support for the Marvell Zylonite PXA3xx reference platform, supporting standard AC97 stereo and AUX interfaces together with the auxiliary I2S interface of the WM9713. The board has two options for the MCLK of the WM9713: either the standard AC97 system clock can be used or the 13MHz CLK_POUT output of the PXA3xx can be used, selected via SW15 on the board. Currently only the AC97 system clock is supported by this driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-05ASoC: Add Palm/PXA27x unified ASoC audio driverMarek Vasut
this patch adds asoc audio driver for pxa27x based Palm PDAs. I tested it for palmtx, t5 and ld, it should work with palmz72 as well (slapin, please test). I sent it here some time ago, but now I got to fixing bugs in it. It should be somehow mostly ok and ready for applying. [Converted to use snd_soc_dapm_nc_pin() and bool Kconfig -- broonie] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-30ASoC: Add PXA SSP supportMark Brown
The SSP ports PXA series processors can be used to implement a variety of audio interface formats. This patch implements support for I2S, DSP A and DSP B modes on these ports. This patch is based on the previous out of tree pxa2xx-ssp driver (which was originally written by Liam Girdwood with updates from Philipp Zabel and Nicola Perrino) and pxa3xx-ssp driver (originally written by Seth Forsee based on the pxa2xx-ssp driver). Testing coverage is not complete currently. Tested-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-05-27[ALSA] Add EM-X270 ASoC driverMike Rapoport
This patch adds ASoC support for EM-X270 machine. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] soc - Preliminary ac97 drivers for Toshiba e800 PDAsIan Molton
Currently only the AUX channel is used (touchscreen) Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-02-09[ALSA] ASoC pxa2xx build supportLiam Girdwood
This patch builds ASoC pxa2xx support for Corgi, Spitz, Tosa and Poodle Zaurus machines. From: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
