path: root/sound/soc/pxa/magician.c
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Lock the CODEC in PXA external jack controlsMark Brown
When doing anything with the system, especially DAPM, we need to hold the CODEC mutex. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-23ASoC: pxa2xx-i2s is the proper name of the I2S DAI, not pxa-i2s.Ian Lartey
Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-05ASoC: Add source argument to PLL configurationMark Brown
More and more devices feature PLLs and FLLs with the ability to select between multiple input clocks. In order to better support these devices a new argument, source, has been added to the set_pll() configuration API. Using set_clkdiv() is often difficult due to the need to stop the PLL/FLL before any reconfiguration can be done. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-06ASoC: change set_tdm_slot api to allow slot_width override.Daniel Ribeiro
Extend set_tdm_slot to allow the user to arbitrarily set the frame width and active TX/RX slots. Updates magician.c and wm9081.c for the new set_tdm_slot(). wm9081.c still doesn't handle the slot_width override. While being there, correct an incorrect use of SlotsPerFrm(7) use in bitmask on pxa-ssp.c (SSCR0_SlotsPerFrm(x) is (((x) - 1) << 24)) ). (this series is meant for Mark's for-2.6.32 branch) Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-25Merge branch 'for-2.6.31' into for-2.6.32Mark Brown
2009-06-15ASoC: UDA1380: refactor device registrationPhilipp Zabel
This patch mostly follows commit 5998102b9095fdb7c67755812038612afea315c5 "ASoC: Refactor WM8731 device registration" to make UDA1380 use standard device instantiation. Similarly, the I2C device registration temporarily moves into the magician machine driver before it will find its final resting place in the board file. At the same time, platform specific configuration is moved to platform data and common power/reset GPIO handling moves into the codec driver. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-14ASoC: magician: fix PXA SSP clock polarityPhilipp Zabel
Follow-up fix needed since "ASoC: pxa-ssp.c fix clock/frame invert". Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-15ASoC: Optimize switch/case in magician.cTakashi Iwai
Use default to optimize the switch/case in magicial_playback_hw_params(), which also fixes the compile warnings below: sound/soc/pxa/magician.c:89: warning: 'acds' may be used uninitialized in this function sound/soc/pxa/magician.c:89: warning: 'acps' may be used uninitialized in this function Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-09ASoC: magician: remove un-necessary #include of pxa-regs.h and hardware.hEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-02ASoC: Add Magician machine supportPhilipp Zabel
HTC Magician has a Philips UDA1380 codec connected via SSP1 (playback) and I2S (capture). There is a flip-flop between the SSP frame clock output and the codec's word select input pin. To make the codec see proper I2S input, the SSP has to send two frames per sample. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
